Simple bathroom.
Well, I have knocked the lights back to 70% of nominal value. I have left the original light sources as fake emitters.
I have found that the result is brighter and takes up to half the render time so these ies things are worth sticking with.
The only problem I still have is a format of classification so I can properly choose which files to go with.
This is TwiLight Render you are using?
If you Right Click your light and choose set target what way is it facing?
I have Twilight, yes. I did check orientation too but still the bounce on the ceiling. The light in particular has an odd shape to the light component which is going to change when I go to the next test to have a more consistent orientation.
Oh yes! Far better!
Really looking good!
Like seeing the changes and progress
Thanks folks, onwards.
OK, I was going to stop but I left this while I fed and communed with T' Badgers. I just changed the ies lights physical shape which lends a little depth to the ceiling. Honest guv'.......
Far, far better!
Looking good!
What a cute render.
My taste is slightly brighter and more grayish.
Thanks folks, I am trying to rebuild my parts and texture collections. These two sites are brilliant. Something I have found useful is fbx files, a way to get 3ds.max files into Sketchup via Blender OR the universal import plugin found here on Sketchucation. https://sketchucation.com/forums/viewtopic.php?f=323&t=71951&hilit=universal+importer or in the store.
