New to DC: topic for my simple questions to the pros
• Page 2 of 3 • 1, 2, 3
Re: New to DC: topic for my simple questions to the prosHi again! I want to have to possibility to have the Definition Name of a DC to be displayed in the Options Dialog, so that if I rename a DC I have its correct name on the dialog. Is that possible?
WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
Re: New to DC: topic for my simple questions to the prosThe components instance name is already tied to both the attribute and option dialog, this can be updated on the fly. This works if you do not use the name attribute and only after loading the component.
Otherwise the component definition name can be accessed via a ruby script and placed into an attribute value. Re: New to DC: topic for my simple questions to the prosThanks! And what would this ruby script be?
Re: New to DC: topic for my simple questions to the prosthanks Moor!
Sorry, but maybe I misexplained what I need, I'm attaching an example. In this case I'd like that if I rename the component to whatever else, I get the new name in the Option dialog title. At the moment, this wont' happen: it keeps titling "elemento da prelevare_shell". WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
Re: New to DC: topic for my simple questions to the prosyou can use the component instance name to give each instance an unique name which is reflected in all the dialog, which is the natural inbuilt way
otherwise set Name = _name in the DC then use a button from the toolbar extension to fire the code snippet to alter the _name attribute, which reads the current definition name, updates the original name to update the option dialog Re: New to DC: topic for my simple questions to the prosSorry Moor, I don't understand. In the file I sent you, if I change the Instance name of "elemento da prelevare_shell" NOTHNG CHANGES in any window...
Re: New to DC: topic for my simple questions to the prossaveas the DC to a folder then bring it into another file, for some reason it does not initially work within its created file, after that, should work, regardless of the number of changes, the references are still maintained
Re: New to DC: topic for my simple questions to the prosOH BIG THANKS! I WAS MISSING THE FACT THAT IT DOESN'T WOTK ON THE ORIGINAL FILE!
Re: New to DC: topic for my simple questions to the prosHi again! is there a way I can LOCK the rotation of a DC along specific axis'?
I have a panel which I don't want users to be able to use as ceiling, so I only want it to be rotateable along its blue axis WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
Re: New to DC: topic for my simple questions to the prosIt's me again!
I'm struggling since a couple days about one thing I think should be doable but I can't get in any way to work in my DC. Basically I have a wall, made of two side pillars and a series of panels in the middle. My wall can be stretched to match some precise measures, which I set. The measures are exact multiples of the panels but may also admit an half-panel on the end, if needed. When I stretch the wall, the start pillar must stay still (works now), the end pillar must reach the final point (works now) and in the middle I want the panel to copy a number of times. It works when I fix the length of the panels to a value, but I'm not able to tell SketchUp that it must stretch the last panel to half its dimension if needed. Do you guys know a way to do that? Thanks in advance!!! WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
To work out the number divide the opening by the whole door size and convert to integer To get the remainder take this number times the size from opening For door lenx, use condition if remainder then the last copy (= copies) is to be remainder There were some issues with the geometry and scaling, first applied lenX to two faces, then had to make a group of the edges so that it obeyed the formula rather than its natural scale made outline to size to opening, added some copy function to the support Re: New to DC: topic for my simple questions to the prosThanks a lot pc!!! I'll have a look at it immediately!
*EDIT* Everything is clear, I don't understand the syntax of these two formulas though: =parete Arty!d_mod_num-1 +if(parete Arty!remain,1,0) Here I don't understand the space between "-1" and "+if" and I don't know the meaning of the "parete Arty!remain" without any checks to perform. =if(and(parete Arty!remain,copy=copies),parete Arty!remain,98) Here I don't understand the meaning of "parete Arty!remain" without any checks: what will it solve into? MANY MANY THANKS! WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
Re: New to DC: topic for my simple questions to the prosThe condition is either true or false, 0 or any negative number is read as false whereas any positive number is true.
A bit of a short cut in logic. The space is not required for mathematical functions, just there for my own readability Re: New to DC: topic for my simple questions to the prosI have a new question for the community: I have an attribute which ALWAYS include alternatively the words "OPACO" "LUCIDO" or "SEMILUCIDO" (name of the material applied). The words are always at the end of the text string, but the number of digits before may change.
I want another attribute to report ONLY the occuring word from case to case. EG: my material attribute returns "grey RAL7040 OPACO", I want another attribute to report only "OPACO". Is there a way to do this? WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
try so: =RIGHT(Material, 5) Re: New to DC: topic for my simple questions to the prosThanks Kostiaarh!
Sadly this formula returns always the last 5 characters, while the number of letters I have to report varies from 5, 6 and 10 digits. WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
Re: New to DC: topic for my simple questions to the prosYou can use find with the item to be found included in the text to avoid the error , and test if the result is within the length of the original text
Note that semi is placed before in the conditional statements otherwise will not be selected Re: New to DC: topic for my simple questions to the proswonderful! Thanks!!
Re: New to DC: topic for my simple questions to the proshi guys! I have a new question: I have a DC which features a choice between type1 and type2. I'd like to have an hyperlink to a pdf showing the technical specs of each choice, so I uploaded both pdfs to an S3 amazon server to have get a valid url.
Is there a way I can insert the <a href> tag inside a formula, so that the hyperlink changes based on the type1/type2 choice? WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
Re: New to DC: topic for my simple questions to the prosI am using 2018. however can see problem when referencing in a formula, a suggestion is to put the pages in the value section of the options list
Re: New to DC: topic for my simple questions to the prosAs always, thanks a lot!
Re: New to DC: topic for my simple questions to the prosHi all you DCs experts!
I have one silly question: for several reasons, the most complex DCs I have made make themselves unique after a simple copy of the original instance. Given the fact that I have to further investigate why this happens in specific cases, would it be possible to write a plugin which searches all the instances of the same DC and substitutes the identical copies with one single component? WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
Re: New to DC: topic for my simple questions to the prosAny DC with nested DC(s) will become unique on a redraw, so I recommend using the definition name as a category rather than an identity, and use the instance name or a custom attribute as the identity. the #number is not considered, the reports "group by" is the instance or custom attribute.
If you simplify a DC so its nested components are not dynamic, then the definition #number will remain, so one could consider a method of simplification via a script as a possible solution depending on the DCs concerned. Although you could script a swap for same, that "same" would have to be a simple DC with no nested DCs as the uniqueness would only be triggered again if there is a redraw Re: New to DC: topic for my simple questions to the prosthanks Phil! Completely understood! Thank you!
Re: New to DC: topic for my simple questions to the prosSorry to bother again...
I have another tricky question: I have issues trying to report attributes assigned to COPIES of the original instance. I mean: the fields areactually correclty compiled but the native reporting tool keeps only the result of the "original" instance. I attach my component (which I'm particularly proud of, maybe naively...). You can spot the issue, for example, if you change the size of the main component eg to 150x100cm. In this case I replicate the inner "Riser_strutt.quadrotta", and the copy is resized to 100x50. If you now enter the component you will see that the copy of the original instance has a "COMP_FIN" attribute changed to 50x100 (dimensions of the tile after the copy). If I generate report using the "8_PRELIEVO" template, I get a quantity of 2 on the string of "quadrotta truciolare Riser", and the "comp_fin" field still reports "100x100". Is there a way I can make this work? or is it impossible? In this second case, my solution would be NOT to modify the copy of the original instance but instead include an invisible pre-set 100x50 component, appearing in the right places(s) when needed... Could this work? THANKS A LOT IN ADVANCE! WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
Re: New to DC: topic for my simple questions to the prosIt has been reported that modified DC copies do not list in the writer, however still no fix, probably unlikely now LCs are the flavor, so we wait while they re-event the wheel instead of fixing thats broken or out of round...
https://forums.sketchup.com/t/generate- ... pies/80600 (2 years)
I believe this your best option, plus a 50x50 Re: New to DC: topic for my simple questions to the prosThanks a lot, as usual.
I ask you a personal opinion: do you think that the trimble team will dismiss the Dynamic Component system? I've writtena whole load of them..... ![]() ![]() ![]() WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
You should be proud, you have grasp the technical challenges of a relative difficult scripting language and now adding you own spin on it. This is what is going to help you adapt and improve whatever the future changes are. It is clear that LCs is where the development is, hardwired and web savvy. DCs will still be around for 5 years but likely, as before, no development'
https://forums.sketchup.com/t/introduci ... /139815/10 I understand they acquired the concept https://forums.sketchup.com/t/introduci ... /139815/33 I would agree with Dan on the period ahead...
https://forums.sketchup.com/t/livecompo ... /140441/11 Re: New to DC: topic for my simple questions to the prosHi again! I've encontered a critical misfunction, I'm posting this in the hope someone can help me figure out how to dodge this.
In the file I attach there's a panel. If I copy the panel, select both copies and change the length, both component react correctly BUT the formulas contained in the last 3 top-level attribute rows are deleted, substituted by their value as fixed number. What can cause this? And secondary: is there a way to apply a certain DC configuration to another DC of the same "family"? Thanks in advance! ****EDIT**** Found another user's post showing same issue. Seems to be related to the attribute state set to "User can see". Thanks! WEB (ita) - https://filipposcarso.wixsite.com/ordinentropico
Who is online
Users browsing this forum: truongthetai and 2 guests
