Group by Layer
Group by Layer
Postby JQL » Thu Aug 11, 2022 2:54 pm
Hi there,
I haven't posted regularly here for a long time, but I've started following the forum again and I will try posting more again.
I think I have used a plugin in the past that would group objects by layer but I might be imagining things. Has anyone got any idea if such a plugin exists?
Thanks in advance!
User avatar
JQL
Premium Member
Premium Member
Re: Group by Layer
Postby Box » Thu Aug 11, 2022 3:07 pm
What is this strange thing you refer to, Layer, never head of it.
User avatar
Re: Group by Layer
Postby Rich O Brien » Thu Aug 11, 2022 3:15 pm
If you right click the tag/layer in tag/layer panel and choose...
...then group that selection
User avatar
Rich O Brien
Administrator
Re: Group by Layer
Postby Rich O Brien » Thu Aug 11, 2022 3:16 pm
Box wrote:What is this strange thing you refer to, Layer, never head of it.
Just locking his poor spelling before he edits :P
User avatar
Rich O Brien
Administrator
Re: Group by Layer
Postby JQL » Thu Aug 11, 2022 3:26 pm
My head always heads layers but I head it's tags now, you head right!
Thanks Box! :D
So Group by Tag anyone?
User avatar
JQL
Premium Member
Premium Member
Re: Group by Layer
Postby Box » Thu Aug 11, 2022 3:28 pm
Bloody autocorrect.
User avatar
Re: Group by Layer
Postby Box » Thu Aug 11, 2022 3:30 pm
You write a thousand eloquent posts, do they call you box the eloquent...
You shag one sheep!
User avatar
Re: Group by Layer
Postby Rich O Brien » Thu Aug 11, 2022 3:33 pm
JQL wrote:So Group by Tag anyone?
What's wrong with the vanilla approach?
Box wrote:You shag one sheep!
They call you Kiwi
Reason: Edited without reason on 11/08/2022
User avatar
Rich O Brien
Administrator
Re: Group by Layer
Postby JQL » Thu Aug 11, 2022 3:34 pm
Rich O Brien wrote:If you right click the tag/layer in tag/layer panel and choose...
That's pretty cool, I was using selection toys.
However, too many right-clicks, I think I would rather keep things unorganized.
User avatar
JQL
Premium Member
Premium Member
Re: Group by Layer
Postby Rich O Brien » Thu Aug 11, 2022 3:35 pm
I'm pretty sure TIG wrote a snippet for this at one point. I'll try find it
User avatar
Rich O Brien
Administrator
Re: Group by Layer
Postby JQL » Thu Aug 11, 2022 3:37 pm
You're too cool! Thanks!
User avatar
JQL
Premium Member
Premium Member
Re: Group by Layer
Postby Rich O Brien » Thu Aug 11, 2022 3:43 pm
Or set this...
...then click the chevron to expose details...
...then install and test if TIG's description suggests it may do what you need.
User avatar
Rich O Brien
Administrator
Re: Group by Layer
Postby Rich O Brien » Thu Aug 11, 2022 3:48 pm
I knew he posted a snippet once...
viewtopic.php?p=427644#p427644
...fails in 2022 though. Maybe he'll see this thread and chime in.
User avatar
Rich O Brien
Administrator
Re: Group by Layer
Postby JQL » Thu Aug 11, 2022 3:50 pm
I think the objective of that one is to have edges and faces sent to layer0. That is aimed at fixing most errors caused by having raw geometry in that layer.
In my case I really don't want to loose the layer of raw geometry unless it becomes grouped by layer first and the group is given that same layer.
So, what I want to do is exactly what you showed on your image: go through each layer, select objects and group them; if possible change the group from Layer0 into the selected layer; and then I can send all raw geometry into Layer0 as it has already been grouped and the group is in the correct layer.
I'm going to read better what each of those Layer plugins does.
@Box, just replace each of the "layer" above by "tag" and you get the point.
@Rich, I was replying to your previous post. I will see what you posted now.
User avatar
JQL
Premium Member
Premium Member
Re: Group by Layer
Postby JQL » Thu Aug 11, 2022 3:59 pm
Rich O Brien wrote:I knew he posted a snippet once...
The description he has in the snippet post is exactly what I need.
Bummer!
It would be very cool if he would chime in indeed.
User avatar
JQL
Premium Member
Premium Member
Re: Group by Layer
Postby Rich O Brien » Thu Aug 11, 2022 4:57 pm
I was wrong. It does work...
Code: Select all
m=Sketchup.active_model;a=m.active_entities;s=[];m.start_operation("!");a.to_a.each{|e|s<<e if e.layer==m.layers[0]};g=a.add_group(s);g.name=m.layers[0].name;g.layer=nil;(g.entities.each{|i|i.layer=nil})unless s.empty?;m.layers.to_a[1..-1].each{|l|s=[];a.to_a.each{|e|s<<e if e.layer==l};next if s.empty?;g=a.add_group(s);g.name=l.name;g.layer=l;g.entities.each{|i|i.layer=nil};};m.commit_operation;
You need to have a group selected that is on Layer0 it then iterates through the model groups things to layer
User avatar
Rich O Brien
Administrator
Re: Group by Layer
Postby JQL » Thu Aug 11, 2022 5:06 pm
It must be a group? I will try it then. Just paste this in the console, right?
User avatar
JQL
Premium Member
Premium Member
Re: Group by Layer
Postby Rich O Brien » Thu Aug 11, 2022 5:20 pm
It seems so. I'm not 100% on what needs to be selected but it seems to rename the selected group and then do some magic.
Try on sample first
User avatar
Rich O Brien
Administrator
Re: Group by Layer
Postby JQL » Thu Aug 11, 2022 5:59 pm
Too late, I've tried it in the model directly and it's taking a lot of time. I don't know if I should just shut it down, try it in a sample, and then leave it on the whole night. It might finish right now, or it might take a week... who knows?
User avatar
JQL
Premium Member
Premium Member
Re: Group by Layer
Postby JQL » Thu Aug 11, 2022 10:47 pm
So I made a simple model and tested the snippet without selecting anything. It works flawlessly.
I don't think it iterates inside groups. Only tried on loose geometry, but I'm going to try That.
EDIT: What it does seems to be doing is grouping all groups in the model into a new group called Layer0. It doesn't act inside those groups. This is cool and a way to control the scope.
Geometry to be affected by the snippet should be in root of the model.
EDIT2: Groups that are tagged already, get their objects inside grouped and stripped from tags. This happens even if they have no tags. All other groups are grouped together in a group called Layer0
User avatar
JQL
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Extensions & Applications Discussions
Who is online
Users browsing this forum: No registered users and 3 guests
