by Mike Amos » Thu Sep 22, 2022 10:00 pm
A mix of natural and artificial lighting but not much by way of complication.
- Premium Member
- Name: Mike Amos
- Operating system: Windows
- SketchUp version: 2019
- License type: Pro
- SketchUp use: hobby
- Level of SketchUp: Intermediate
by ntxdave » Fri Sep 23, 2022 12:03 am
Looks like a good room but is a little dark for mr (at least on my iPad). Seems to me that a bath room would be pretty bright.
ntxdave
- Name: Dave Cahall
- License type: Pro
- SketchUp use: other
by Mike Amos » Fri Sep 23, 2022 2:22 am
Ta mate, it comes out pretty brightly on my monitor as per but white balance etc to do again.
I feel like I am doing a certain amount of this from scratch.
- Premium Member
- Name: Mike Amos
- License type: Pro
by Mike Amos » Fri Sep 23, 2022 4:54 pm
I ran a simple hdri background to see what would come out, have to laugh. Some days, we are indeed, the Pigeon.
I tried increasing the articial lights while reducing the hdri to 50% to sharpen the background, keep it crisp rather than washed out. I increased the exposure too but for some reason not sufficiently. How much is enough?
- Premium Member
- Name: Mike Amos
- License type: Pro
by Rich O Brien » Fri Sep 23, 2022 5:14 pm
What are the properties of the lights? Are they emissive materials?
It's all gone very yellow on my screen.
Have you tried a clay render with just HDRI to see how that lights space? All those highly reflective objects are raising your render times when all you need is some lighting tests.
If that little window is the only path for environmental light to enter the scene then that is also time consuming.
As for your HDRI what file format is it?
Rich O Brien
- Administrator
- SketchUp version: 2022
- License type: Pro
- SketchUp use: engineering and mechanical design
- Level of SketchUp: Advanced
by Mike Amos » Fri Sep 23, 2022 7:49 pm
The hdri is fine, my mistake was to lower the value too far, I wanted a realistic looking backplate rather than washed out. I also ran the lights too bright which is where the orange hue came from.
My issue has been that to get the lighter renders classified as 'architectural' they need to be brighter than I really like. Part of this comes from the monitor settings, we all have different settings so renders can be inconsistent in appearance.
There is an indented balcony behind the jacuzzi as well as the window 'light' on the right hand wall.
The reflective surface on the left (The mirror) is the only large/excessive surface reflector imho, the lights and hdri level were my big errors. Back to experimenting to get a better hdri/backplate balance.
- Premium Member
- Name: Mike Amos
- License type: Pro
by Rich O Brien » Fri Sep 23, 2022 8:05 pm
Are your lights emissive planes or actual lights?
Rich O Brien
- Administrator
- License type: Pro
by Mike Amos » Fri Sep 23, 2022 9:57 pm
They are emissive, I have adjusted the colour of the lights and the orange is gone. The rest will take some figuring out.
- Premium Member
- Name: Mike Amos
- License type: Pro
by Rich O Brien » Fri Sep 23, 2022 10:20 pm
Mesh lights by nature are hard to get right because they don't behave like a bulb. Try an IES light if your render app supports it. https://ieslibrary.com/en/browseLess messing around with values and much richer and accurate lighting. Still use emission but only to fake a glow effect not to flood space with light.
Rich O Brien
- Administrator
- License type: Pro
by Bryan K » Fri Sep 23, 2022 11:51 pm
Nice design and render! Once you sort out the light color, it will be perfect!
- Premium Member
- Name: Bryan K
- SketchUp version: 2017
- License type: Free/Make
- SketchUp use: product design
by Mike Amos » Fri Sep 23, 2022 11:58 pm
Thanks folks, Rich I'll give the ies a go. I had tons of them at one time, guess I'll just have to rebuild the collection.
I altered the light/emissive colour which reduced the reflection. To get the lighter render popular I need to push up exposure which leaves a little 'misty' overtone' I am not fond of.
It does keep me off the streets etc and it's a bit parky out there now.
- Premium Member
- Name: Mike Amos
- License type: Pro
by Bryan K » Sat Sep 24, 2022 12:15 am
Oh there you go! Just a suggestion, but I would I would increase the camera exposure just a bit. Color looks good on this one!
