Multiple offset.
Got an idea to improve SketchUp?
Multiple offset.
Postby remus » Wed Aug 06, 2008 8:21 am
Itd be really useful if the offset tool could handle multiple faces at once. i.e. you select 2 faces then SU offsets both as if you had done each one separately.
remus
Re: Multiple offset.
Postby plot-paris » Wed Aug 06, 2008 12:13 pm
would be sleak indeed!(the same for push/pull as well).
and in addition to that the array function would speed up things considerably...
the workflow would look something like this then:
User avatar
plot-paris
Postby remus » Wed Aug 06, 2008 12:38 pm
Spot on mock up jakob :thumb: exactly what i was thinking of.
remus
Postby drewpoeppel » Wed Aug 06, 2008 4:25 pm
Indeed, would be nice. I'm not code savy but you'd think it wouldn't be that hard to implement.
drewpoeppel
Postby juju » Wed Aug 06, 2008 4:33 pm
Make a component and replace other faces with same. Whatever you do to one will show on the others. You can always explode again later if you wish.
User avatar
juju
Premium Member
Premium Member
Postby plot-paris » Wed Aug 06, 2008 5:19 pm
but that only works if the faces are all the same shape; and you have to create components first, which is another step in the workflow.
we want this function all the time - simply an enhancement of the offset (and push/pull) tool's functionality...
User avatar
plot-paris
Postby juju » Wed Aug 06, 2008 5:34 pm
O I C
User avatar
juju
Premium Member
Premium Member
Postby Gaieus » Thu Aug 07, 2008 10:27 am
Must be doable by ruby since the bevel plugin also offsets all the faces.
User avatar
Postby plot-paris » Thu Aug 07, 2008 1:21 pm
...and "normal push/pull" is basically what I asked for the push/pull tool to do
User avatar
plot-paris
Postby fredo6 » Thu Aug 07, 2008 9:53 pm
remus wrote:Itd be really useful if the offset tool could handle multiple faces at once. i.e. you select 2 faces then SU offsets both as if you had done each one separately.
Interesting ideas, in particular the multiple offset option (like the rings I use for Shape On Surface). Unfortunately, the OffsetOnSurface does it only on faces that are not connected (if they are, it will consider them as part of the same surface). However JPP, using the option Normal Push Pull does it on multiple face selection, whether connected or not.
Of course, very easy to do in Ruby, especially if this is only for individual faces.
User avatar
PluginStore Author
PluginStore Author
Postby eidam655 » Mon Oct 01, 2018 1:32 am
bump :D does a similar plugin exist already? or am i just bad at googling? :)
I'm using SketchUp 2015, V-Ray 2.
User avatar
eidam655
Postby Dave R » Mon Oct 01, 2018 2:32 am
eidam655 wrote:bump :D does a similar plugin exist already? or am i just bad at googling? :)
Did you try searching here for 'multiple offset'? When I did I got this which installs very nicely with the SketchUcation Extension Store tool.
Click on the picture.
User avatar
Global Moderator
Postby pilou » Mon Oct 01, 2018 10:57 am
Yes SDmitch plugin rules! It's me who have ask to him to make this sort of detailed thing! ;)
Use also with it the special "PushPull" (gives me some minute to refind it! :)
Ok It was Step Extrude! ;)
Speedy Galerie
User avatar
Top SketchUcator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Feature Requests
Who is online
Users browsing this forum: No registered users and 5 guests
Visit our sponsors:
