DO NOT UPGRADE TO CATALINA .... YET!!!!!
Unless you like to live dangerously
I also lost Audacity after the upgrade
Catalina has broken many apps !
The latest SketchUp v2019.3 [available but not widely advertised yet!] addresses most known issues, but I understand that it still suffers from an 'undo/redo' bug, and that needs fixing directly by Apple ! -
@Euadorian what kind of problem with Audacity are you seeing? If it is being rejected as 32-bit, you need to update to the latest release (2.3.2) which is 64-bit. However, there is known issue with access to certain input devices such as the microphone. They are looking into it. See this link for a temporary workaround:
https://forum.audacityteam.org/viewtopic.php?f=47&t=107162&p=378694
@slbaumgartner Thank you! It just won't open. I was in a rush, so I just used MacOS's voice recorder and then edited it in my PC. I'll look into it. Thanks!
Plugins don't work with CATALINA 10.15.2 / SU 19.3
is there any news yet?
UPDATE: I just updated to Catalina 10.15.3 and installed LibFredo6_v9.5g. FredoCorner and Curviloft are working again!!!
Good to hear. It looks like the wrinkles have been ironed out
So are we good to upgrade now?
