Wires
Wires
Postby duanekemp » Thu Jul 15, 2021 9:03 pm
A part of a current project (not showing the project)... allowing a glimpse into some detail due to plugins by Chris Fullmer's Component Stringer and Fredo6's Curviloft.
Renders took around two minutes each.
5
Duane Kemp
Kemp Productions
Puidoux, Switzerland
Gallery:
https://duanekemp.artstation.com/
User avatar
duanekemp
Re: Wires
Postby boofredlay » Thu Jul 15, 2021 9:17 pm
Nice! :knockout:
User avatar
boofredlay
Global Moderator
Re: Wires
Postby ntxdave » Thu Jul 15, 2021 10:49 pm
Some very interesting and well done work. :thumb: :thumb:
User avatar
ntxdave
Re: Wires
Postby duanekemp » Thu Jul 15, 2021 11:32 pm
I've done wires before using the same plugins, but, this was a bit more time consuming as it had many more to deal with. Thanks guys.
Duane Kemp
Kemp Productions
Gallery:
User avatar
duanekemp
Re: Wires
Postby Bryan K » Thu Jul 15, 2021 11:56 pm
Excellent work.
Wires are not easy for me. Free floating ones like are even harder.
Top notch work. :thumb:
User avatar
Premium Member
Premium Member
Re: Wires
Postby L i am » Fri Jul 16, 2021 9:26 am
That is seriously, great work. Making cables look convincing is not easy, at all :thumb:
3
Premium Member
Premium Member
Re: Wires
Postby Mike Amos » Mon Jul 19, 2021 10:59 am
Serious brilliant, got me pondering on the model that gets this level of detail, looking forward to find out what it is. :thumb:
Premium Member
Premium Member
Re: Wires
Postby duanekemp » Mon Jul 19, 2021 11:55 am
These are the cables attached to a nuclear bomb reconstruction from photo references. Though the wires were a pain in the butt, the bomb itself was a nightmare. Fortunately, the geometrical issues were solved and the bomb is now complete. But, I remember the day where, "dang... I have to do those wires/cabling" was a bit of a hurdle... wasn't looking forward to it.
Duane Kemp
Kemp Productions
Gallery:
User avatar
duanekemp
Re: Wires
Postby L i am » Tue Jul 27, 2021 1:37 pm
"These are the cables attached to a nuclear bomb".......ah, that's why they look so familiar ;)
Premium Member
Premium Member
Re: Wires
Postby L i am » Tue Jul 27, 2021 1:47 pm
From a serious perspective it gets away with being "Milspec" equipment, and you nailed that :thumb:
Premium Member
Premium Member
Re: Wires
Postby duanekemp » Thu Jul 29, 2021 12:17 am
Thank you so much!
Duane Kemp
Kemp Productions
Gallery:
User avatar
duanekemp
Re: Wires
Postby pbacot » Thu Jul 29, 2021 1:13 am
Nice Electrical wires
Shocking results!
Is this a "current" project or "potential" project?
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
User avatar
Top SketchUcator
Re: Wires
Postby duanekemp » Thu Jul 29, 2021 7:05 am
Thank you very much.
This is a current project that has several levels of development. The implosion device with this wire configuration was completed last year and a second variation has been finalised, which has the bomb in place/installed in support rings and frame within a warhead, which is part of one half of the final presentation that includes a different device. The two bombs together are meant to show the direct comparison between the two weapons within their respective warheads with shrouds.
This also meant the wiring had to be done a second time for it to be presented within the "case" or protective covering while sitting in the warhead, with the wires' socket connected to a control box.
Once published, I'll be able to share renders so that these wires will have a bit more visual context or explanation/reason to be modelled.
Duane Kemp
Kemp Productions
Gallery:
User avatar
duanekemp
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Gallery
Who is online
Users browsing this forum: Google Bot and 4 guests
