[Tutorial] Animator Quick Start
• Page 4 of 4 • 1, 2, 3, 4
Re: [Tutorial] Animator Quick StartAwesome..
Thanks for the quick response, I'll have a play with it and see how it works.. Cheers. Re: [Tutorial] Animator Quick StartHello! I'm trying to animate a scene using STATIC SCENE (the ones created in SKP).
Here is the prob. I add Scene 1, Scene 2, Scene 3.... and it ALWAYS forces a transition between them. Whereas I want: Scene 1. ...5 secs. CUT to SCENE 2..... 5 secs. CUT to SCENE 3.... 5 secs. NO TRANSITIONS between scenes. I'm getting a bald spot looking for a solution :S Any comments appreciated. Re: [Tutorial] Animator Quick Start
Page Utilities 2 Save the Earth, it's the only planet with chocolate.
When you click on each element for scenes in the timeline, you have a dialog box appearing in the corner. Just click and disable the 'Fade out' (it's a toggle button)
Re: [Tutorial] Animator Quick StartHi, Is it possible to reuse the animated object in another sketchup file?
For example, I created a spinning fan in a sketchup project, but now I have a new project which requires the same fan in animation. Can I reuse the same spinning fan I've created in animator previously, but in a different project?
Not possible at the moment. I am trying to think whether it could be possible and how to do it, but not obvious.
Re: [Tutorial] Animator Quick StartThanks for the quick response.
I got another question regarding rendering using 'ambient occlusion EX' plugin. I did an APPARITION in animator to create a section cut effect of a particular object. However, after rendering, the section cut effect affected the whole scene instead of that object. I then did another rendering using the normal Natural rendering and the APPARITION section cut effect works correctly on that single object. Any idea how to make it work using ambient occlusion EX plugin?
This is one known problem with rendering software. They don't seem to take section cuts into account. Could you try to render a model with an active section cut using Ambient Occlusion Ex and tell me if you see it. Thanks fredo
I just did a section cut with scenes. Ambient occlusion does not render section cut correction when export via animation mode. Section cut does work in Ambient occlusion in a static view. I guess that is the limitation of Ambient occlusion renderer. Thanks for your awesome tools Fredo.
Animator interacts with Ambient Occlusion Ex via an API. Maybe it caches the state of objects. Let me see if there is a way to force a refresh. I noticed the same behavior with Thea.
Regarding explosion animationHi,
I have a question regarding explosion effect in animator, is there a way to control direction of elements that explodes, currently they are exploding in all the directions but i cannot control them as in which element should move in which direction. This plug-in is super useful, thanks for making something that can convert your imaginations into something visual. Regards, Saumil Re: Regarding explosion animation
Currently Animator explodes away from the center of gravity of the object. There is unfortunately no way to customize it at the moment.
Re: [Tutorial] Animator Quick StartGreetings,
Thank you for a quick reply. Check out this turn table animation I created using animator , v-ray for rendering and some post production. https://www.instagram.com/p/B_z7B7SgbWZ ... _copy_link OR https://drive.google.com/file/d/1-xU8aS ... sp=sharing Re: [Tutorial] Animator Quick Start
nice one, loved the finger snap with accompanying disintegration at the end Save the Earth, it's the only planet with chocolate.
Regarding rendering PluginGreetings,
Can anyone suggest quick rendering plugin(other than V-ray) for basic rendering of the animation. It has nearly 2000 frames. Re: [Tutorial] Animator Quick StartHave you looked at Twilight Render? Animator also supports it.
Animator & SketchFXGreetings,
I have been trying to render my animation using sketchFX. In the progress bar & even in the sketchup it shows that frames are being generated , but when it is done I don't get the full video or all the frames generated, I only get 2-3 frames out of 300 frames in my folder. See attached images Safe FrameCan we add safe frame in animator?
Or is there any way I can get an idea of how much area will be covered if I export in 1:1 aspect ratio while setting up the camera. Animator - besoin d'aideBonjour Fredo,
J'adore ton plugin et je souhaiterai l'utiliser pour visualiser et rejouer la trajectoire de drones ou robots dans une pièce. Je m'explique, les robots sont équipés de capteurs qui me communiquent toutes les secondes leur position X,Y,Z + ID. Pourrait-on imaginer lire ce fichier et écrire en automatique le script de toutes les séquences d'une seconde (ou X secondes) de chacune des translation des différents drones ? En clair, peut-on créer un code pour générer un script en automatique et l'ajouter au modèle pour qu'il puisse être accessible à l'ouverture d'Animator, visualiser les mouvements et réaliser les films des séquences de ces mouvements ... Merci d'avance de ton éclairage sur la faisabilité de cette idée Bien à toi Stéphane Re: [Tutorial] Animator Quick Start@smai31
J'ai prévu de faire des animations par script, mais ca prendra un peu de temps avant que je me remettes aux évolutions d'Animator Pour l'instant, on peut faire l'inverse et visualiser les trajectoires sous forme de courbes de points choisis sur des objets animés. Fredo
I have installed the fredolib and the animator plugin on my macbookpro, on SUPRO2017, i can see the animator tool bar wtih four buttons, but when I click on the first, nothing happens, I can't see the time line and all the other panels!. Could someone help me? Re: [Tutorial] Animator Quick StartBonjour,
Je reposte le message en fançais si besoin, suite à l'installation de fredolib et de animator sur mon mac avec sketchuppro 2017, je ne vois que la toolbar avec 4 boutons, mais pas tout l'environnement de travail. Quelqu'un peux-t-il me répondre sur ce sujets? Merci bcp Re: [Tutorial] Animator Quick Start
What happens if you click on the first button of the toolbar. If nothing happens, the redo the same, but with the Ruby console opened, so that you can see if there are error messages.
Re: [Tutorial] Animator Quick StartAnimator does not start when pressing the clip Icon.
Using skethup 2020. Re: [Tutorial] Animator Quick Start
Can you open the Ruby console and check if there are error messages.
Who is online
Users browsing this forum: Dat19071996, sy950926 and 1 guest