- Premium Member
- Name: Bryan K
by Mike Amos » Sat Sep 24, 2022 1:00 am
Thanks Bryan, standard exposure on Twiglet render is 1:00 and I have already pushed this to 6:00. Looking to the ies shot later today.
- Premium Member
- Name: Mike Amos
- License type: Pro
by ntxdave » Sat Sep 24, 2022 2:30 am
Bryan K wrote:Oh there you go!  …..Color looks good on this one!
Agree completely.
ntxdave
- Name: Dave Cahall
- License type: Pro
by Bryan K » Sat Sep 24, 2022 6:40 am
Mike Amos wrote:Thanks Bryan, standard exposure on Twiglet render is 1:00 and I have already pushed this to 6:00. Looking to the ies shot later today.
Oh wow. I see.
- Premium Member
- Name: Bryan K
by Mike Amos » Sat Sep 24, 2022 1:29 pm
Thanks folks, moving onwards as we all do.
- Premium Member
- Name: Mike Amos
- License type: Pro
by Mike Amos » Sat Sep 24, 2022 6:38 pm
Well, as they said on Ground Force, day one. I used an ies ligit and had to put my welding goggles on to enter the living room.
Much more than meets the mark one's with this here ies lark but I will let you know how I get on folks.
- Premium Member
- Name: Mike Amos
- License type: Pro
by Mike Amos » Sat Sep 24, 2022 8:02 pm
Well, I have knocked the lights back to 70% of nominal value. I have left the original light sources as fake emitters.
I have found that the result is brighter and takes up to half the render time so these ies things are worth sticking with.
The only problem I still have is a format of classification so I can properly choose which files to go with.
- Premium Member
- Name: Mike Amos
- License type: Pro
by Rich O Brien » Sat Sep 24, 2022 8:40 pm
This is TwiLight Render you are using? If you Right Click your light and choose set target what way is it facing?
Rich O Brien
- Administrator
- License type: Pro
by Mike Amos » Sat Sep 24, 2022 9:18 pm
I have Twilight, yes. I did check orientation too but still the bounce on the ceiling. The light in particular has an odd shape to the light component which is going to change when I go to the next test to have a more consistent orientation.
- Premium Member
- Name: Mike Amos
- License type: Pro
by Bryan K » Sat Sep 24, 2022 11:05 pm
Oh yes! Far better!  Really looking good!
- Premium Member
- Name: Bryan K
by ntxdave » Sat Sep 24, 2022 11:45 pm
Bryan K wrote:Oh yes! Far better!  Really looking good!
Agree
ntxdave
- Name: Dave Cahall
- License type: Pro
by tuna1957 » Sun Sep 25, 2022 1:00 am
Like seeing the changes and progress
tuna1957
- Premium Member
- Name: Charles Treon
- Operating system: Mac
- SketchUp version: 2015
- License type: Pro
- Level of SketchUp: Beginner
by Mike Amos » Sun Sep 25, 2022 1:14 am
Thanks folks, onwards.
- Premium Member
- Name: Mike Amos
- License type: Pro
by Mike Amos » Sun Sep 25, 2022 2:31 am
OK, I was going to stop but I left this while I fed and communed with T' Badgers. I just changed the ies lights physical shape which lends a little depth to the ceiling. Honest guv'.......
- Premium Member
- Name: Mike Amos
- License type: Pro
by Bryan K » Sun Sep 25, 2022 9:19 pm
Far, far better! Looking good!
- Premium Member
- Name: Bryan K
by majid » Mon Sep 26, 2022 11:24 am
What a cute render. My taste is slightly brighter and more grayish.
majid
- Top SketchUcator
- Name: Majid
- SketchUp version: pre-2013
- SketchUp use: architecture
by ntxdave » Mon Sep 26, 2022 2:24 pm
ntxdave
- Name: Dave Cahall
- License type: Pro
by Mike Amos » Wed Sep 28, 2022 9:57 am
Thanks folks, I am trying to rebuild my parts and texture collections. These two sites are brilliant. Something I have found useful is fbx files, a way to get 3ds.max files into Sketchup via Blender OR the universal import plugin found here on Sketchucation. viewtopic.php?f=323&t=71951&hilit=universal+importer or in the store. https://3dsky.org/https://cgmood.com/
- Premium Member
- Name: Mike Amos
- License type: Pro
by Ad Machine » 5 minutes ago
Ad Machine
- Robot
Return to Gallery
