[Plugin] ClothWorks v1.7.9 - 18 Apr 2024
@aris said:
Hey guys, I have a problem with the license (you can see in the image)
I don't know who to contact about this
As Fredo pointed out, please update to the latest version of SketchUcationTools. If the problem still persists with activation, try deleting your licensing cache and then activating again as described in ClothWorks licensing manual, Known Issue section, #3: https://antonsynytsia.github.io/manuals/ClothWorks/license_manual_v174.pdf
Hello Anton,
I purchased the license the day before. But I am having some problems validating the license.
Please help.system: OS X 10.11.6
SketchUp: SketchUp 2017 pro
Cloth works: ClothWorks_v1.7.4
SketchUcationTools_v4.1.1I have been trying since yesterday. No any luck.
By the way, I am not able to load the SketchUcation Plugin store in the extension, either.
@hydboxhydbox Your Mac OS is 10.11. Is it possible for you to upgrade to 10.13? I presume that could be conflicting with SketchUcation extension. Alternatively, it could be thata SCF 4.0 is not compatible with SU2017 but he details indicate that it is compatible with SU2017 and later.
Привет. А есть ли иные способы оплатить лицензию, кроме PayPal?
Hi. Are there any other ways to pay for the license besides PayPal?
Hi Anton,
It's sorted.
I updated my system to MacOS 10.13. and tried again. The validating message went through.Maybe there should be some reminder on the download page for those who still using the older macOS system.
Thanks again.
When you purchase, PayPal is not required. You can pay with your credit/debit card directly. As far as additional payment alternatives, that is for SketchUcation to decide upon and integrate. What payment option do you have in mind?
@hydboxhydbox said:
Hi Anton,
It's sorted.
Thanks again.
Interesting case. I will inform SketUcation team about this incompatibility issue. Thank you for your test and patience!
Hi. Yes, I meant a credit / debit card. When I check out, I end up always being redirected to PayPal. How exactly can I pay by card without using PayPal in any form?
Have you seen this option? See attached screenshot.
Yes. I attached a few screenshots.
As a result, payment by card, but through the PayPal service =(
Hi Anton,
It's sorted.
Thanks again.[/quote]
Interesting case. I will inform SketUcation team about this incompatibility issue. Thank you for your test and patience![/quote]NO problem. Thanks for the great extension.
I am now following the menu to give it a try and I got this exposed table edge.
The parameter setting is exactly the same as the ones on the example in the menu.
The parameter setting is exactly the same as the ones on the example in the menu.Try the settings shown here.
Correct the face orientation first, though. Make sure the front faces are up.
Thanks, it fixed it.
Is that because I use Quadrilateral Grid + adaptive remeshing? But that is what is said in the menu. Or in simpler cases, the Quadrilateral Grid will be enough?
I doubt it. At least I don't get the same result you show when I use those settings.
已購買ClothWorks的授權,但始終沒有收到許可信件
[mod=:15j0fr8j]Translated by Google:
I have purchased a license for ClothWorks, but never received a license letter[/mod:15j0fr8j]
已購買ClothWorks 的授權,但始終沒有收到授權信件,
我的收件信箱是hengzuan168@gmail.com,
請看到回覆後,寄授權檔給我,謝謝,
因為已經超過24小時了 -
Hi, I have a licensing problem with ClothWorks. I had to format the pc without being able to release the license. After the new installation I entered the licenses of the paid plugins and ClothWorks tells me that I am using 3 licenses while in fact I only use 1 license. I don't have other PCs where I use ClothWorks. I need help resetting the licensing situation. Thank you very much
請看到回覆後,寄授權檔給我,謝謝,
因為已經超過24小時了Check inbox for email from support@sketchucation.com
The license logs show 3 devices in use with the most recent validation occurring 8 days ago...
請看到回覆後,寄授權檔給我,謝謝,
因為已經超過24小時了
