[Plugin] TopoShaper - v2.6a - 24 Apr 21 - IsoContour & Cloud
Re: [Plugin] TopoShaper - v2.5c - 29 Oct 19 - IsoContour & C
Postby jschwaiger » Wed Jun 30, 2021 5:23 pm
I was able to copy my linework into a new sketchup file and get it to work - not sure what the issue was before - I have been getting similar cleansing errors for some time, but never created a log, so not sure how similar they are...
jschwaiger
Postby Dave R » Wed Jun 30, 2021 6:56 pm
jschwaiger wrote:I have also been receiving the error...
What version of SketchUp are you using? Please complete your profile.
User avatar
Global Moderator
Postby jschwaiger » Wed Jun 30, 2021 7:03 pm
Sketchup Pro 2021 on Windows 10.
jschwaiger
Re: [Plugin] TopoShaper - v2.6a - 24 Apr 21 - IsoContour & C
Postby horsewithnoname » Sat Jul 24, 2021 10:08 pm
Hey guys,
Is there a way to make changes to the terrain after it as been generated?
Like making an undergound level.
Also, is there a way to make a step and not join two lines with a slope?
horsewithnoname
Postby GD3Design » Thu Sep 09, 2021 11:07 pm
Hello,
TopoShaper just started giving me problems. I've used for years without any hickups..no idea why I'm getting errors now.
When I select contours and run TopoShaper, I get 'cannot hide layer that is a part of the active path' Error.
This is happening on both office and home pc. Sketchup Pro 21.1.299, Windows 10 pro. error log attached, one from office, one from home office. If anyone has any ideas or has time to check this out, I'd sure appreciate it. Thanks!
User avatar
GD3Design
Postby GD3Design » Fri Sep 10, 2021 1:17 pm
Update:
I got it to work. exploded, copied to new drawing, etc. All good now. :thumb:
User avatar
GD3Design
Postby fredo6 » Fri Sep 10, 2021 4:08 pm
TopoSahper has to play with layer visibility to have the 2D/3D view. So, if you are not at the top level of the model, there may be problems.
User avatar
PluginStore Author
PluginStore Author
Postby caespinosax » Sat Oct 23, 2021 5:02 pm
I just installed Libfredo6, restarted sketchup, and then installed the toposhaper plugin, then rebooted again and the plugin is nowhere to be found. In the window menu if the LibFredo6 options menu appears. I have SK2019
caespinosax
Postby TIG » Sat Oct 23, 2021 7:15 pm
TopoShaper appears in a Fredo... submenu under Tools.
There is also a Toolbar option...
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
cron
Who is online
Users browsing this forum: No registered users and 15 guests
