Dual Dims extension
Dual Dims extension
Postby Chris Hutchins » Fri Jul 31, 2020 9:42 pm
I can't figure out how to center both the imperial (top) and metric bottom on the dim. line.
Imperial is always left justified.
thanks
Last edited by Chris Hutchins on Fri Jul 31, 2020 10:51 pm, edited 1 time in total.
Chris Hutchins
Re: Dual Dims extension
Postby Dave R » Fri Jul 31, 2020 9:54 pm
What settings do you have for Dimensions in Model Info. I get this when I run Dual Dimensions.
User avatar
Global Moderator
Postby Chris Hutchins » Fri Jul 31, 2020 11:32 pm
Here are the Dimension details, I have tried modifying them without much luck.
Seems to work fine for you!. could it be related to how I have fonts set up somewhere else?
Chris Hutchins
Postby Dave R » Fri Jul 31, 2020 11:48 pm
Very likely it is the font. Flux Architect is a pretty poorly built font. Notice that your first screen shot doesn't even show the font as FLux Architect. Try Verdana or Arial and see what you get.
If you want something that looks more hand lettered, you might try Tekton Pro.
or Architect Std
And there are certainly others out there.
As I was poking around on my computer I came across one called NewFlux Architect. No idea where it came from but that one does appear to behave.
User avatar
Global Moderator
Postby Chris Hutchins » Fri Jul 31, 2020 11:56 pm
Actually, the first example is Verdana, I was trying several different fonts including Flux Architect, they all respond the same, with the imperial numbers left justified.
Chris Hutchins
Postby Dave R » Fri Jul 31, 2020 11:59 pm
Maybe it's a Mac thing.
User avatar
Global Moderator
Postby Chris Hutchins » Sat Aug 01, 2020 10:22 pm
If I highlight the dimension text, then it pops back into the center where I want it?
any ideas?
Chris Hutchins
Postby Dave R » Sat Aug 01, 2020 10:36 pm
That does seem like a Mac thing. Maybe TIG will get an opportunity to chime in when he has time.
User avatar
Global Moderator
Postby TIG » Sun Aug 02, 2020 2:25 pm
It behaves as expected on PCs, so I must suspect it's a MAC issue.
I don't have a MAC available right now...
@DaveR - do you have one to check it ?
I suspect it's not the extension per se, but the way MACs format dimensions' text...
Can one of you try doing it manually too...
Select an 'ordinary' dim and manually edit its text...
Let the first part be <> to tell it to use the actual value, then add \n to force a new-line and some alternative text [in () if desired]...
So if it's 24" the string would be something like <>\n(61cm)
Is the justification of the text still 'wrong' ??
If so it's not the extension, but it's the MAC itself !
User avatar
Global Moderator
Postby Dave R » Sun Aug 02, 2020 2:32 pm
TIG wrote:@DaveR - do you have one to check it ?
Unfortunately my MacBook is defunct so I can't check it but I'm guessing you are on the money with the way Macs format text.
User avatar
Global Moderator
Postby Chris Hutchins » Sun Aug 02, 2020 5:57 pm
Hi Guys... appreciate your help on this!
If I do it manually I get the same left justification.... \n didn't seem to work on the Mac, but Control & Return provided the 2nd line.
I guess its a Mac thing
Chris Hutchins
Postby Dave R » Sun Aug 02, 2020 6:08 pm
I asked another Mac user to test it and he got the same thing so yes, I would agree it's a Mac thing.
User avatar
Global Moderator
Postby TIG » Sun Aug 02, 2020 6:17 pm
What typed equivalent might work ?
\r or \r\n for example ?
Could you try those possibilities manually and see what works on your MAC - if anything...
If something works then I can add an OS test for a MAC, and change the PC's \n newline character[s] to suit that ??
User avatar
Global Moderator
Postby Chris Hutchins » Thu Aug 06, 2020 5:52 pm
Interestingly enough, when I print as PDF everything comes out center justified. So I am good to go, thanks for you help!
Chris Hutchins
Postby Dave R » Thu Aug 06, 2020 5:57 pm
That's kind of odd but as long as it works...
What happens if you send to LayOut? Do those dimensions look right in LO?
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Extensions & Applications Discussions
Who is online
Users browsing this forum: No registered users and 0 guests
Visit our sponsors:
