Dotted lines in pdf export despite being solid in sketchup
Found a bug in SketchUp? Report it here
Postby john2 » Sat Apr 18, 2020 6:50 pm
SketchUp has this bug wherein if I select solid line from the dropdown menu in layers or tags, then the pdf export shows those lines as dotted. I exported this pdf from a new file where I drew a box from scratch.
testing 1.pdf
Sketchup Make 2017 (64-bit), Vray 4.0 , Windows 10 – 64 bit, corei7-8750H, 16GB RAM, Nvidia GeForce GTX 1050Ti 4GB
User avatar
john2
Re: Dotted lines in pdf export despite being solid in sketch
Postby pbacot » Sat Apr 18, 2020 7:09 pm
Same here. But I only see the effect when--under the export options--I turn up the line scale above .5.
And this is v. 2019 on a Mac.Maybe that first pick never was solid. It just looks solid in SketchUP and you have to choose "default" (silly).
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
User avatar
Top SketchUcator
Postby john2 » Sun Apr 19, 2020 7:35 am
pbacot wrote:Same here. But I only see the effect when--under the export options--I turn up the line scale above .5.
That's a great hack to solve this trouble! :ecstatic: :thumb: :thumb:
This has been tested on Sketchup 2019 and Sketchup 2020, Windows 10, 64 bit.
The default settings for pdf have been used to produce this error.
This qualifies as a bug. Right?
User avatar
john2
Postby Dave R » Thu Jul 09, 2020 1:58 pm
Which version of 2020? I just did the same thing you showed and with the default export settings. Attached is the PDF I got using SU20.1.235.
Untitled.pdf
What graphics card are you using?
BTW, your profile says you're still using SU2017. Perhaps you could update it.
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Bug Reporting
Who is online
Users browsing this forum: No registered users and 0 guests
Visit our sponsors:
