Alarm for V-ray (SOLVED)
Postby Tax » Sat Sep 04, 2021 1:44 am
An extension witch plays some music or pop a msgbox once V-ray has finished render.
Any aproach ideas on this?
I found no prints of it on SU console but it has its own "V-ray progress window":
Could we acess/detect its last logs?
obs: I use V-ray 3.6 on SU2018 on Win10-64bits
"Between cause and consequence, lots of connivance."
"Never felt being on same level as others; just bc Ive never been."
User avatar
Tax
PluginStore Author
PluginStore Author
Re: How to code an alarm for V-ray?
Postby Tax » Sat Sep 04, 2021 9:34 am
Just realized V-ray changes its toolbar icons while rendering:
bet the best aproach would be an observer; would appreciate help on coding it.
User avatar
Tax
PluginStore Author
PluginStore Author
Postby Tax » Sun Sep 05, 2021 2:27 am
Realized that eventually it may end up on UI::Command class matter.
So I'm thinking about a simplier (even shitty) workaround:
1º aproach: observer
2º aproach: toolbar class?
3º aproach: pixel color <<<
New questions: (assuming its always gonna be the same pixel coord)
- How to read screen pixels? directly?
- Screenshot? how to write and read?
- is "color check at every 10s" a good practice? better suggestion?
User avatar
Tax
PluginStore Author
PluginStore Author
Postby Tax » Sun Sep 05, 2021 6:05 pm
(SOLVED)
It`s actually pretty simple. Thanks to DanRathbun on:
https://forums.sketchup.com/t/how-to-tell-if-v-ray-render-has-finished/133293
Code: Select all
if VRay::LiveScene.active.rendering? == false
   print "Render hasn't started. Try again."
else
   @Timer = UI.start_timer(5,true) {
      print "Render is complete."
      UI.beep
      UI.stop_timer(@Timer)
      break
   print "V-ray render check"
Works like a charm!
User avatar
Tax
PluginStore Author
PluginStore Author
Re: Alarm for V-ray (SOLVED)
Postby Dan Rathbun » Wed Dec 15, 2021 5:41 pm
Just a note that calling the == method with a true or false argument for a Boolean conditional expression is considered poor practice.
Ie, ...
... it is completely unnecessary to make a method call here as the Vray::LiveScene method calls return a Boolean result and the interpreters if evaluates the Boolean expression.
So the interpreter must evaluate an extra expression that is either:
false == false or true == false
    I'm not here much anymore. But a PM will fire email notifications.
    User avatar
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    by Ad Machine » 5 minutes ago
    Ad Machine
    Robot
    Return to Developers' Forum
    Who is online
    Users browsing this forum: No registered users and 15 guests
