delete and update add_note don't work
Postby mr_Creator » Fri Aug 21, 2020 9:20 pm
Hello,
I create note:
Code: Select all
@note = Sketchup.active_model.add_note 'Note', 0.8, 0.9
But I cannot delete and change the note. Help please, I used different methods, but none helped.
mr_Creator
Re: delete and update add_note don't work
Postby dezmo » Sat Aug 22, 2020 4:43 pm
Code: Select all
You may realised that is creating Sketchup::Text https://ruby.sketchup.com/Sketchup/Text.html
To change:
Code: Select all
@note.set_text "This is another note"
Most probably to see changes, the view need to redraw.
Code: Select all
Sketchup.active_model.active_view.invalidate
do delete:
Code: Select all
@note.erase!
Man can do everything. Only a matter of time and money.
dezmo
Postby mr_Creator » Sat Aug 22, 2020 8:37 pm
dezmo wrote:
Code: Select all
To change:
Code: Select all
Code: Select all
do delete:
Code: Select all
@note.erase!
When i use:
Code: Select all
then I get this (check image)
the text is superimposed on each other. Sketchup 2020
mr_Creator
Postby dezmo » Sun Aug 23, 2020 1:30 pm
mr_Creator wrote:When i use:
Code: Select all
You didn't say what you did before.
I guess you actually did something like this:
Code: Select all
If you can tell me what your goal is at all, I might be better able to suggest something... ;)
dezmo
Postby TIG » Sun Aug 23, 2020 1:50 pm
The bare bones code is:
Code: Select all
note=Sketchup.active_model.add_note("The initial note", 0.8, 0.9)
### where 'note' is a reference to that newly made text-entity
### refreshes the view
later on you can use
Code: Select all
note.text="This is the changed note"
The @note would only apply if you are reusing variables between methods etc.
Also the set_text(...) method operates outside of the undo-stack, whereas the text= works within it.
Also, please parenthesize your arguments...
To erase the note use note.erase!
User avatar
Global Moderator
Postby Dan Rathbun » Sat Oct 17, 2020 2:20 pm
Just tested Sketchup::Text#set_text on SU2020 and it (as Dezmo says) does not display the change until the view is redrawn. So Sketchup.active_model.active_view.invalidate is necessary to see the change.
I'll open a documentation issue for this "quirk".
    I'm not here much anymore. But a PM will fire email notifications.
    User avatar
    Dan Rathbun
    PluginStore Author
    PluginStore Author
    by Ad Machine » 5 minutes ago
    Ad Machine
    Robot
    Return to Developers' Forum
    Who is online
    Users browsing this forum: v1jsd11 and 5 guests
    Visit our sponsors:
