by wikii » Mon Sep 29, 2008 12:07 am
It is still in developing, here is the current version.
Get the latest version as an RBZ from the PluginStore:
Download
wikii on Mon Sep 29, 2008 1:28 am, edited 2 times in total.
wikii
PluginStore Author
Posts: 146Joined: Mon Jan 28, 2008 1:13 am
by Daniel S » Mon Sep 29, 2008 12:44 am
Wikii I get a error on the ruby console I attach a image. Daniel S
Daniel S
Posts: 341Joined: Mon Nov 12, 2007 6:06 pmLocation: Mar del Plata, Buenos Aires, Argentina
Operating system: Windows
SketchUp version: 2015
License type: Pro
SketchUp use: product design
Level of SketchUp: Intermediate
by wikii » Mon Sep 29, 2008 12:45 am
Try a curved path.
wikii
PluginStore Author
by wikii » Mon Sep 29, 2008 12:47 am
Daniel S wrote: Wikii I get a error on the ruby console I attach a image. Daniel S
Select welded edges as path and a face before using this script.
wikii
PluginStore Author
by wikii » Mon Sep 29, 2008 12:55 am
A curve path
wikii
PluginStore Author
by Daniel S » Mon Sep 29, 2008 1:02 am
Wikii I attach a video showing what i´m doing... still I get a error in the ruby console. Daniel S
Daniel S
License type: Pro
by wikii » Mon Sep 29, 2008 1:12 am
Sorry , I modified two classes. Please download again
wikii on Mon Sep 29, 2008 1:29 am, edited 1 time in total.
wikii
PluginStore Author
by solo » Mon Sep 29, 2008 1:21 am
I cannot seem to get it to work, I see it in the plugin drop down menu, but when I select it it does nada, does it work like follow me tool? if yes then I cannot seem to figure it out.
Global Moderator
Posts: 12397Joined: Mon Nov 12, 2007 1:46 pmLocation: The Colony, Texas
SketchUp version: 2017
License type: Pro
SketchUp use: other
by wikii » Mon Sep 29, 2008 1:28 am
wikii
PluginStore Author
by Daniel S » Mon Sep 29, 2008 1:29 am
Now works..
thank you Wikii!!
Solo...
install the latest version, and under Plugins you will see "FollowAndRotate". Select first a curve and a face.
Daniel S
Daniel S
License type: Pro
by solo » Mon Sep 29, 2008 1:30 am
I have tried that without anything happening.
Global Moderator
License type: Pro
SketchUp use: other
by wikii » Mon Sep 29, 2008 1:32 am
Daniel S wrote: Now works..
thank you Wikii!!
Solo...
Daniel S
wikii
PluginStore Author
by Daniel S » Mon Sep 29, 2008 1:42 am
Solo...
try with the ruby console open like in the video i attach here:
http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=12965&start=15#p94900 And if it gives error send the error to wikii.
For me is working now.
Daniel S
Daniel S
License type: Pro
by solo » Mon Sep 29, 2008 1:51 am
hey, It works!
Thanks mate.
Global Moderator
License type: Pro
SketchUp use: other
by EarthMover » Mon Sep 29, 2008 4:08 am
It's working for me also. Thanks sooo much wikii!!
3D Artist at Clearstory 3D Imaging Guide Tool at Winning With Sketchup Content Creator at Skapeup
EarthMover
Premium Member
Posts: 1801Joined: Fri Sep 12, 2008 9:06 pmLocation: Eastern Pennsylvania
SketchUp version: 2016
License type: Pro
SketchUp use: landscape architecture
Level of SketchUp: Advanced
by silver_shadow » Mon Sep 29, 2008 5:58 am
Wheeee, thanx a million !!!
silver_shadow
Posts: 277Joined: Fri Jun 06, 2008 8:11 amLocation: Cape Town, South Africa
by bigstick » Mon Sep 29, 2008 8:04 am
This is fantastic! Thanks a lot wikii!
