error: #syntaxerror - plugins/followandrotate_en.rbs?
Postby archmlcm » Tue Sep 28, 2021 5:28 am
Hi Guys,
Just installed sketchup pro 2021. And encounter this error.
Error: #<SyntaxError: c:/users/mark.m/appdata/roaming/sketchup/sketchup 2021/sketchup/plugins/followandrotate_en.rbs:49: invalid multibyte char (UTF-8)
Is this something we need to worry about?
Looking forward for your response and suggestions.
Thank you.
Mark Leo
https://ae.linkedin.com/in/archmlcm
archmlcm
Re: error: #syntaxerror - plugins/followandrotate_en.rbs?
Postby Rich O Brien » Tue Sep 28, 2021 8:53 am
The clue is in the error message....
Code: Select all
...that right there is what WE need not to worry about.
There's a frontroom and a backroom....reverse faces
User avatar
Rich O Brien
Administrator
Postby Box » Tue Sep 28, 2021 9:54 am
For a bit more info on that, follow and rotate hasn't worked for a long time. So it isn't a bug, just a bugged plugin. Remove it or you will continue to get that error.
User avatar
Postby Dave R » Tue Sep 28, 2021 7:46 pm
Since this isn't a SketchUp bug and is instead related to an old extension, I've moved the thread to the Plugins folder.
BTW, your profile says you are still using SketchUp 2014. Please update your profile. That information helps others help you.
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Plugins
Who is online
Users browsing this forum: Archassandra, DuyguK, KRRISH11223344 and 14 guests
