[Plugin] JointPushPull Interactive - v4.4e - 02 Jun 19
Re: [Plugin] JointPushPull Interactive - v4.4e - 02 Jun 19
Postby rv1974 » Mon Jul 19, 2021 1:38 pm
works perfectly here.
try direct:
https://www.racoon-artworks.de/resource_extendborders.php
p.s. his ShapeConnect is also interesting:
rv1974
Postby panixia » Mon Jul 19, 2021 7:35 pm
rv1974 wrote:try direct:
Yes, the page works, but the download button does nothing. :?
User avatar
panixia
Postby rv1974 » Mon Jul 19, 2021 8:09 pm
Everything works here, maybe its your ad blocker- try DL via smart phone. Let's discuss it in PMs, not in the thread
rv1974
Postby Box » Fri Jul 23, 2021 3:44 pm
Hi Fredo
There seems to be an issue with JPP Normal.
It doesn't produce sides.
This is running 2021.1.299 on Win 7 with Lib 11.9c and JPP 4.4e
User avatar
Postby boofredlay » Fri Jul 23, 2021 4:16 pm
I just tested it with 2018 Pro and it works fine. Must be something with the newer SU version.
User avatar
boofredlay
Global Moderator
Postby panixia » Fri Jul 23, 2021 5:23 pm
Box wrote:Hi Fredo
That's 100% because you set "borders" to "none". :thumb:
User avatar
panixia
Postby Box » Sat Jul 24, 2021 2:31 am
panixia wrote:That's 100% because you set "borders" to "none". :thumb:
I was sure I had checked that, in fact I'm still sure that I changed to to None while trying to make it work.
But you are absolutely correct, as soon as I set it to Contour or Grid it works perfectly.
Sorry Fredo, all good.
User avatar
Postby panixia » Sat Jul 24, 2021 7:28 am
Glad that it helped.
User avatar
panixia
Postby Box » Sat Jul 24, 2021 7:52 am
panixia wrote:Glad that it helped.
One for the D'oh book.
User avatar
Postby panixia » Sat Jul 24, 2021 12:29 pm
Lol! :roflmao:
User avatar
panixia
Postby EvilBoris » Wed Oct 13, 2021 3:43 pm
Can anybody help?, I get this error with any object using round
Date: 13-Oct-21 15:39:35
An error occurred in Round Push Pull
Error in Analysis of model
undefined method `normalize' for nil:NilClass
jointpushpullalgo.rbe: 1408 -- block in round_compute_direction
jointpushpullalgo.rbe: 1406 -- each
jointpushpullalgo.rbe: 1406 -- round_compute_direction
jointpushpullalgo.rbe: 1353 -- block in block_prepare_vertices_R
jointpushpullalgo.rbe: 1353 -- each
jointpushpullalgo.rbe: 1353 -- block_prepare_vertices_R
jointpushpullalgo.rbe: 1111 -- block in block_prepare_vertices_all
jointpushpullalgo.rbe: 1111 -- each
jointpushpullalgo.rbe: 1111 -- block_prepare_vertices_all
jointpushpullalgo.rbe: 519 -- algo_prepare_calculation_exec
jointpushpullalgo.rbe: 499 -- algo_prepare_calculation
jointpushpulltool.rbe: 837 -- dragging_start
jointpushpulltool.rbe: 1527 -- onLButtonDown
I can do this with a new document and a cube and I get this error or in an existing model.
EvilBoris
Postby Dave R » Wed Oct 13, 2021 3:47 pm
EvilBoris wrote:Can anybody help, I get this error with any object using round
This is in SketchUp 8 as your profile indicates you are using?
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: akashachar, farnaz_pzr, gnandhu97, Sibz and 16 guests
