[Plugin] TopoShaper - v2.6a - 24 Apr 21 - IsoContour & Cloud
Re: [Plugin] TopoShaper - v2.5c - 29 Oct 19 - IsoContour & C
Postby jschwaiger » Wed Jun 30, 2021 5:23 pm
I was able to copy my linework into a new sketchup file and get it to work - not sure what the issue was before - I have been getting similar cleansing errors for some time, but never created a log, so not sure how similar they are...
jschwaiger
Postby Dave R » Wed Jun 30, 2021 6:56 pm
jschwaiger wrote:I have also been receiving the error...
What version of SketchUp are you using? Please complete your profile.
User avatar
Global Moderator
Postby jschwaiger » Wed Jun 30, 2021 7:03 pm
Sketchup Pro 2021 on Windows 10.
jschwaiger
Re: [Plugin] TopoShaper - v2.6a - 24 Apr 21 - IsoContour & C
Postby horsewithnoname » Sat Jul 24, 2021 10:08 pm
Hey guys,
Is there a way to make changes to the terrain after it as been generated?
Like making an undergound level.
Also, is there a way to make a step and not join two lines with a slope?
horsewithnoname
Postby GD3Design » Thu Sep 09, 2021 11:07 pm
Hello,
TopoShaper just started giving me problems. I've used for years without any hickups..no idea why I'm getting errors now.
When I select contours and run TopoShaper, I get 'cannot hide layer that is a part of the active path' Error.
This is happening on both office and home pc. Sketchup Pro 21.1.299, Windows 10 pro. error log attached, one from office, one from home office. If anyone has any ideas or has time to check this out, I'd sure appreciate it. Thanks!
User avatar
GD3Design
Postby GD3Design » Fri Sep 10, 2021 1:17 pm
Update:
I got it to work. exploded, copied to new drawing, etc. All good now. :thumb:
User avatar
GD3Design
Postby fredo6 » Fri Sep 10, 2021 4:08 pm
TopoSahper has to play with layer visibility to have the 2D/3D view. So, if you are not at the top level of the model, there may be problems.
User avatar
PluginStore Author
PluginStore Author
Postby caespinosax » Sat Oct 23, 2021 5:02 pm
I just installed Libfredo6, restarted sketchup, and then installed the toposhaper plugin, then rebooted again and the plugin is nowhere to be found. In the window menu if the LibFredo6 options menu appears. I have SK2019
caespinosax
Postby TIG » Sat Oct 23, 2021 7:15 pm
TopoShaper appears in a Fredo... submenu under Tools.
There is also a Toolbar option...
User avatar
Global Moderator
Postby makover » Tue Nov 30, 2021 1:48 pm
Installed Toposhaper (sketchup pro 2021) and when I start out with "cleansing contours it goes to a yellow square with the contours to the side and no toolbar to select the parameters from. seem to be able to work through it by right clicking and selecting "create preview". Ultimately what I'm hoping to do is to adjust the level of smoothing so that I get things like the sidewalks showing up in the examples below. Attaching below terrain done with native sandbox tools, and then done with toposhaper. hoping I can get something between the two in terms of terrain detail and most importantly eliminating the jagged geometry created with sandbox.
makover
Premium Member
Premium Member
Postby fredo6 » Tue Nov 30, 2021 7:15 pm
Could you send me the model with the isocontours. There may be a bug somewhere.
User avatar
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: MysteryBoi, samuel_t, SEVYSEVY, wim van landschoot and 17 guests
