total newbie question
Postby aghud » Sun Aug 01, 2021 2:37 pm
Hi Guys
i am new to all this so please forgive my ignorance
i am using the free version on a windows pc and i want to build a recording studio in my loft
question 1 .:
can i download extensions into the free version?
if so how ?
i have watches the videos on you tube but it only shows this on the pro version and not the free version
thanks
T
aghud
Re: total newbie question
Postby Box » Sun Aug 01, 2021 2:59 pm
Simple answer is No, at this time the web version does not support extensions.
User avatar
Postby aghud » Sun Aug 01, 2021 3:30 pm
thanks
which version is the minimum for exts ?
i wont be using it after this project and as i have no idea as to what i am doing i will need to save all my cash for the project
thanks anyways
T
aghud
Postby TIG » Sun Aug 01, 2021 3:50 pm
Currently the free web-based version does not support 'plugins/extensions'.
But there is still a 'Make' version of 2017 available for non-commercial use [might be you?]
That does allow most plugins/extensions to be install and run [obviously some newer ones will be adjusted for newer versions of SketchUp, but many earlier ones will still work OK.
For v2017 Make try: https://help.sketchup.com/en/downloading-older-versions
User avatar
Global Moderator
Postby aghud » Mon Aug 02, 2021 10:52 am
@Tig
Thank you so much :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb:
aghud
Postby aghud » Tue Aug 03, 2021 12:06 am
@Tig
i still cant load add on as the version wont let me register ?
is the version also a trial or can i keep it for a while
how can i register it ?
TY
T :fro:
aghud
Postby TIG » Tue Aug 03, 2021 11:36 am
I assume you mean v2017 'Make' - if it's a fresh install you'll get the full version working for a month, after that it reverts to make.
https://www.sketchup.com/sketchup/2017/ ... en-x64-exe
What have you downloaded and installed [remember that you need to right-click installer's exe and 'run as administrator' - if it's already installed do a 'repair' when prompted...] ?
You will need to give some details to get it working... even when 'free'...
All versions allow extensions to be installed and used...
User avatar
Global Moderator
Postby aghud » Tue Aug 03, 2021 1:47 pm
Hi Tig
Yes Thanks i got the hang of it .. ithink...
i can istall the add ons through the archive function where i look at the info for the plugin then download it then istall it from sketchup
just having a problem with the "Fredo tools " it wont install although it tells me it has hmmmm.
no matter i can learn faster with this version as the youtube videos look the same interface as what i have with it...
so far i have had a lot of fun with it .. but soon i have to stop playing with it and get my plans and models up and running.
i am looking for an addon that helps me design framing for int walls and doors, stairs etc. then help me calculate the materiel ..
not only am i loving this app but i am really impressed with the support and help from people ..
great community ..
if i can find a use for this app after my project then i will invest in a paid version...
once again
Thank you
T :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb: :thumb:
aghud
Postby TIG » Tue Aug 03, 2021 2:01 pm
Some authors like Fredo & thomthom use supporting Lib files, which are available to download and install [LibFredo], then after SketchUp is restarted the tools should load and be available.
However, don't fall into the trap of thinking that every extension is listed under the Extensions menu...
Read up on each particular extension's usage - e.g. Fredo's Tools is accessed through the Tools menu list or its Toolbar entry...
Some other tools are also activated from the context-menu... read up on each one...
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Extensions & Applications Discussions
Who is online
Users browsing this forum: No registered users and 8 guests
