[Code] Win32 - Get SketchUp Window Handle (WIP)
Postby thomthom » Mon Dec 27, 2010 7:59 pm
Here's a snippet to get the handle for the SketchUp window the calling ruby script belongs to.
Code: Select all
  GA_ROOTOWNER
= 3
# Returns the window handle of the SketchUp window for the input queue of the
  # calling ruby method.
  # @return [Integer] Returns a window handle on success or +nil+ on failure
  def self.get_sketchup_window
# Retrieves the window handle to the active window attached to the calling
    # thread's message queue.
    hwnd = GetActiveWindow.call
    return nil if hwnd
.nil?
    # In case the SketchUp window was not the active one - get the ancestor.
    GetAncestor.call(hwnd, GA_ROOTOWNER)
(EDIT: This method will fail if the SketchUp window isn't the active window.)
Alternative safer method here: viewtopic.php?f=180&t=33756&start=15#p297228
PluginStore Author
PluginStore Author
Re: [Code] Win32 - Get SketchUp Window Handle
Postby Dan Rathbun » Mon Dec 27, 2010 8:12 pm
Does this work if wxSU is loaded ?? (wxSU creates a toplevel invisible sxWindow and makes Sketchup a child window of it. So Sketchup is no longer the toplevel window.)
    I'm not here much anymore. But a PM will fire email notifications.
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby thomthom » Tue Dec 28, 2010 1:10 am
    It does?
    ugh... I really don't know...
    In that case I suppose one need to travel each owner until you find one which matches some properties. Not sure if window text is the most reliable as webdialog might have "SketchUp" in it. Maybe by class...?
    Seems that wxSU has a number of issues under SU...
    PluginStore Author
    PluginStore Author
    Postby thomthom » Tue Dec 28, 2010 1:01 pm
    Further testing: the method will fail if the SketchUp window isn't the active window.
    PluginStore Author
    PluginStore Author
    Postby honoluludesktop » Tue Dec 28, 2010 10:34 pm
    Handle is a term I recall from my "good old DOS days":-) Can the "SketchUp Window Handle" be used to close an instance of SketchUp from another instance of SketchUp?
    honoluludesktop
    In Remembrance
    Postby Dan Rathbun » Wed Dec 29, 2010 12:24 am
    honoluludesktop wrote:Handle is a term I recall from my "good old DOS days":-) Can the "SketchUp Window Handle" be used to close an instance of SketchUp from another instance of SketchUp?
    Yes ... BUT ... we must first solve the issue of getting the CORRECT handle for each instance, and storing it (in the proper place,) where it can be accessed by multiple plugins.
    Once the "handle" is determined, the code that was needed to find it, is no longer needed, and should be garbage collected.
    THEN ... you'll need to solve the issue of talking between two instances of Sketchup Ruby, and having one inform the other what it's window handle is.
      Dan Rathbun
      PluginStore Author
      PluginStore Author
      Postby thomthom » Wed Dec 29, 2010 1:55 am
      GetActiveWindow
      http://msdn.microsoft.com/en-us/library ... 85%29.aspx
      The return value is the handle to the active window attached to the calling thread's message queue. Otherwise, the return value is NULL.
      What is interesting with this function is that it find a window based on the calling thread. But it's limitation is that it requires one of the windows that belong to the thread to the the active one.
      But, I'm trying to find a function that either let you enumerate the windows that belong to a thread, or get the top most window for a thread. In either one of those conditions one should be able to reliably get the window handle.
      I think one can get lots of useful info if one can get the thread id of the SketchUp process. Any ideas of how one can do this. I've been scanning the Win32 API a bit today looking for relevant functions.
      PluginStore Author
      PluginStore Author
      Postby Jim » Wed Dec 29, 2010 2:11 am
      I am not entirely sure the Win32API.so file we all have been using supports callbacks, which the windows enumerator functions require as arguments.
      Specifically, calls to EnumWindows and EnumChildWindows can not be used with Win32API.
      The win32-api ruby library does support callbacks, and we should really be using it anyway. it's more robust, and more stable (I've read.)
      Jim
      Global Moderator
      Postby thomthom » Wed Dec 29, 2010 2:22 am
      Jim wrote:I am not entirely sure the Win32API.so file we all have been using supports callbacks, which the windows enumerator functions require as arguments.
      The win32-api ruby library does support callbacks, and we should really be using that it anyway. it's more robust, and more stable (I've read.)
      I was just looking at this. I noticed the lack of Callback.
      Where is the win32-api found - the one that supports callbacks?
      PluginStore Author
      PluginStore Author
      Postby Jim » Wed Dec 29, 2010 2:26 am
      thomthom wrote:Where is the win32-api found - the one that supports callbacks?
      http://win32utils.rubyforge.org/
      I'm not sure if this can co-exist with Win32API or not.
      require 'win32/api'
      win32.zip
      Jim
      Global Moderator
      Postby thomthom » Wed Dec 29, 2010 3:05 am
      The example I saw of it:
      http://stackoverflow.com/questions/3327 ... 09#3328209
      Seemed to use namespace Win32 as oppose to Win32API.
      So this is not a module that ships with Ruby?
      PluginStore Author
      PluginStore Author
      Postby Dan Rathbun » Wed Dec 29, 2010 3:12 am
      thomthom wrote:So this is not a module that ships with Ruby?
      Correct... no it's not, because it is platform specific, AND considered an extension. You, or any user must download it from RubyForge. If you want the latest releases, as they are released. I believe you also must compile them yourself, or wait until Mr. Berger & Co decides to do it.
        Dan Rathbun
        PluginStore Author
        PluginStore Author
        Postby Dan Rathbun » Wed Dec 29, 2010 3:32 am
        thomthom wrote:win32-api Seemed to use namespace Win32 as oppose to Win32API.
        True it has it's own namespace... and another quirk.. Dan Berger reordered the arguments in the API calls making it a bit cumbersome to have scripts that can use either library.
          Dan Rathbun
          PluginStore Author
          PluginStore Author
          Postby Dan Rathbun » Wed Dec 29, 2010 3:58 am
          Jim wrote:I am not entirely sure the Win32API.so file we all have been using supports callbacks, which the windows enumerator functions require as arguments. ...
          Actually Win32API.so is obsolete, and for some time, they have been suggesting coders migrate to using the DL library directly.
          In Ruby vers 1.9.x and up... they no longer supply a Win32API.so file, instead they have replaced it with a Win32API.rb script that mimics the old so file, and translates Win32API calls into DL library calls.
          This is the Win32API.rb file distro'd with Ruby v 1.9.1 p429
          Code: Select all
          # -*- ruby -*-
          # for backward compatibility
          warn "Warning:#{caller[0].sub(/:in `.*'\z/, '')}: Win32API is deprecated after Ruby 1.9.1; use dl directly instead" if $VERBOSE
          require
          'dl'
          class Win32API
            DLL
            TYPEMAP = {"0" => DL::TYPE_VOID, "S" => DL::TYPE_VOIDP, "I" => DL::TYPE_LONG}
            def initialize(dllname, func, import, export = "0", *rest)
              @proto = [import].join.tr("VPpNnLlIi", "0SSI").sub(/^(.)0*$/, '\1')
              handle = DLL[dllname] ||= DL.dlopen(dllname)
              @func = DL::CFunc.new(handle[func], TYPEMAP[export.tr("VPpNnLlIi", "0SSI")], func, *rest)
            def call
          (*args)
              import = @proto.split("")
              args.each_with_index do |x, i|
                args[i], = [== 0 ? nil : x].pack("p").unpack("l!*") if import[i] == "S"
                args[i], = [x].pack("I").unpack("i") if import[i] == "I"
              ret
          , = @func.call(args)
              return ret || 0
            alias Call call
          It looks as though the DL library supports callbacks. Maybe we should use it ??
          I've also read that the DL library is 'on the outs', and they are planning to deprecate it and replace it with something else.
          Jim wrote:The win32-api ruby library does support callbacks, and we should really be using it anyway. it's more robust, and more stable (I've read.)
          Yes.. I agree. Dan Berger is a "sharp cookie" when it comes to both Ruby and Windows coding. He is also on several of the MAJOR Ruby development teams including RubyGems and rdoc.
          See his profile: RubyForge Profile for Daniel Berger
            Dan Rathbun
            PluginStore Author
            PluginStore Author
            Postby thomthom » Wed Dec 29, 2010 4:07 am
            Will that work for Ruby 1.8?
            PluginStore Author
            PluginStore Author
            Postby Dan Rathbun » Wed Dec 29, 2010 4:30 am
            thomthom wrote:I think one can get lots of useful info if one can get the thread id of the SketchUp process. Any ideas of how one can do this.
            How about?
            Process.pid()
            Thread.main.object_id
            thomthom wrote:I've been scanning the Win32 API a bit today looking for relevant functions.
            Well all the API functions for: Processes and Threads
              Dan Rathbun
              PluginStore Author
              PluginStore Author
              Postby thomthom » Wed Dec 29, 2010 12:46 pm
              Ah - there we go, that might help.
              GetCurrentProcessId looks promising.
              PluginStore Author
              PluginStore Author
              Postby thomthom » Wed Dec 29, 2010 12:49 pm
              pid = GetCurrentProcessId.call
              4684
              Process.pid()
              4684
              It seem to return the same thing.
              PluginStore Author
              PluginStore Author
              Postby Dan Rathbun » Wed Dec 29, 2010 2:14 pm
              thomthom wrote:pid = GetCurrentProcessId.call
              4684
              Process.pid()
              4684
              Yes and it's the same as you'll see in the Task Manager, or using tlist.exe from the command line (for that Sketchup instance.)
                Dan Rathbun
                PluginStore Author
                PluginStore Author
                Postby Dan Rathbun » Wed Dec 29, 2010 2:34 pm
                Dan Rathbun wrote: It looks as though the DL library supports callbacks. Maybe we should use it ??
                My bad.. :oops:
                Callbacks were added in 1.9.x, both 1.8.6 and 1.8.7 DL libs don't have the callback.rb file.
                sorry Thom
                  Dan Rathbun
                  PluginStore Author
                  PluginStore Author
                  Postby thomthom » Wed Dec 29, 2010 2:56 pm
                  GetCurrentThreadId I think this one is what we can use to get associated window handles. Just need to get callbacks working so we can use EnumThreadWindows to get the windows for the calling thread.
                  PluginStore Author
                  PluginStore Author
                  Postby thomthom » Wed Dec 29, 2010 3:45 pm
                  require 'win32/api'
                  win32.zip
                  I just tried it, works fine with Win32API.
                  Here's a bastardised proof of concept snippet where I found the SketchUp window regardless if it had focus or not.
                  Code: Select all
                  # http://stackoverflow.com/questions/3327666/win32s-findwindow-can-find-a-particular-window-with-the-exact-title-but-what
                  EnumWindows       = Win32::API.new('EnumWindows', 'KP', 'L', 'user32')
                  EnumThreadWindows = Win32::API.new('EnumThreadWindows', 'LKP', 'I', 'user32')
                  GetCurrentThreadId = Win32API.new("kernel32.dll", "GetCurrentThreadId", '', 'L')
                  # Detect the toolwindows even if Hide Dialogs is active.
                  def enum_sketchup_windows
                    threadId = GetCurrentThreadId.call
                    enumWindowsProc = Win32::API::Callback.new('LP', 'I'){ |handle, param|
                      #puts "EnumWindows - Callback"
                      #puts "> handle: #{handle}"
                      #puts "> param: #{param.inspect}"
                      window_text = get_window_text(handle)
                      window_text.strip! # Remove trailing NULL character
                      p window_text unless window_text.empty?
                      if !window_text.index(param).nil?
                        puts "window was found: handle #{handle}"
                        0 # FALSE - stop looking after we find it
                        1 # TRUE
                      else
                        1 # TRUE
                    EnumThreadWindows.call(threadId, enumWindowsProc, 'SketchUp')
                  # Takes the first enumerated window for the calling SketchUp thread and fetches
                  # the root owner which should be the SketchUp window. (Not tested against wxSU)
                  # Is the enum required to get just one window? Any other function to get an
                  # arbitrary window from the SketchUp thread?
                  def find_sketchup_window
                    hwnd = 0
                      hwnd = GetAncestor.call(handle, GA_ROOTOWNER)
                    hwnd
                  Remaining issues:
                  • Migrate Win32API to Win32::API for all function calls.
                  • While testing I eventually got an exception that said there was too many callbacks initiated. Seems there might be a limit. I have not looked into this further, but I think once might have to make one callback proc, and then delegate to the appropriate handling method based on param.
