export selection to STL not possible any more?
General discussion related to SketchUp Pro and Make
Postby togo » Sat Nov 21, 2020 11:52 pm
the export to STL seems to have changed in version 2021:
If you only want to export one group as STL, then it is no longer enough to just select the solid group, the corresponding tag must also be activated, otherwise nothing will be exported, which is pretty confusing if nothing happens.
In version 2020 any tag could be active and the selected group was simply exported, no matter on which tag is located.
In version 2021 I now cannot export two solid groups which are on different tags any more.
Is there any way to handle this, without changing the tags of each selected group just for the export?
(not easy to explain - I filmed this, but the size is 80mb?)
togo
Re: export selection to STL not possible any more?
Postby Dave R » Sun Nov 22, 2020 12:10 am
Good catch. I can reproduce that. I expect it's a regression in the exporter code.
There's a bug report filed on this.
User avatar
Global Moderator
Postby togo » Sun Nov 22, 2020 12:24 am
ok, thanks. I have a workaround for now.
togo
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Pro & Make Discussions
Who is online
Users browsing this forum: furkanylcn, JanaOttenburgs, paddyclown and 6 guests
Visit our sponsors:
