[Plugin] follow me rotate
Postby wikii » Mon Sep 29, 2008 12:07 am
It is still in developing, here is the current version.
Get the latest version as an RBZ from the PluginStore:
Download
11
wikii
PluginStore Author
PluginStore Author
Re: [REQ] follow me rotate
Postby Daniel S » Mon Sep 29, 2008 12:44 am
Wikii
I get a error on the ruby console
I attach a image.
Daniel S
Daniel S
Postby wikii » Mon Sep 29, 2008 12:45 am
Try a curved path.
wikii
PluginStore Author
PluginStore Author
Postby wikii » Mon Sep 29, 2008 12:47 am
Daniel S wrote:Wikii
I attach a image.
Daniel S
Select welded edges as path and a face before using this script.
wikii
PluginStore Author
PluginStore Author
Postby wikii » Mon Sep 29, 2008 12:55 am
A curve path
wikii
PluginStore Author
PluginStore Author
Postby Daniel S » Mon Sep 29, 2008 1:02 am
Wikii
I attach a video showing what i´m doing...
still I get a error in the ruby console.
Daniel S
Daniel S
Postby wikii » Mon Sep 29, 2008 1:12 am
Sorry , I modified two classes.
Please download again
wikii
PluginStore Author
PluginStore Author
Postby solo » Mon Sep 29, 2008 1:21 am
I cannot seem to get it to work, I see it in the plugin drop down menu, but when I select it it does nada, does it work like follow me tool? if yes then I cannot seem to figure it out.
User avatar
Global Moderator
Postby wikii » Mon Sep 29, 2008 1:28 am
wikii
PluginStore Author
PluginStore Author
Postby Daniel S » Mon Sep 29, 2008 1:29 am
Now works..
thank you Wikii!!
:thumb:
Solo...
install the latest version, and under Plugins you will see "FollowAndRotate". Select first a curve and a face.
Daniel S
Daniel S
Postby solo » Mon Sep 29, 2008 1:30 am
I have tried that without anything happening.
User avatar
Global Moderator
Postby wikii » Mon Sep 29, 2008 1:32 am
Daniel S wrote:Now works..
thank you Wikii!!
:thumb:
Solo...
Daniel S
:ecstatic:
wikii
PluginStore Author
PluginStore Author
Postby Daniel S » Mon Sep 29, 2008 1:42 am
Solo...
try with the ruby console open like in the video i attach here:
http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=12965&start=15#p94900
And if it gives error send the error to wikii.
For me is working now.
Daniel S
Daniel S
Postby solo » Mon Sep 29, 2008 1:51 am
hey, It works!
Thanks mate.
User avatar
Global Moderator
Postby EarthMover » Mon Sep 29, 2008 4:08 am
It's working for me also. Thanks sooo much wikii!! :sketchstatic:
Content Creator at Skapeup
User avatar
EarthMover
Premium Member
Premium Member
Postby silver_shadow » Mon Sep 29, 2008 5:58 am
Wheeee, thanx a million !!! :enlight:
silver_shadow
Postby bigstick » Mon Sep 29, 2008 8:04 am
This is fantastic! Thanks a lot wikii!
User avatar
bigstick
Re: [Plugin] follow me rotate
Postby plot-paris » Mon Sep 29, 2008 11:06 am
phantastic plugin Wikii! thanks for sharing :ecstatic:
however, when I use a welded curve, I get very unexpected results. something doesn't seem to be working with welded paths. everything works fine if I use a bezier curve (no matter how complicated)
and I have a suggestion for a future update:
if you have a face with it's midpoint not at the starting point of the curve, the cuve will be moved to this centre point.
would it be possible to prevent this from happening, so that you can use a shape with an offset, that is twisted arround the path with a certain distance.
or even better, could you change the script to allow the use of several seperate faces?
User avatar
plot-paris
Postby watkins » Mon Sep 29, 2008 11:31 am
Any chance of making this available as a .zip file? I have problems with files with .rar extensions.
watkins
Postby pilou » Mon Sep 29, 2008 11:33 am
Funny :thumb: :enlight: :fro:
Done ;)
Speedy Galerie
User avatar
Top SketchUcator
Postby wikii » Mon Sep 29, 2008 1:38 pm
plot-paris wrote:and I have a suggestion for a future update:
Try to select one curve , one face and one construction point , then , using FAR. The construction point will be treated as the center of the face.
wikii
PluginStore Author
PluginStore Author
Postby plot-paris » Mon Sep 29, 2008 2:11 pm
weird. it only works for me, if I have a curve as a path. it doesn't work with a straight line like in your example (not even the dialog box for rotation/scale input appears)...
but arround a curve it looks really cool! :D
User avatar
plot-paris
Postby marcosrodrigues » Mon Sep 29, 2008 2:46 pm
Seems very promising, Wikii. Thank you.
| menos é mais
marcosrodrigues
Postby pilou » Mon Sep 29, 2008 2:53 pm
Your are not alone :)
And yet some erratic Works for 2 straight lines welded, sometimes yes, sometime no
Speedy Galerie
User avatar
Top SketchUcator
Postby Dave R » Mon Sep 29, 2008 3:54 pm
Interesting plugin but this is what I get.
User avatar
Global Moderator
Postby wikii » Mon Sep 29, 2008 4:21 pm
Dave R wrote:Interesting plugin but this is what I get.
select a face without it's border
wikii
PluginStore Author
PluginStore Author
Postby Dave R » Mon Sep 29, 2008 4:29 pm
thank you. that works.
User avatar
Global Moderator
Postby watkins » Mon Sep 29, 2008 5:18 pm
Dear Pilou,
Thanks for posting the .zip file.
Regards,
Bob
watkins
Postby free agent » Mon Sep 29, 2008 6:44 pm
hey wow awsome plugin, thanx for posting, is there any way to reverse the triangulation of the faces, i noticed that once smoothed the and as you rotate the form it gets very jaggy at the edges and you have to go in there with the flip edge tool to smooth it out... any way around this within the coding?
User avatar
free agent
Postby juju » Mon Sep 29, 2008 7:51 pm
We have some very gifted people here, only surpassed by their generosity. Thank you (all the ruby programmers, both free and commercial) so much for SU so much than it was.
User avatar
juju
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Next
Return to Plugins
cron
Who is online
Users browsing this forum: beatriz_m, Builder54, karolinesouza , lozanogerardo779 and 12 guests
Visit our sponsors:
