New to DC: topic for my simple questions to the pros
thanks Phil! Completely understood! Thank you!
Sorry to bother again...
I have another tricky question: I have issues trying to report attributes assigned to COPIES of the original instance. I mean: the fields areactually correclty compiled but the native reporting tool keeps only the result of the "original" instance.I attach my component (which I'm particularly proud of, maybe naively...).
You can spot the issue, for example, if you change the size of the main component eg to 150x100cm. In this case I replicate the inner "Riser_strutt.quadrotta", and the copy is resized to 100x50. If you now enter the component you will see that the copy of the original instance has a "COMP_FIN" attribute changed to 50x100 (dimensions of the tile after the copy).
If I generate report using the "8_PRELIEVO" template, I get a quantity of 2 on the string of "quadrotta truciolare Riser", and the "comp_fin" field still reports "100x100".Is there a way I can make this work? or is it impossible?
In this second case, my solution would be NOT to modify the copy of the original instance but instead include an invisible pre-set 100x50 component, appearing in the right places(s) when needed... Could this work?THANKS A LOT IN ADVANCE!
It has been reported that modified DC copies do not list in the writer, however still no fix, probably unlikely now LCs are the flavor, so we wait while they re-event the wheel instead of fixing thats broken or out of round...
https://forums.sketchup.com/t/generate-report-does-not-include-component-copies/80600 (2 years)
I believe this your best option, plus a 50x50
Thanks a lot, as usual.
I ask you a personal opinion: do you think that the trimble team will dismiss the Dynamic Component system? I've writtena whole load of them..... -
You should be proud, you have grasp the technical challenges of a relative difficult scripting language and now adding you own spin on it. This is what is going to help you adapt and improve whatever the future changes are.
It is clear that LCs is where the development is, hardwired and web savvy.
DCs will still be around for 5 years but likely, as before, no development'@unknownuser said:
We intend to launch authoring tools for Live Components sometime next year. Being able to author Live Components is just the beginning though. Those apps/tools will expand over the next several years to offer new ways of modeling in conjunction with SketchUp.
https://forums.sketchup.com/t/introducing-a-new-kind-of-sketchup-object-live-components/139815/10
I understand they acquired the concept
https://forums.sketchup.com/t/introducing-a-new-kind-of-sketchup-object-live-components/139815/33I would agree with Dan on the period ahead...
The Dynamic Components extension has not had any new features for many many years, and will (most likely) not get any more. SketchUp team has said this before. There are too many extensions (some Trimble) that now rely upon the DCs to remain as they are.
It has also been like “pulling teeth” to get errors in the Dynamic Components extension fixed. I do hope (and politic) for all existing easily fixed errors in DC code to be fixed, before it is “retired” to an optional extension.
So, it is most likely [speculating] that the Dynamic Components extension would be “frozen” at some version, and thereafter remain as such in the Extension Warehouse as an optional extension. (Ie, it may no longer be distributed as a “default” extension with the SketchUp installer. But [speculating] this is not likely to happen for several major cycles until after Live Components is mature enough.)
https://forums.sketchup.com/t/livecomponents-vs-dynamiccomponents/140441/11
Hi again! I've encontered a critical misfunction, I'm posting this in the hope someone can help me figure out how to dodge this.
In the file I attach there's a panel. If I copy the panel, select both copies and change the length, both component react correctly BUT the formulas contained in the last 3 top-level attribute rows are deleted, substituted by their value as fixed number.
What can cause this?
And secondary: is there a way to apply a certain DC configuration to another DC of the same "family"?
Thanks in advance!
EDIT
Found another user's post showing same issue. Seems to be related to the attribute state set to "User can see". Thanks!
you could use the summary to display the data as the "component info" section is not affected.
I suggest you consider using some ruby scripts with your DCs to help with placement, multiple changes....
Hi all!
Sorry to ask for help again: I'm trying to figure out the simplest way to round a result of a formula to the closest upper value of a list with non constant intervals (e.g. 20,70,180,500)Do you have any hints for me?
Thanks in advance as usual!
nearest
then test if input > nearest
if so find the next valueexample 1: use a string of values and string functions to get the next
I was almost there thanks a lot Phil!
Hi! is there a way to select all locked components? a plugin or a one-line snippet maybe?
Thanks in advance! -
Hi again! I have a new question for Phil
I have a formula which returns a text string which may contain LUCIDO, SEMILUCIDO or OPACO.
I want another attribute to substitute in that exact string the words LUCIDO, SEMILUCIDO or OPACO with GL100, GL60 or GL25 respectively. Is there a way to do that?
Thanks in advance!
So cool! Thanks a lot, I couldn't have made it by myself.
Hi again! This is slightly OffTopic but it seems I can't find out a plugin I once saw.
Say we have a DC ("wall") in a model, then we copy it 2 more times and make 3 variations in total, which will be called "wall", "wall#1" and "wall#2". Say we later delete the wall#1 instance, so we have "wall" and "wall#2".This plugin checks the numbered instances of "wall", and renames the "wall#2" instance to "wall#1" (since "wall#1" is available again after the deletion).
Con any of you guys recall what was the name of this plugin?
Thanks in advance!
Eneroth Decrease Component Number on extension warehouse
Wonderful!!! THANKS Phil!
Hi again! Happy new year!
I have the need to bulk export the thumbnails of the selected components, I fiddled around in the forums and I discovered this small but effective Ruby code:mod = Sketchup.active_model # Open model
sel = mod.selection # Current selection
path = mod.path #current path
mypath= File.join(File.dirname(path),'/') #not the model namesel.each do |sel| # you would have to select all components in the model
compname = sel.name # each component's definition name
thumbnailname = File.join(mypath, compname + '.jpg') # as jpg
sel.definition.save_thumbnail thumbnailname
endThe only issue is that this plugin doesn't work if i have the character "|" in the component instance name. Is there a way to allow the character in the "allowed" characters? Thanks in advance!
Hi again! Is there a way, even a small oneliner ruby code, to get a dimension in SKP (Not layout) with NO leaders at all? No lines, only the number.
Thanks in advance!
Hi again!
another silly question: is there any way a plugin could select all the dynamic components which share the exact same attribute selections as the selected one?Could be very useful.
A searched a lot but could not find any in the internet..
Thanks in advance!