                  PluginStore Author
                  PluginStore Author
                  Postby thomthom » Wed Dec 29, 2010 3:56 pm
                  = Documentation
                  The source file contains inline RDoc documentation. If you installed
                  this file as a gem, then you have the docs.
                  Where do you get the source code?
                  I tried to install the gem, but got this error:
                  PluginStore Author
                  PluginStore Author
                  Postby Jim » Wed Dec 29, 2010 4:18 pm
                  It is a c-language based extension, and apparently isn't available already compiled for your platform. So you would need to compile it.
                  This is the advantage of using the mingw32 Ruby Installer with devkit - it automatically builds native libraries.
                  http://rubyinstaller.org/downloads/
                  Jim
                  Global Moderator
                  Postby thomthom » Wed Dec 29, 2010 4:33 pm
                  But where is the source code - since it's suppose to contain the documentation?
                  PluginStore Author
                  PluginStore Author
                  Postby Jim » Wed Dec 29, 2010 4:36 pm
                  For me, it is here:
                  C:\Ruby186\lib\ruby\gems\1.8\gems\win32-api-1.4.7-x86-mingw32\ext\win32
                  Jim
                  Global Moderator
                  Postby thomthom » Wed Dec 29, 2010 5:05 pm
                  hm... guess I have to look into that ming-thing...
                  Anyway - I have produced a code which appear to return the handle for the SketchUp window of the calling thread. I created a EnumWindowsProc to delegate enumeration messages in order to avoid Error: #<Win32::API::Error: too many callbacks are defined.>. I really want to know what this limit is. This is the first draft, I expect there is a better way to deal with this.
                  But, we do get a reliable window for the SketchUp window we want - as far as I have been able to test.
                  PluginStore Author
                  PluginStore Author
                  Postby thomthom » Wed Dec 29, 2010 5:08 pm
                  Maybe we can handle drag and drop by callbacks. Or intercept window messages so we can simulate the roll-up/down of toolwindows.
                  Still, OSX users are out of luck here...
                  PluginStore Author
                  PluginStore Author
                  Re: [Code] Win32 - Get SketchUp Window Handle (WIP)
                  Postby Dan Rathbun » Thu Dec 30, 2010 3:41 am
                  Here's some interesting info:
                  Code: Select all
                  #  some Sketchup window properties:
                  #  AutomationId  =  ""
                  #  CLASS   =  "Afx:00400000:b:00010011:00000006:00790557"
                  #  *** the last octet changes each time Sketchup is run,
                  #  examples:  "Afx:00400000:b:00010011:00000006:0012077F"
                  #             "Afx:00400000:b:00010011:00000006:000E0699"
                  #  ControlType           =  "ControlType.Window"
                  #  LocalizedControlType  =  "window"
                  The main application window is the only one with a classname like this, and also the only one with a LocalizedControlType that equals "window".
                  ALL dialogs including WebDialogs, are:
                  Code: Select all
                  #  ClassName             =  "#32770"
                  #  LocalizedControlType  =  "Dialog"
                    Dan Rathbun
                    PluginStore Author
                    PluginStore Author
                    Postby Dan Rathbun » Thu Dec 30, 2010 4:14 am
                    thomthom wrote:I have produced a code which appear to return the handle for the SketchUp window of the calling thread.
                    Are you planning on distibuting a pre-compiled win-api as part of TT_Lib2 ??
                    I have a few issues with this.
                    (1) It's not in the correct folder. What if a person already has it (and possibly a newer version,) installed ?
                    require will not recognize the path string you have in that example, and would load the older version down under your TT_Lib2 folder. That would overwrite the newer classes that might be loaded, if they were loaded first.
                    OR.. since "T" comes before "W" your version would get loaded first, and when a normal version gets loaded after... your code might get broken. (I say "might" as newer versions are usually better.)
                    So? I like the idea of someone precompiling Berger's WinUtils, and zipping them for manual install by the community (and/or creating a one-click-installer for dummies.) But they should be in the proper folder ... and likely a path to them appended to the $LOAD_PATH array.
                    How much of Berger's suite would the distro have? the bare bones min or the whole thing?
                      Dan Rathbun
                      PluginStore Author
                      PluginStore Author
                      Next
                      Return to Developers' Forum
                      Users browsing this forum: No registered users and 12 guests
