you could use the summary to display the data as the "component info" section is not affected.
I suggest you consider using some ruby scripts with your DCs to help with placement, multiple changes....
New to DC: topic for my simple questions to the pros
• Page 3 of 3 • 1, 2, 3
Re: New to DC: topic for my simple questions to the prosHi all!
Sorry to ask for help again: I'm trying to figure out the simplest way to round a result of a formula to the closest upper value of a list with non constant intervals (e.g. 20,70,180,500) Do you have any hints for me? Thanks in advance as usual! WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
Re: New to DC: topic for my simple questions to the prosnearest
then test if input > nearest if so find the next value example 1: use a string of values and string functions to get the next Re: New to DC: topic for my simple questions to the prosI was almost there
![]() WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
Re: New to DC: topic for my simple questions to the prosHi! is there a way to select all locked components? a plugin or a one-line snippet maybe?
Thanks in advance! WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
Re: New to DC: topic for my simple questions to the prosHi again! I have a new question for Phil
![]() I have a formula which returns a text string which may contain LUCIDO, SEMILUCIDO or OPACO. I want another attribute to substitute in that exact string the words LUCIDO, SEMILUCIDO or OPACO with GL100, GL60 or GL25 respectively. Is there a way to do that? Thanks in advance! WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
Re: New to DC: topic for my simple questions to the prosHi Filippo
can use nested SUBSTITUTE order is important example attached Re: New to DC: topic for my simple questions to the prosSo cool! Thanks a lot, I couldn't have made it by myself.
Re: New to DC: topic for my simple questions to the prosHi again! This is slightly OffTopic but it seems I can't find out a plugin I once saw.
Say we have a DC ("wall") in a model, then we copy it 2 more times and make 3 variations in total, which will be called "wall", "wall#1" and "wall#2". Say we later delete the wall#1 instance, so we have "wall" and "wall#2". This plugin checks the numbered instances of "wall", and renames the "wall#2" instance to "wall#1" (since "wall#1" is available again after the deletion). Con any of you guys recall what was the name of this plugin? Thanks in advance! WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
Re: New to DC: topic for my simple questions to the prosEneroth Decrease Component Number on extension warehouse
Re: New to DC: topic for my simple questions to the prosWonderful!!! THANKS Phil!
Re: New to DC: topic for my simple questions to the prosHi again! Happy new year!
I have the need to bulk export the thumbnails of the selected components, I fiddled around in the forums and I discovered this small but effective Ruby code: mod = Sketchup.active_model # Open model sel = mod.selection # Current selection path = mod.path #current path mypath= File.join(File.dirname(path),'/') #not the model name sel.each do |sel| # you would have to select all components in the model compname = sel.name # each component's definition name thumbnailname = File.join(mypath, compname + '.jpg') # as jpg sel.definition.save_thumbnail thumbnailname end The only issue is that this plugin doesn't work if i have the character "|" in the component instance name. Is there a way to allow the character in the "allowed" characters? Thanks in advance! WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
Re: New to DC: topic for my simple questions to the prosHi again! Is there a way, even a small oneliner ruby code, to get a dimension in SKP (Not layout) with NO leaders at all? No lines, only the number.
Who is online
Users browsing this forum: No registered users and 0 guests
