General discussion about Animator for SketchUp
by fredo6 » Thu Mar 31, 2022 9:11 am
Saumil12345 wrote:Is there any hope that you release a new version or a fix to this issue today? I have to take a workshop on animator, but if the plugin is not working, I can't do anything, please reply as soon as possible, so that I can know if I will have to postpone the workshop or we are getting new version soon?
Oooops....! sorry for that. New version Animator v3.7a published with extension of validity.
- Premium Member
- Name: Fredo6
- Operating system: Windows
- License type: Pro
- SketchUp use: interior design
- Level of SketchUp: Intermediate
by duanekemp » Thu Mar 31, 2022 9:23 am
Fredo!!! You are a good man! Thank you. Will download now.
Cheers,
duanekemp
- Name: Duane Kemp
- License type: Pro
- SketchUp use: architecture
- Level of SketchUp: Advanced
by duanekemp » Thu Mar 31, 2022 9:52 am
It works! Thank you Fredo!
duanekemp
- Name: Duane Kemp
- License type: Pro
by Calcifer » Thu Mar 31, 2022 2:02 pm
Thank you Fredo. You're the man!
Calcifer
- Name: Calcifer
- SketchUp version: 2020
- License type: Pro
- SketchUp use: film and stage
by JMGUILLAUME » Wed Apr 20, 2022 3:02 pm
Animator is a very interesting plugin but I do not succeed to record films of the animation.
It seems that FFMpeg does not work correctly.
I obtain numerous images instead of film, and they vanishes when I click record.
Without possibility to record films, animator is less useful.
Is there something to do?
JMGUILLAUME
- Name: JMGUILLAUME
by juju » Wed Apr 20, 2022 7:57 pm
JMGUILLAUME wrote:Animator is a very interesting plugin but I do not succeed to record films of the animation.
If all else fails, and if you're so inclined, you can composite the myriad images into a film using 3rd party software. Far from ideal, I know, but a workaround.
juju
- Premium Member
- Name: Juju
- License type: Pro
by Guest » Wed Apr 20, 2022 8:33 pm
Hi everyone. One question. Do you know what happens if you don't click that 'Save and exit' button once the render is finished? I'm on a black screen with all peripherals dead and the render is running in the background. I'll have to hard-restart PC once render is done and I'm not sure if files will be saved if the button is not clicked. Has anyone did it before or could do a quick try to let me know?
Guest
by duanekemp » Thu Apr 21, 2022 6:06 am
juju wrote:JMGUILLAUME wrote:Animator is a very interesting plugin but I do not succeed to record films of the animation.
Quicktime imports image sequences to make movies... an easy one click process.
duanekemp
- Name: Duane Kemp
- License type: Pro
by Calcifer » Fri Apr 22, 2022 2:38 pm
Guest wrote:Hi everyone. One question. Do you know what happens if you don't click that 'Save and exit' button once the render is finished? I'm on a black screen with all peripherals dead and the render is running in the background. I'll have to hard-restart PC once render is done and I'm not sure if files will be saved if the button is not clicked. Has anyone did it before or could do a quick try to let me know?
Hi. I did a quick test. When the render is completed, you have to click save and exit to save your files. The other button though asks you if you really want to erase the exported files. I also started an export and interrupt SU in the middle of the process. You get all the individual images as PNG files until the time the export was interrupted. I actually noticed in the past you can complete your export and already copy all individual images before clicking save and exit. once you do, if you haven't selected exporting as individual images, those images disappear and merge to become one video file. Personnaly, I always export as individual frames on top of everything else. If I have a problem when exporting with VRay (and it happens a lot), I can at least save some time and resume. Hope it helps. Good luck
Calcifer
- Name: Calcifer
- License type: Pro
by fredo6 » Fri Apr 22, 2022 8:40 pm
Just a few precisions.
When you generate, you can choose the video format (MP4, MOV, GIF, etc...) but also Images Sequence.
When you select 'Save and Exit', the frame image files will be deleted unless you chose 'Images Sequence'.
- Premium Member
- Name: Fredo6
- License type: Pro
by Calcifer » Tue May 03, 2022 10:27 pm
Hello Fredo,
I have few questions and observations regarding rendering an animation with VRay through animator. I am currently working on a quite large scale project so I did some VRay rendering tests with simplified files for now and noticed few things: - it appears that rendering doesn’t work when Safe Frame is enabled in VRay. - when I export a single frame directly in SU with VRay (not using animator), it takes on my computer about 2 minutes to export an image with the GPU, 6 minutes with the CPU. Hence I always enable the GPU option. However, when I exported my animation, each frame took about 6 to 8 minutes to render. Does Animator/VRay only use the CPU and overrides the VRay Set ups? Note that it rendered all the render elements perfectly and separately. - The animation is 5 seconds long (at 24 fps) and after 24 or 25 frames, the animation kept freezing. The rendering time counter still goes up. I left it one night running and it was still on the same frame in the morning. It worked well when I rendered each second individually (so in 5 batches). Is there a limitation with memory or something? If so, is there a way to know before exporting? - Which leads me to wondering if it would be possible to have options in how time is displayed. Right now it’s only in second with one decimal. Could it be displayed in frames? (When chosing which part of the animation I want to render) - For my final project, full resolution, a frame takes with my current computer 30 to 40 minutes to render with GPU so I guess it would take about 2 hours with CPU. I am far from being at the stage when I render a final animation but I am concerned I’ll never be able to render without using a render farm (I suspect IaaS would be the only option to use animator). I don’t know much about rendering farms but they seem to be either CPU or GPU. If my assumption that animator only uses CPU, I should go for that? - based on my research, it doesn’t seem possible to use VRay cloud to render with animator. Did I miss something? - last but not least, I was wondering if there could be an option to export each frame as a unique SU file? Not that I would want that as it would require a big hard disk drive and export hundreds or thousands of SU files, but I thought it could be an alternative and make the use of VRay cloud possible.
I hope my message isn’t too long. Thank you in advance.
Calcifer
- Name: Calcifer
- License type: Pro
by fredo6 » Wed May 04, 2022 6:46 am
What you describe is probably beyond the approach possible with Animator, VRay and Sketchup. if you need 120 frames (5 seconds at 24fps), each rendering in 30-40 minutes, then it is likely that either Animator, Sketchup or VRay will have problem.
I don't have a solution at the moment, sorry. Generating 120 skp model files (or 120 scenes) is a possibility, but that does not give a satisfactory solution because it does not scale up. And this is not easy to implement anyway.
- Premium Member
- Name: Fredo6
- License type: Pro
by Calcifer » Wed May 04, 2022 3:20 pm
Hello Fredo, Thank you for your quick response. I was afraid it would be your answer. That been said I may find a convoluted way to work around the animator and SU limitations.
I have a last question: if I would like to improve my hardware to use animator (just for opening animator and use it), should I focus more on CPU or GPU?
Calcifer
- Name: Calcifer
- License type: Pro
by fredo6 » Wed May 04, 2022 9:47 pm
Calcifer wrote:I have a last question: if I would like to improve my hardware to use animator (just for opening animator and use it), should I focus more on CPU or GPU?
I personally do not know. This is anyway related to the rendering software not to Animator. So I would suggest you ask Chaos Group (or check their forum, where I am sure there would be plenty of good advice)
- Premium Member
- Name: Fredo6
- License type: Pro
by Ad Machine » 5 minutes ago
Ad Machine
- Robot
Return to Animator Beta
