Flowify problems
Re: Flowify problems
Postby pilou » Sun Sep 20, 2020 8:01 pm
could you please explain in detail why a quad mesh is required?
You can't project something with Flowify on a complete sphere 3D!
But yes if you make a little triming somewhere like that!
You have now a "quad" surface! ;)
User avatar
Top SketchUcator
Postby paritoshaj » Sun Oct 25, 2020 1:35 am
Idk why its not working but its not working, i have finals tomorrow need to do roof trusses please help
paritoshaj
Postby cotty » Sun Oct 25, 2020 4:17 pm
paritoshaj wrote:Idk why its not working but its not working, i have finals tomorrow need to do roof trusses please help
After exploding the pyramids in the source geometry group, it's working...
User avatar
cotty
Top SketchUcator
Postby arkiduckling » Sat Nov 28, 2020 5:46 am
hi I have an issue also with flowify, it is not working and I dont know if it is because of my mistakes or plugin's issue because when i checked my extension manager, there's a text in the flowify says UNSIGNED. May I know what does it mean and if that was the reason why i couldnt work with flowify :))) thank you
arkiduckling
Postby cotty » Sun Dec 06, 2020 4:29 pm
It's not the reason ;-)
you can upload the model and we will have a look at it...
User avatar
cotty
Top SketchUcator
Postby Dave R » Sun Dec 06, 2020 4:52 pm
arkiduckling wrote:...there's a text in the flowify says UNSIGNED.
Signed or unsigned has no bearing on the functionality of the extension.
As Cotty, suggests, share your .skp file so we can see what you are working with and what steps you need to take to sort it out.
User avatar
Global Moderator
Postby ravindulk94 » Sat Sep 18, 2021 8:35 am
optimaforever wrote:I have a strange behaviour too...
The flowify command generates a huge model, with an array of sectional faces.
First the source material: Group 1 composed of A target surface / B source surface / C projection vectors and D the source mesh (exploded)
The resulting groups from the flowify command
I succeeded all the other meshes with the same method but here I've got a bug...
flowify bug.skp
did you find any solution for this error?
ravindulk94
Postby Dave R » Sat Sep 18, 2021 11:49 pm
ravindulk94 wrote:did you find any solution for this error?
What version of SketchUp are you using? Your profile says 2021 Free/Make which is impossible.
User avatar
Global Moderator
Postby MrKrabs » Sat Oct 23, 2021 6:16 pm
can someone help me out with flowify? I can´t get it to work properly
MrKrabs
Postby cotty » Sat Oct 23, 2021 7:55 pm
MrKrabs wrote:can someone help me out with flowify? I can´t get it to work properly
From the instructions...
Your target surface isn't suitable.
User avatar
cotty
Top SketchUcator
Postby MrKrabs » Sat Oct 23, 2021 8:28 pm
is there any way to make it suitable?
MrKrabs
Postby francesgale » Fri May 13, 2022 2:32 pm
hello, first time using flowify, any idea what i should do with this error?
francesgale
Postby SMatta79 » Tue May 17, 2022 11:12 pm
Hello, is there anyone available to help me fix a problem w Floify? I set up the groups correctly 1 main group w the 3 groups inside. when I hit impose grid the grid doesn't appear.
SMatta79
Premium Member
Premium Member
Postby pilou » Tue May 17, 2022 11:40 pm
I can help you if files are in format skp 6 to 2017 :)
User avatar
Top SketchUcator
Postby SMatta79 » Wed May 18, 2022 5:56 am
pilou wrote:I can help you if files are in format skp 6 to 2017 :)
Hi Pilou, No unfortunately mine is a 2022 version :( How else can we do this?
SMatta79
Premium Member
Premium Member
Postby pilou » Wed May 18, 2022 9:11 am
I suppose that you have choice when you make an exportation...(save as)
User avatar
Top SketchUcator
Postby Rich O Brien » Wed May 18, 2022 10:50 am
Meanwhile back in 2022... :-P
The Error message Flowify is outputting is telling you the problem. Your source and destination should share some level of topological similarities.
User avatar
Rich O Brien
Administrator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Extensions & Applications Discussions
Who is online
Users browsing this forum: No registered users and 0 guests
