Open plan small.
Open plan small.
Postby Mike Amos » Thu May 12, 2022 12:49 am
Two levels, 18 feet2.
Division of main room by function but big enough for a washing/spin dryer machin under the kitchen worktops. Fridge freezer optimal for kitchen and tv purposes. What use a film or match without some nice amber lubricant? The white blob next to said lubricant storage (Below the stairs) is intended as storage and space for a coffee machine etc.
Premium Member
Premium Member
Re: Open plan small.
Postby Bryan K » Thu May 12, 2022 5:41 am
Cozy!
Good render too!
User avatar
Premium Member
Premium Member
Postby Mike Amos » Thu May 12, 2022 10:49 am
Ta mate, getting there slowly. I think it a bit large for some out there.
Premium Member
Premium Member
Postby Mike Amos » Thu May 12, 2022 11:31 pm
Stupid really, working on the plan of an 18' square plot. I did think a few things were a bit off but put that down to fatigue. 16' square plot is the reality. At least I can get that nagging itch to go away now I know the problems. Face palm moment, I know. :roflmao:
Premium Member
Premium Member
Postby Mike Amos » Sat May 14, 2022 12:52 am
From the garden looking in.There is an issue with the hdri, take a look at the bricks in the wall on the left, the low wall in the garden and the bricks visible through the kitchen window that can be seen through the patio doors on the right.
Premium Member
Premium Member
Postby tuna1957 » Sat May 14, 2022 5:26 am
Hmmm…. Interesting, show us more inside and out. Only comment is I’d bust my A## on those crazy stairs ;)
tuna1957
Premium Member
Premium Member
Postby Bryan K » Sat May 14, 2022 7:54 am
HDRIs are tricky. They often don't scale properly and there is no way to adjust their scale. You might try rotating the HDRI if your renderer has that ability, until you find the right "look".
That's why you often do not see more than one or at most, two, views of my renders outdoors and also why I try to use a lot of open land views. The farther away the background, the better they look.
I also use a trick where I'll build about 100-200ft in every direction, of real 3D model that also blocks the ground views and then use an HDRI.
HDRIs take a lot of faking and fiddling to look right. But it does beat building an entire world. (oh if I only had the power and time to do so, though)
User avatar
Premium Member
Premium Member
Postby Mike Amos » Sat May 14, 2022 12:02 pm
tuna1957 wrote:Hmmm…. Interesting, show us more inside and out. Only comment is I’d bust my A## on those crazy stairs ;)
Ta folks and agreed with bells on. You did of course miss the bungee cord stair assist. Hiving the wardrobe facing the top of those stairs will make changing clothes easier though, if a tad bruising. Those stairs appear in many place like boats and a lot of smaller homes as stairs take away the use of a LOT of footage from a house.
Premium Member
Premium Member
Postby Mike Amos » Mon May 23, 2022 10:09 pm
Moving on a tad, changed the lights a bit which gives a subtle shift of tone.
Premium Member
Premium Member
Postby Bryan K » Tue May 24, 2022 3:06 am
Oh that is nice! Good render and view! Warm and cozy and airy. :thumb:
Can't go wrong with Bill the Cat either. :lol:
User avatar
Premium Member
Premium Member
Postby Mike Amos » Tue May 24, 2022 3:07 am
Thanks Bryan.
Premium Member
Premium Member
Postby tuna1957 » Tue May 24, 2022 5:16 am
I like this last “bird’s eye” view :thumb:
tuna1957
Premium Member
Premium Member
Postby HornOxx » Tue May 24, 2022 6:23 am
tuna1957 wrote:I like this last “bird’s eye” view :thumb:
Yes! :thumb:
even if the rotary dryer(?) which we in D name "Laundry-Spider" :) would be there in real life, I would avoid showing this here useless and too prominent thing in the rendering ;)
Prima otherwise!
never trust a skinny cook
User avatar
HornOxx
Postby Mike Amos » Tue May 24, 2022 11:39 am
Thanks folks, the birds eye view is simply to get a reasonable field of view in. I deliberately did not light the upper level so the ground floor was prominent. I believe a lighter upper floor and stairs would detract from the render.
Premium Member
Premium Member
Postby Mike Amos » Wed May 25, 2022 1:41 am
I added a garden gate and a few other bits and bobs.
Premium Member
Premium Member
Postby tuna1957 » Wed May 25, 2022 4:22 am
Cool ! :thumb:
tuna1957
Premium Member
Premium Member
Postby Mike Amos » Wed May 25, 2022 12:12 pm
Ta mate, I hope not too many additions, Lights might be increase though.
Premium Member
Premium Member
Postby Bryan K » Thu May 26, 2022 5:36 am
Excellent! :thumb:
User avatar
Premium Member
Premium Member
Postby Mike Amos » Thu May 26, 2022 10:21 am
Thanks Bryan, different view lower level.
Premium Member
Premium Member
Postby Bryan K » Fri May 27, 2022 3:08 am
All of these are your best renders to date. Absolutely pro arch viz quality. :thumb:
User avatar
Premium Member
Premium Member
Postby Mike Amos » Fri May 27, 2022 11:39 am
Thanks Bryan.
Premium Member
Premium Member
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to WIP
cron
Who is online
Users browsing this forum: No registered users and 0 guests