bigstick
Posts: 248Joined: Tue Nov 27, 2007 10:29 pmLocation: Wales, UK
Operating system: Mac
SketchUp version: 2013
License type: Pro
SketchUp use: architecture
by plot-paris » Mon Sep 29, 2008 11:06 am
phantastic plugin Wikii! thanks for sharing
however, when I use a welded curve, I get very unexpected results. something doesn't seem to be working with welded paths. everything works fine if I use a bezier curve (no matter how complicated)
and I have a suggestion for a future update:
if you have a face with it's midpoint not at the starting point of the curve, the cuve will be moved to this centre point.
would it be possible to prevent this from happening, so that you can use a shape with an offset, that is twisted arround the path with a certain distance.
or even better, could you change the script to allow the use of several seperate faces?
plot-paris
Posts: 1573Joined: Tue Apr 01, 2008 10:15 amLocation: Konstanz, Germany
License type: Pro
by watkins » Mon Sep 29, 2008 11:31 am
Any chance of making this available as a .zip file? I have problems with files with .rar extensions.
watkins
Posts: 1426Joined: Wed Nov 14, 2007 5:47 pm
by pilou » Mon Sep 29, 2008 11:33 am
Funny
Done
Top SketchUcator
Posts: 21195Joined: Wed Jan 23, 2008 10:33 pm
License type: Free/Make
SketchUp use: hobby
by wikii » Mon Sep 29, 2008 1:38 pm
plot-paris wrote: and I have a suggestion for a future update: if you have a face with it's midpoint not at the starting point of the curve, the cuve will be moved to this centre point. would it be possible to prevent this from happening, so that you can use a shape with an offset, that is twisted arround the path with a certain distance.
Try to select one curve , one face and one construction point , then , using FAR. The construction point will be treated as the center of the face.
wikii
PluginStore Author
by plot-paris » Mon Sep 29, 2008 2:11 pm
weird. it only works for me, if I have a curve as a path. it doesn't work with a straight line like in your example (not even the dialog box for rotation/scale input appears)...
but arround a curve it looks really cool!
plot-paris
License type: Pro
by marcosrodrigues » Mon Sep 29, 2008 2:46 pm
Seems very promising, Wikii. Thank you.
| menos é mais
marcosrodrigues
Posts: 54Joined: Tue Jun 10, 2008 2:14 amLocation: Salvador, Brasil
by pilou » Mon Sep 29, 2008 2:53 pm
Your are not alone
And yet some erratic Works for 2 straight lines welded, sometimes yes, sometime no
Top SketchUcator
SketchUp use: hobby
by Dave R » Mon Sep 29, 2008 3:54 pm
Etaoin Shrdlu % (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Global Moderator
Posts: 18189Joined: Tue Nov 13, 2007 11:52 pmLocation: SE Minnesota
SketchUp version: 2021
License type: Pro
SketchUp use: woodworking
by wikii » Mon Sep 29, 2008 4:21 pm
Dave R wrote: Interesting plugin but this is what I get.
select a face without it's border
wikii
PluginStore Author
by Dave R » Mon Sep 29, 2008 4:29 pm
thank you. that works.
Global Moderator
License type: Pro
by watkins » Mon Sep 29, 2008 5:18 pm
Dear Pilou, Thanks for posting the .zip file. Regards, Bob
watkins
by free agent » Mon Sep 29, 2008 6:44 pm
hey wow awsome plugin, thanx for posting, is there any way to reverse the triangulation of the faces, i noticed that once smoothed the and as you rotate the form it gets very jaggy at the edges and you have to go in there with the flip edge tool to smooth it out... any way around this within the coding?
free agent
Posts: 282Joined: Thu Jun 05, 2008 10:00 amLocation: Cape Town, South Africa
by juju » Mon Sep 29, 2008 7:51 pm
We have some very gifted people here, only surpassed by their generosity. Thank you (all the ruby programmers, both free and commercial) so much for SU so much than it was.
juju
Premium Member
Posts: 2751Joined: Mon Oct 22, 2007 1:45 pmLocation: Durbanville, Cape Town, South Africa.
License type: Pro
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
