[code] extract png thumbnail image from .skp file
• Page 1 of 1
[code] extract png thumbnail image from .skp fileThis bit of Ruby code extracts the png image from a .skp file and writes it to disk using the same basename as the model file.
Re: [code] extract png thumbnail image from .skp fileyup, i did something similar in 2005, a viewer for .skp thumbnail inside Total Commander - see my blog post (no source though yet)
SketchUp Ruby Consultant | Podium 1.x developer
http://plugins.ro Re: [code] extract png thumbnail image from .skp file_
The following code does the same thing BUT must be run from within Sketchup Ruby.
FYI: There are three (3) save_thumbnail methods Sketchup.save_thumbnail which can work on files, other than the one that's loaded. Model.save_thumbnail which only works for the current model, but has a bug, in that if the model has never been saved, it writes a blank thumbnail image to the %UserProfile% folder instead of the Model folder specified in Preferences>Files>Model folderpath. [BUG - as of SU ver 7.1.6087] ComponentDefinition.save_thumbnail There is also View.write_image which can write a thumbnail of the current view that CAN be different than the thumbnail that was saved within the file. _
Re: [code] extract png thumbnail image from .skp fileHi,
i would like to know how to extract with better resolution than a thumbail or how t oextract texture from skp files thanks a lot ? regards Gabriel Re: [code] extract png thumbnail image from .skp file
SketchUp automatically generates a thumbnail image and saves it inside the skp file. That is what Jim's code extracts. You have no control over the size or quality of this image. In my experience, for a complex model it is almost useless. There just aren't enough pixels in it to avoid total blur of the contents. To get an image in which you control the size and quality, you must use one of the techniques Dan describes. As he notes, these are Ruby code that runs within SketchUp - though I suppose you could write code using the C API that would do it. Steve
Re: [code] extract png thumbnail image from .skp file@Gabriel... do you REALLY use pre-v6 SketchUp ? Did you download it off the web somewhere ?
Please go to SketchUp.com and download the latest free version. There are very many bugs in those old version, they should be outlawed! ![]()
Re: [code] extract png thumbnail image from .skp filethanks you a lot
i hadnt understand at the begininng it was extraction of thumbail so i understand know why their were so little . so i will try download for more recent sketchup version and i will try to find the way to find a ruby code or try to done if is not so complicated i will try to extract texture of scene and atribute the name of skp object , cause it was that s i exactly want to do thanks again and have nice year ! Gabriel Re: [code] extract png thumbnail image from .skp filehi all
anyone tried Jim's script using ruby 2 in SU... I get encoding errors on my mac... Error: invalid Unicode escape: /\xFF\xFE\xFF\x0ES\x00k\x00e\x00t\x00c\x00h\x00U\x00p\x00 \x00M\x00o\x00d\x00e\x00l\x00\xFF\xFE\xFF If I can get it to run, I can pipe the output and attach it to the skp files resource fork ... I think it would be faster then using Sketchup.save_thumbnail(skp,img) for the same purpose... I want to compare them... john learn from the mistakes of others, you may not live long enough to make them all yourself...
Re: [code] extract png thumbnail image from .skp filehi Jim
to clarify, I'm trying to run it in 'Ruby Console' using the embedded ruby 2... and it also fails using Jeff's Terminal.app cmd, but mac also uses ruby 2... john learn from the mistakes of others, you may not live long enough to make them all yourself...
John, try putting the magic comment at the head of jim's file: # coding:ascii-8bit At least that worked for me from a Terminal window. And the png I got was much nicer than the ones I remember from SU 8 when I last tried this... Steve
Re: [code] extract png thumbnail image from .skp file@steve
that stopped the errors, but still not working here... send me your copy... john learn from the mistakes of others, you may not live long enough to make them all yourself...
sent via PM
Re: [code] extract png thumbnail image from .skp filecheers Steve that works if I cd into the folder then run...
it returns the exact same png as Sketchup.save_thumbnail [if that's set for png]... pixel dimensions vary wildly from skp to skp... you can influence the size by re-saving the skp in v2015, but the logic is a little obscure... one that was 400x183, I re-saved now comes in at 256x256 but that seems to be the limit... it also cropped the image, so needs zoom extents in a square viewport to see all... the upshot is I can use it for a quick'n'dirty batch mode icon generator, but they're not as good as doing them individually using my add icon plugin... learn from the mistakes of others, you may not live long enough to make them all yourself...
• Page 1 of 1
Users browsing this forum: charlsousa786 and 14 guests
