was told sketchup is bad for 3d printing
• Page 1 of 1
was told sketchup is bad for 3d printingHi,
Was just talking to the 3d printing workshop and when they did not mention sketchup as a software to use, I asked why and they said it causes a lot of problems. I have not 3d printed anything let, but if I do it woud be with sketchup as thats what I'm more comfortable with. But is Sketchup problematic for 3d printers? Another person said there is a lot of issues with faces. Look forward to any feedback you might have. Regards Simon Re: was told sketchup is bad for 3d printingI'd be interested in an answer to this too.
As long as your modelling is watertight and prepared properly for printing, I wouldn't have thought that there would be an issue. Box seems to get some great results from SUp, so it might just be that this company isn't used to working with good quality SUp models.
Re: was told sketchup is bad for 3d printingI made a few models for 3d printing (even for a HQ expensive 3d printer) with SketchUp and it works fine. I don't see any problems there.
Maybe the shop ran into people that didn't have much experience and made 'bad' 3d models?! What kind of models do you intend to 3d print? Why not just try making your model in SketchUp, 3d print and analyze problems if they occur? Re: was told sketchup is bad for 3d printingLet’s face it, if the Warehouse is anything to go by, there are a lot of people making ‘bad’ SUp models.
I’m often sent models by clients and it’s rare that I don’t have to rebuild everything from scratch.
Re: was told sketchup is bad for 3d printingSketchup has all kinds of users, that's the beauty of it. People who know what they're doing will have good results, people who don't... well, they can always learn how to do it.
Re: was told sketchup is bad for 3d printingBasically anyone saying Sketchup is no good for 3d printing simply hasn't learnt to use Sketchup effectively.
Some other software can be less likely to cause problems because they are solid modellers whereas sketchup is a surface modeller. Solid modellers make everything out of solid lumps, but sketchup needs you to understand how to make a manifold solid. Re: was told sketchup is bad for 3d printingA nice ‘solid’ confirmation from box
Re: was told sketchup is bad for 3d printingThe guy was expecting me to use Solid works, but as im an Interior Designer its more natural that I come from the Sketchup or 3D Max direction.
I cant say if I am a good modeler though. But I do expect to be creating more curvey free form models when I do to 3D printing, which i dont have any experience in doing actually. Bit scared of leaving my world of boxes behind. Cheers Re: was told sketchup is bad for 3d printingBox nailed it - I totally agree that anyone who learns how to use Sketchup "properly" with good modeling practices will be just fine. Keep in mind that plugins are virtually a necessity for making great models for 3D printing.
Every CAD program has limitations, Sketchup included. Solid modeling programs can be easier to make a solid model, often providing a warning if the modeling operation will make a non-manifold model. The level of complexity certainly takes some of the "fun" out of the modeling that Sketchup is known for. I'm a big fan of using the right tool for the job. Sketchup is fantastic for making architectural-type models - no big surprise. Solidworks is great for mechanical engineering models. Blender is good for artistic purposes, and Zbrush for character modeling. Can any of the programs be used for making other models than what they're best known for? Sure! Half the battle is knowing how to use the program, and great users can perform magic in their tool of choice. However, you're not going to win any character-modeling awards using Solidworks. ![]() Personally I still use Sketchup for some projects, but I've mostly outgrown it for Fusion 360. Parametric modeling is a major time saver when iterating a product, and it's much easier to make complex organic objects. So now @syburn - the question is, what are you modeling for 3D printing? If the models are similar to what you already use Sketchup for, then you'll be just fine. 3D Printing with SketchUp Book
http://goo.gl/f7ooYh
Re: was told sketchup is bad for 3d printingI want to explore 3d printing in interiors so i expect I will be looking for freeform and organic forms as conventional construction is alread doing square types of designs very well.
So its more organic, curvy, with patterns on the surface. Regards Re: was told sketchup is bad for 3d printingI've printed a lot of models in 3D and all of them were modeled with SketchUp. Maybe you should have a look at an online printing service instead?
You can use Sketchup with plugins like Curviloft and Subdivide and Smooth for a while, but you will run into limitations pretty quickly, especially with patterns on curved surfaces. You may want to look into using Rhino then. I believe our resident skate park designer Jeff graduated to Rhino for those kind of shapes. Many architects use Rhino as well. It's more accurate and much easier to use for organic shapes. It is still a surface modeler (vs a solid modeler), so you'll want to keep good modeling practices for 3D printing in mind. It'll be much easier for texture mapping your shapes as well. Fusion360 could work as well, but I haven't seen many architectural projects made with it. @cotty, I think he's asking more about modeling, than printing. 3D Printing with SketchUp Book
Re: was told sketchup is bad for 3d printingHow do you use 3d printing in the interior design business?
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
Re: was told sketchup is bad for 3d printingNot actually the problem but it has issues. Sketchup is not too bad. allthat3d can help you in getting a detail idea of it.
- FTFY ![]() SketchUp Pro 2021
Dell Precision 3630 Intel i7-8700 32 GB Ram 512 M.2 PCIe SSD Nvidia RTX 2080 Re: was told sketchup is bad for 3d printingI've used SU to design sewing machine parts and toys, and they all 3-d printed just fine. You'll need one of the plugins that write STL files, and then you're good to go.
One trick: if it's a small part and there's fine detail, design it at 1000x scale, then shrink it down before you generate the STL file. SU doesn't like fine details. Re: was told sketchup is bad for 3d printing
STL export has been a native thing in SketchUp for some time now. No need for a plugin for that. Modeling at 1000x is good but no need to scale the model down before exporting the STL. Model with units set to meters but tell the slicer that the units are millimeters. The STL file is unitless, after all. Here's something I did in SketchUp this evening. It's 3D printable. The image is from the slicer. Etaoin Shrdlu
% (THERE'S NO PLACE LIKE) G28 X0.0 Y0.0 Z0.0 M30 %
Re: was told sketchup is bad for 3d printingGood morning to all of you.
Is SketchUp performing well to produce STL gear files? Re: was told sketchup is bad for 3d printingIt can perform well for that sort of thing but it depends on how well the model is made.
Re: was told sketchup is bad for 3d printingEtaoin Shrdlu
Re: was told sketchup is bad for 3d printingAlthough I have been using SU for near a decade now, I will only be getting a 3D printer in July/August, so I'm no expert on 3D printing. But I have done a lot of research on the subject.
The thing to remember in creating SU models that will print well is IMHO attention to detail. SU is a surface modeller. Any curve is a series of straight line vectors, they are not the smooth curves you see if the model is smoothed. That smoothness is only an illusion via the SU display s/w. The printer prints in straight lines, very small straight lines, but nothing is a true curve. So to get a reasonably smooth curve in the printer you need the curve divided into a lot of segments. SU default is 24 segments in a 360 degree circle. Great for small curves, but large curves may need 120 segments. That I think may be the reason some prints come out less than desired. The other critical thing is the bead size the printer is making. The current standard .4mm so any feature Lines or curve segments) in the model that is less than .4mm will not print well, if at all. You can get print nozzles as small as .15mm, but that will really slow down a slow print to begin with. So making curves requires a minimum segment size no less than the nozzle size. You need to preview the final model in SU with hidden and smoothed lines turned off before you output the STL file. That is what the print will/should look like. __________________
jgb
• Page 1 of 1
