[Plugin] Tools On Surface - v2.3a - 06 Oct 17
Re: [Plugin] Tools On Surface - v1.3 (more shapes, inference)
Postby CadFather » Sun Jul 20, 2008 11:05 am
large toolbars use 24 pixel icons, small 16 pixels.
but TOS does not load them automatically, so if you want small toolbars put the 16 in the folder - if large the 24
a quick way is to zip both set of icons in the TOS folder - when you want to change them just "unzip here" and overwrite all files (i use winrar).
Quarr-IT - SketchUp Training from the Master.. http://quarr-it.com/
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby pilou » Sun Jul 20, 2008 1:10 pm
Ok all is clear now, I full understand my problem :thumb:
Speedy Galerie
User avatar
Top SketchUcator
Postby fredo6 » Wed Jul 23, 2008 6:07 pm
CadFather wrote:large toolbars use 24 pixel icons, small 16 pixels.
CadFather,
First of all, thanks for your hard and impressive work on the icons and cursors. I am glad to see that this is appreciated by users.
The TOS script actually makes provision of big and small icons. The naming convention is to append '_24' or '_16' to the icon filename for big and small icons, respectively.
It is only because I am lazy that I did publish only one set (and in 32x32 by the way).
The attached archive contains your two sets of icons and cursors merged into one set, with the proper naming convention. All .png files should just be extracted and dropped in the folder TOS_Dir_13
Again, thanks very much
User avatar
PluginStore Author
PluginStore Author
Postby CadFather » Wed Jul 23, 2008 6:38 pm
Master Fredo... Thanks and hats off - :fro:
works just like sketchup 8 - if only i was half as lazy as you! :D
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby pilou » Wed Jul 23, 2008 10:20 pm
Some more easy and confortable now :fro:
Speedy Galerie
User avatar
Top SketchUcator
Postby CadFather » Thu Jul 24, 2008 8:34 am
Hi Fredo, i don't think this same 16/24 system applies to bezier as well - had a look at the scripts but cannot locate/attempt how to make the switch automatic..any pointers would be great..
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby fixzigma » Thu Jul 24, 2008 9:59 am
:berserk: Thankss
fixzigma
Postby fredo6 » Thu Jul 24, 2008 10:07 am
CadFather wrote:Hi Fredo, i don't think this same 16/24 system applies to bezier as well - had a look at the scripts but cannot locate/attempt how to make the switch automatic..any pointers would be great..
No, Bezierspline is an old script now, but I plan to refresh it at some point in time.
This being said, it would be relatively simple to make just the modification about icons. Let me think about it.
User avatar
PluginStore Author
PluginStore Author
Postby CadFather » Thu Jul 24, 2008 1:01 pm
..it would be great to have _16, _24 naming convention like TOS - but all in your own time of course ;)
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby fredo6 » Fri Jul 25, 2008 10:56 am
CadFather,
For easier access to your set of icons and cursors, I edited the first message of this thread and attached the archive file.
http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11212&st=0&sk=t&sd=a#p76625
Fred
User avatar
PluginStore Author
PluginStore Author
Postby FkY » Fri Jul 25, 2008 1:31 pm
Hello all, it's my first message here...
Thanks to Fredo6 for this awesome plugin, it's very useful.
I've just seen a little bug in the arc display. When you move an arc created with this plugin, the center point (displayed by a cross) doesn't move.
It would be nice to have the tangent constraint when you create an arc after an other or a line to have a continuity.
FkY_
PS : sorry for my "garbage english", I do my best but...
FkY
Postby fredo6 » Fri Jul 25, 2008 3:35 pm
FkY wrote:I've just seen a little bug in the arc display. When you move an arc created with this plugin, the center point (displayed by a cross) doesn't move.
Not really a bug actually. the script just create a construction point for the arc center for convenience (as it should maybe in native Sketchup!). But the construction point is not really part of the arc and does not keep any connection with it afterward.
FkY wrote:It would be nice to have the tangent constraint when you create an arc after an other or a line to have a continuity.
Yes, that would be nice. On a Surface, it is however a little bit tricky, though probably feasible.
User avatar
PluginStore Author
PluginStore Author
Postby CadFather » Fri Jul 25, 2008 3:48 pm
Fredo6 wrote:CadFather,
Fred
oh..i'm honoured to have my name next to it! :D
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby zhuangsuph » Tue Aug 05, 2008 6:26 am
Thank youThank youThank you
zhuangsuph
Postby theolwakachangchang » Tue Aug 12, 2008 11:07 am
for some reason i cannot get the toolbar to show up???
i only get this:
theolwakachangchang
Postby CadFather » Tue Aug 12, 2008 4:29 pm
make sure you have al the files in 'plugins'
ZLoader__OnSurface.rb
and the folder TOS_Dir_13 which contains the scripts and the toolbar icons
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby Frederik » Tue Aug 12, 2008 8:54 pm
Isn't this because the script needs to be activated from the Extensions..?? :?
From the menu-bar click Window > Preferences, which will open the System Preferences window...
Select Extensions and make sure the Tools on Surface is ticked... ;)
Now you shold be able to see the toolbar - that is if you've extracted the zip-file to the correct folder... ;)
Cheers
Kim Frederik
User avatar
Frederik
Thea Render Support
Thea Render Support
Postby CadFather » Tue Aug 12, 2008 10:21 pm
oh yes indeed that is the first thing :P
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby theolwakachangchang » Wed Aug 13, 2008 4:38 am
I believe I have all the necessary files. I have the ZLoader__OnSurface.rb and then in the TOS_Dir_13 folder I have 73 *.png files, 9 *.rb files, 1 *.def file and 2 manuals.... I have activated the script from extensions. I get all the options from the Tools on Surface section in the Tools pulldown, its just a pain not having a toolbar
Pretty sure I have installed and followed all the instructions correctly?
theolwakachangchang
Postby fredo6 » Wed Aug 13, 2008 9:12 am
By chance, can you check in the menu View>Toolbar if you have a toolbar named "Surface Operations" and if it is checked.
User avatar
PluginStore Author
PluginStore Author
Postby theolwakachangchang » Wed Aug 13, 2008 9:32 am
Yep, I have that checked.. that little 'dash thing' that shows up (as shown earlier in the image with the arrow) is what shows up when I have 'Surface Operations' checked
theolwakachangchang
Postby CadFather » Wed Aug 13, 2008 3:16 pm
in these cases i move all the plugins to another folder and keep only the troubling one.
give it a try if you still have a problem, redownload the plugin and re-try. if still no good you can try re-installing SU - wouldn't kow what else..
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby theolwakachangchang » Thu Aug 14, 2008 5:41 am
:lol: :lol:
hmmmm turns out I found the problem... For some reason I had extracted the files into the tools directory instead of the plugins directory
theolwakachangchang
Postby CadFather » Thu Aug 14, 2008 9:57 am
:roll: ;)
User avatar
CadFather
PluginStore Author
PluginStore Author
Postby renyiandhan » Mon Sep 01, 2008 11:13 am
Amazing!!! Thanks!!! :berserk:
renyiandhan
Postby agrazdi » Mon Sep 01, 2008 1:32 pm
Any news about the double line you mentioned for V1.4 ?
agrazdi
agrazdi
Postby fredo6 » Mon Sep 01, 2008 7:50 pm
This will come, but not before end of Sep (actually, it should do more than double, and on any contour). I did not spend a lot of time recently on Rubys, but should try to resume soon, with some work on Web dialogs as well.
I also solved the question of generating faces when drawing lines on surfaces.
User avatar
PluginStore Author
PluginStore Author
Postby BorgMan » Tue Sep 02, 2008 4:23 pm
Well that's strange, I'm using the tool right now to offset from a shape on a curved face. However, for some reason it thinks that the object is part of the face too, and thus is offsetting over that face. That's (obviously) not what I want...
More varied than the Borg, more powerful than the living dead, and better shots than Imperial Stormtroopers.
You've gotta love Slivers.
BorgMan
Postby fredo6 » Wed Sep 03, 2008 7:47 pm
Not sure I understand the problem.
Just in case, there is an option 'Isolate surface when extending' which is mapped on F7 and also available in the contextual menu. This allows ignoring the surrounding surface when you offset.
User avatar
PluginStore Author
PluginStore Author
Postby BorgMan » Wed Sep 03, 2008 9:14 pm
Thanks Fredo; I'll try that next.
I'm getting this error too. Is there anything I forgot to extract?
Error Loading File LibOnSurface.rb
uninitialized constant SUToolsOnSurface::TOS_DIRError Loading File LoaderOnSurface.rb
No such file to load -- /LibTraductor_20.rbError Loading File ShapeOnSurface.rb
uninitialized constant SUToolsOnSurface::CODE_Rectangle
[EDIT] Hmmm... didn't work. The problem is that in the last screenshot, you can see a blue line that comes through the object (default color). That's the face I want to offset. When I do so, it thinks that that object is the same as the cilinder on which I am trying to offset. This results in a few lines on the cilinder (the grey area), but then all of a sudden the lines makes a strange turn, goes over the object (the default color thing), and when it touches the grey area again, it goes back to the beginning. I want that blue lined face to extrude, not anything else :|
BorgMan
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
cron
Who is online
Users browsing this forum: No registered users and 10 guests
Visit our sponsors:
