[Plugin] FullScreen v5.0.0 (14 Feb 2021)
Re: [Plugin] FullScreen v5.0.0 (14 Feb 2021)
Postby Anton_S » Wed Feb 17, 2021 6:58 am
pipinek wrote:As in previous version I have an issue with the toolboxes placed on the SU working space (not docked. Most of the time they are frozen. Cannot activate any icon or move them on the screen. This is very annoying.
With the previous version opening and close a Menu-Toolbat dialog windows or deactivate/activate an item of your plugin via the Menu resolved the problem.
At present several times I could make alive the toolbar only by restarting SU 2021 (samein 2020 one).
Sometimes it works, sometimes not.
Does this frozen toolbars issue happen with just the FullScreen plugin installed or does it happen even without the plugin installed?
pipinek wrote:One more thing - it seems whilst the plugin activated the screen toolbar tips are not showing
Can you elaborate by active? Do you mean when the user interface window is open or when you have certain certain features hidden, e.g when hiding menu bar?
I do not seem to experience either of the above, so help me understand this.
By the way, glad the previous issue is resolved!
Anton_S
PluginStore Author
PluginStore Author
Postby TutorialsUp » Wed Feb 17, 2021 7:14 am
:ecstatic: Thank you so much for this awesome update :o
I'm facing one little problem in SketchUp 2021 it's showing in the Extension menu not windows and the is not an option for Reset I also find in Shortcut.
and one request :P
can you turn on the dark mode or just invert colors for the whole sketchup including all toolbars, trays, dialogs, and menus
by doing this you can save millions of eyes :fro: :ecstatic:
Thanks again
User avatar
TutorialsUp
Postby pipinek » Wed Feb 17, 2021 4:29 pm
Anton_S wrote:At present several times I could make alive the toolbar only by restarting SU 2021 (samein 2020 one).
By the way, glad the previous issue is resolved![/quote]
Greetings,
Only when FullScreen plugin is active/unable there is often the problem with floating toolbars and tooltips.
Same occurred with the orevious version of the plugin.
If this happens the icons on the floating toolbars are frozen. They do not react on clicking, the toolbar as cannot be moved aa well.
The only thing that can cure it is to restart Sketchup. Often it works.
This happens only when FullSreen plugin is unable.
Perhaps as a brand new Sketchup element installed and its very unique quality and function Sketchup has same time to warmly and fully accept it.
pipinek
Premium Member
Premium Member
Postby Anton_S » Fri Feb 19, 2021 7:33 am
TutorialsUp wrote:and one request :P
Dark theme is not an easy problem to solve. Besides changing the colors of the frames, you must also change many of the icons, e.g. icons that contain black edges must be changed to white or another light outline color, otherwise, it will look ugly. Besides that, trays will also need to be updated... The fonts should be changed from dark to light. Doing this would not be practical (maybe even possible) from my end. This is something that SketchUp has to do from their end. I know WinForms framework supports dark theme. If SketchUp is based on WinForms, then it shouldn't be a hard problem for them.
Anton_S
PluginStore Author
PluginStore Author
Postby Anton_S » Fri Feb 19, 2021 7:38 am
TutorialsUp wrote:I'm facing one little problem in SketchUp 2021 it's showing in the Extension menu not windows and the is not an option for Reset I also find in Shortcut.
I moved the controls to Extensions menu intentionally. The Reset option is replaced with Apply Saved. Toggle the Apply Saved option to retain (apply saved settings) or reset (revert to original settings). The purpose for having one menu option is so that you could assign the same shortcut key to toggle between retaining and resetting.
Anton_S
PluginStore Author
PluginStore Author
Postby Anton_S » Fri Feb 19, 2021 7:46 am
pipinek wrote:Only when FullScreen plugin is active/unable there is often the problem with floating toolbars and tooltips.
Would it be possible for you to test the FullScreen plugin without AVAIL RPC installed? It can be the case that there is an additional conflict between two of these plugins.
pipinek wrote:Perhaps as a brand new Sketchup element installed and its very unique quality and function Sketchup has same time to warmly and fully accept it.
No, that is not the case. SketchUp does not work like an immune system.
Anton_S
PluginStore Author
PluginStore Author
Postby simjoubert » Tue Mar 09, 2021 8:51 am
Hello and thank you for this plugin which will facilitate and improve the transition from modeling to customer presentation!
The number of plugins in my toolbar has grown without my being able to get rid of a single one! Can you imagine saving different toolbar configurations to switch from one working environment to another depending on the state of play of the model. Modeling, texturing, Animation, Render, ...
thanks again
Bonjour et merci pour ce plugin qui va faciliter et améliorer le passage modélisation à la présentation client !
Le nombre de plugins dans ma barre d'outils grossi sans que je puisse me défaire d'un seul ! Pouvez vous imaginer l'enregistrement de différente configurations de barre outils pour passer d'un environnement de travail à un autres selon l'atat d'avancement du modèle. Modélisation, texturing, Animation, Render,...
Merci encore
User avatar
simjoubert
Premium Member
Premium Member
Postby DanBie » Tue Mar 09, 2021 12:01 pm
Great. Good job! :)
DanBie
Postby RoCas777 » Mon Mar 22, 2021 10:47 pm
I have installed the plugin on SketchUp but I can't find the toolbar or the settings on Extensions menu or anywhere else :( :( anyboydy had the same trouble and know how to fix it???
Cheers!
RoCas777
Postby Dave R » Thu Mar 25, 2021 4:34 pm
Read the first post in this thread. It clearly states it does not work on Mac.
It also indicates that in the Extension Store entry.
User avatar
Global Moderator
Postby yinliangxxxx » Wed Mar 31, 2021 3:46 am
Thank you Anton_S, I’m very sorry for my poor English, I can only use Google Translate to communicate, may I consider adding a multi-language library, it is convenient for other countries’ plug-in lovers to translate your plug-in, thank you again
yinliangxxxx
Postby eseraphim » Mon Apr 12, 2021 5:17 am
Hi Anton, I was used AMS window settings but just upgraded to Fullscreen and SketchUp 2021.
In SketchUp 2020 I had to shortcuts mapped -- one hid everything and went fullscreen and the other restored my window back to my working space -- it worked perfectly. However, I seem to be unable to do the same workflow with your latest update? Trays do not seem to want to show/hide whenever I apply saved settings, I have to check "trays and dialogs" to bring them back no matter what even if they are supposed to disappear as part of the saved settings -- additionally, I set a shortcut key to the apply saved settings, but it doesn't seem to do anything. Am I missing something? thank you for the help.
eseraphim
Postby awadrummer » Fri Apr 16, 2021 8:05 pm
I love the plugin, but I was wondering if it would be possible to have Sketchup save the toggle for floating toolbars. I have to hide the floating toolbars manually every time I restart Sketchup even though I use Fullscreen to hide them and click the save and check the "Apply Saved On Start" option.
Thank you!
Chris B.
awadrummer
Postby gianlucaf » Wed Jun 16, 2021 4:15 pm
awadrummer wrote:Hi,
Thank you!
Chris B.
Apparently I have the same problem, or maybe I don't quite understand how it works.
Still a great help.
gianlucaf
Postby rv1974 » Thu Jun 17, 2021 4:08 am
Try Fredo LOTT
rv1974
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Plugins
Who is online
Users browsing this forum: Einstein, NickBarker88, SULIDA59 and 16 guests
Visit our sponsors:
