MSPhysics 1.0.3 (16 October 2017)
Re: MSPhysics 1.0.3 (16 October 2017)
Postby pilou » Tue Jul 21, 2020 1:35 pm
For your tests :)
Put your links as you want...
Wanted 2 curves...
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Sat Jul 25, 2020 11:06 pm
Sorry bad hypothesis ! :oops:
That can't work with these prisms!
There are overlapings!
Works for 2 perpendicular "lines" but not for a checkerboard! :-P
Here with a pyramid with 5° basis
Speedy Galerie
User avatar
Top SketchUcator
Postby pilou » Fri Jul 31, 2020 8:09 am
I found my error and won half of joints! ;)
No so evident to find the good angles following sizes! :ugeek:
3
Speedy Galerie
User avatar
Top SketchUcator
Postby azizxpx » Fri Sep 04, 2020 1:38 pm
Hello Anton_S
We thank you very much for this effort
I was hoping the work would Export in mdl format
Is there a way for that?
Thanks ..
azizxpx
Postby mkurmanalinova » Mon Sep 28, 2020 7:22 am
Hello, could you help me?
1. I need a command, a function that allows to find out the position of the pusher at any time by using the keys, for example. At the moment the position of the pusher is bound to the sensor. The box crosses the sensor, the sensor issues a task for the movement of the puher. Also, when we touch the sensor, we display the coordinates of the pusher. The command “puts” didn’t help, it show the text, but we need the changing value.
2. I need a command that is triggered by the condition: "sensor 2" = 1, "sensor 3" = 1, moreover, when the box leaves the sensor's range, "sensor 2" = 0. The pusher moves to a value of -70 when there are 2 boxes on the conveyor in the range of sensors 2 and 3.
The problem is as follows: the pusher is triggered by the condition if laser2 && laser3> 0, fly = -70, written in the script of sensor 3.
But when the box crosses the sensor 3, only one condition is triggered (laser3> 0), the boxes do not accumulate.
Is there a function (onTouch, onUpdate, etc.) where you can write a condition via an if for two sensors?
mkurmanalinova
Postby eosmontana » Tue Nov 17, 2020 11:14 pm
Does anyone know of a work around to install on a mac in SKU2019?
eosmontana
Postby Dave R » Sat Nov 21, 2020 12:15 am
eosmontana wrote:Does anyone know of a work around to install on a mac in SKU2019?
As per earlier posts in this thread, the extension doesn't work in versions later than 2018 so there's no point installing it for SketchUp 2019. The author is working on a new version and it'll be released as soon as it is ready.
User avatar
Global Moderator
Postby ak-sam » Wed Feb 17, 2021 10:32 pm
Hello are there any updates on when this could be compatible with SU2020 & 2021?
ak-sam
Postby Dave R » Wed Feb 17, 2021 10:48 pm
ak-sam wrote:Hello are there any updates on when this could be compatible with SU2020 & 2021?
See: viewtopic.php?f=323&t=56852&start=840#p656107
User avatar
Global Moderator
Re: MSPhysics Preview
Postby pinyol » Wed Feb 24, 2021 4:53 pm
Hi Anton,
Any news on when you'll be able to release an updated version of this wonderful Plugin?
Best,
Juan
pinyol
Postby kaoru_komine » Tue Mar 23, 2021 7:38 am
Hello.
I have a question for the participants of this forum.
I would like to use the videos I made with "mspysics" and "sketchup make" for commercial purposes, what do you guys do in such cases?
If I have a "sketchup" license, am I not in violation?
Or do I have to buy "sketchup pro 2017" somehow?
I posted a question here because the terms and conditions of sketchup.com don't make sense to me.
Please let me know what you think.
kaoru_komine
Postby maddiebeck » Thu Mar 25, 2021 8:18 pm
Hi Anton,
I am also awaiting the release of an SKU2021 compatible version of MS Physics..Can we expect to see this soon?
maddiebeck
Postby Dave R » Fri Mar 26, 2021 1:02 pm
kaoru_komine wrote:I would like to use the videos I made with "mspysics" and "sketchup make" for commercial purposes, what do you guys do in such cases?
The terms of use for SketchUp 2017 Make are clear that it may not be used for commercial purposes. Having a license for an older version of SketchUp does not change the EULA for Make. If you need more clarification on that you should seek legitimate legal counsel.
kaoru_komine wrote:Or do I have to buy "sketchup pro 2017" somehow?
At this stage it's not likely that Trimble would sell you a license for SU2017 Pro. It's long out of support and they don't sell licenses for unsupported versions. The current version for which they are providing licenses is 2021.
User avatar
Global Moderator
Postby faust07 » Wed Apr 07, 2021 7:58 pm
Hello Anton,
I hope you are fine and as a programming and physics genius you have a lot to do ... ;)
My questions:
Is it feasible to make the existing (ingenious) MSPhysics compatible with SketchUp 2021 and what effort would that require?
SketchUp and Ruby API have changed a few times in the meantime.
Could outsiders with more or less programming knowledge help you? Possibly also financially.
You're working on a new version. Can someone help you with testing?
Otherwise, porting the last version v1.0.3 to SUp2021 would be very helpful, as you already have to keep 3 SketchUp versions:
SUp2016 32bit for Sketchy Physics, SUp2017Make for MSPhysics and the current SUp version for daily work.
I hope the users' interest in exercises and simulations on a physical basis for SketchUp does not wane.
Since SketchUp is only available in paid versions anyway and since more and more professional plugins are chargeable, this would also be conceivable for MSPhysics.
Well, moaned enough.
Best regards, Andreas
faust07
move the cart forward
Postby 971jmd » Sun May 09, 2021 4:48 am
hello
hi, i can't move the cart forward, do you have the skechup file to understand. thank you
https://youtu.be/s2XaEboPQ7g?t=731
[url]]https://youtu.be/s2XaEboPQ7g?t=731[/url]
971jmd
Re: move the cart forward
Postby Dave R » Sun May 09, 2021 5:23 pm
971jmd wrote:i can't move the cart forward
What version of SketchUp are you actually using? Your profile says Pre-6.
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: alevaxxia78, Edwardesss, Google Bot, jacejacejace12, Shree97 and 20 guests
Visit our sponsors:
