@skuser can you send an email too support@sketchucation.com?
Also check your Spam folder just in case it went there.
I purchased license, but can't Validate it because of Error A04
Error message :
msg_validation_error
Request to Sketchucation = ERROR_A04I've already installed Sketchucation store v4.1.0.
how can I solve it???? -
Thanks Rich, followed your advice but they have not responded, I am desperate to user this plugin and my project is being held up by this. I may need to ask PayPal for a refund.
@skuser you should be sorted now. Check your inbox when you get a chance
how can I solve it????Can you let me know the what plugin you need help with?
oh, I'm trying to validate Fredocorner.
Hello.
Are there other payment methods besides PayPal? -
Not at the moment. Stripe support planned.
Hi, I have a licensing problem with ClothWorks. I had to format the pc without being able to release the license. After the new installation I entered the licenses of the paid plugins and ClothWorks tells me that I am using 3 licenses while in fact I only use 1 license. I don't have other PCs where I use ClothWorks. I need help resetting the licensing situation. Thank you very much
licence problem with fredo corner
Thank you very much. This solved my error also.
I just downloaded Fredo Spline - to try out for 15 day, but it already said that the license has expired in February 2021...
I don't think it says 'the license has expired', but most probably 'the trial period has expired'.
It is likely because you already installed FredSpline sometimes in Februrary. -
I bought a license Fredo Corner and I canβt load it. I have already reinstall my program for a few times.
@helenbzilka said:
I bought a license Fredo Corner and I canβt load it. I have already reinstall my program for a few times.Install latest version of SketchUcation Tools...
https://sketchucation.com/resources/plugin-store-download
If that won't fix issue, erase your signature file and reactivate your license.
C:\Users\[SomeName]\AppData\Local\SCF Licenses
Just like some others here I get the following error message when trying to validate my FredoCorner license.
"msg_validation_error
Request to Sketchucation = ERROR_A04"
I tried to find the soultion in this thread but couldn't find an answer adressing this specific error code
I have Sketchucation extension store v4.1.3 installed and I have tried to delete the SFCLicenseSignature file and reactivate the license. Still get the error message. Can you help me with a solution for ERROR_A04?
Hi, for some reason, a license has ceased to work on
Fredocorner. I hope to help.
Could you do the following
In the Message History panel, click on the button "License File Location". This opens the directory where license files are stored.
Erase the files
- SCFLicenseSignature - DO NOT MODIFY OR DELETE.txt
- SCFLicense_FredoCorner_this_computer.txt
- Redo the Validation procedure.
Sorry for the inconvenience. This may be due to a change of your computer environment.
Thanks, all worked well. Health to you and prosperity.
