[code] intersect_with example
Postby shirazbj » Mon Mar 16, 2009 12:25 pm
I have tried to use two intersected cubes to demonstrate how to use the intersect_with command. This could be a example for the ruby doc.
Code: Select all
    model
Sketchup.active_model
    entities
model.entities
#Create a group to collect all entities for base cube
basegroup=entities.add_group
    basegroupentities
=basegroup.entities
    p1
Geom::Point3d.new(000)
p2 Geom::Point3d.new(200000)
p3 Geom::Point3d.new(20001500)
p4 Geom::Point3d.new(01500)
p5 Geom::Point3d.new(000)
points = [p1,p2,p3,p4,p5]
#Add a face entity into base group
base basegroupentities.add_face points
    normal
base.normal
if normal==[0,0,-1]
base base.reverse
    base
.pushpull 1000
    base_trans
=basegroup.transformation
#Create a group to collect all entities used for cutting cube
cutgroup=entities.add_group
    cutgroupentities
=cutgroup.entities
    p1
Geom::Point3d.new(500, -50500)
p2 Geom::Point3d.new(1500, -50500)
p3 Geom::Point3d.new(1500200500)
p4 Geom::Point3d.new(500200500)
p5 Geom::Point3d.new(500, -50500)
#Add a face entity into cut group
base cutgroupentities.add_face points
    normal
base.normal
if normal==[0,0,-1]
base base.reverse
    base
.pushpull 1000
    cut_trans
=cutgroup.transformation
#Use all entities in cut group to cut through all entities in base group
    #The middle basegroup variable is to specify that the intersection lines are drawn on base group entities.
cutgroupentities.intersect_with falsecut_transbasegroupbase_trans truebasegroup
    status
basegroup.explode
    model
.active_view.zoom_extents
    UI
.messagebox("Click to delete cut group.")
cutgroup.erase!
3
Reason: Put the code into a code box and renamed the tag
shirazbj
Re: [ruby doc] intersect_with example
Postby DavidBoulder » Tue Feb 08, 2011 10:07 pm
Thanks, that was really helpful, but I'm having problems with a simple variation on this.
The basic concept is a model with only groups at the top level. The user selects a group and then runs the script. The script should intersect that group with the model; the new geometry is created inside of that group. My next step after this is working is to let the user multi-select and iterate through their selection. That should be easy if I can just get the basic code working first.
This is what I want for the intersect_with line, but I just can't get it to work. I guess I need to get the name of the group that is in selection[0]? and then use that similar to your code.
selection[0].intersect_with true, selection[0].transformation, selection[0], [0,0,0], true, entities
David Goldwasser
OpenStudio Developer
DavidBoulder
Postby TIG » Tue Feb 08, 2011 10:40 pm
Your selection[0] will be an entity BUT the intersect_with method is for entities - that is the 'container-entities' holding that individual entity... see
http://code.google.com/apis/sketchup/do ... rsect_with
Recast it something like... selection[0].parent.entities.intersect_with(true, selection[0].transformation, selection[0].parent.entities, selection[0].transformation, true, entities)***
***I'm not sure what your final argument 'entities' is - it should either be an 'entities object' or an 'array of entities'... it could be selection[0].parent.entities.to_a so all entities in the same context are used in the intersection :?
Global Moderator
Postby Dan Rathbun » Tue Feb 08, 2011 11:03 pm
Someone please..
Codebox the script example, parenthesize the intersect_with call (it wraps,) and rename the topic title:
[ code ] Entities.intersect_with example
.. so that Jim's sticky code index script can find it.
    I'm not here much anymore. But a PM will fire email notifications.
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    Postby DavidBoulder » Wed Feb 09, 2011 7:26 am
    TIG, thanks for you help. That got me over the hump. Below is what I was looking for. If you select one or more top level groups and run this script, it will iterate through the groups adding necessary intersecting geometry under each group.
    Code: Select all
    model = Sketchup.active_model
    entities = model.active_entities
    selection = model.selection
    # loop through selection of top level groups to create new intersecting geomtry under each group.
    selection.each { |entity|
    entity.entities.intersect_with(true, entity.transformation, entity.entities.parent, entity.transformation, true, entity.parent.entities.to_a)
    David Goldwasser
    DavidBoulder
    Re: [code] intersect_with example
    Postby TIG » Wed Feb 09, 2011 9:07 am
    I suggest you trap for non-groups
    Code: Select all
    next if not entity.class==Sketchup::Group
    Also shouldn't entity.entities.parent be entity.entities.parent.entities :?:
    Global Moderator
    Return to Developers' Forum
    Users browsing this forum: No registered users and 12 guests
