[Tutorial] Animator Quick Start
General discussion about Animator for SketchUp
Re: [Tutorial] Animator Quick Start
Postby TonyAU » Wed Jun 19, 2019 5:16 am
Awesome..
Thanks for the quick response, I'll have a play with it and see how it works..
Cheers.
TonyAU
Postby ctrlaltf1 » Fri Feb 14, 2020 2:06 am
Hello! I'm trying to animate a scene using STATIC SCENE (the ones created in SKP).
Here is the prob.
I add Scene 1, Scene 2, Scene 3....
and it ALWAYS forces a transition between them.
Whereas I want:
Scene 1. ...5 secs.
CUT to SCENE 2..... 5 secs.
CUT to SCENE 3.... 5 secs.
NO TRANSITIONS between scenes.
I'm getting a bald spot looking for a solution :S
Any comments appreciated.
ctrlaltf1
Postby juju » Fri Feb 14, 2020 6:31 am
ctrlaltf1 wrote:Hello! I'm trying to animate a scene using STATIC SCENE (the ones created in SKP).
Here is the prob.
Whereas I want:
Scene 1. ...5 secs.
Page Utilities 2
User avatar
juju
Premium Member
Premium Member
Postby fredo6 » Fri Feb 14, 2020 10:49 am
ctrlaltf1 wrote:NO TRANSITIONS between scenes.
When you click on each element for scenes in the timeline, you have a dialog box appearing in the corner.
Just click and disable the 'Fade out' (it's a toggle button)
User avatar
PluginStore Author
PluginStore Author
Postby piew » Fri Mar 06, 2020 11:07 am
Hi, Is it possible to reuse the animated object in another sketchup file?
For example, I created a spinning fan in a sketchup project, but now I have a new project which requires the same fan in animation.
Can I reuse the same spinning fan I've created in animator previously, but in a different project?
piew
Postby fredo6 » Fri Mar 06, 2020 11:42 am
piew wrote:Hi, Is it possible to reuse the animated object in another sketchup file?
Not possible at the moment.
I am trying to think whether it could be possible and how to do it, but not obvious.
User avatar
PluginStore Author
PluginStore Author
Postby piew » Mon Mar 09, 2020 4:38 am
Thanks for the quick response.
I got another question regarding rendering using 'ambient occlusion EX' plugin.
I did an APPARITION in animator to create a section cut effect of a particular object. However, after rendering, the section cut effect affected the whole scene instead of that object.
I then did another rendering using the normal Natural rendering and the APPARITION section cut effect works correctly on that single object.
Any idea how to make it work using ambient occlusion EX plugin?
piew
Postby fredo6 » Mon Mar 09, 2020 12:08 pm
piew wrote:I did an APPARITION in animator to create a section cut effect of a particular object. However, after rendering, the section cut effect affected the whole scene instead of that object.
This is one known problem with rendering software. They don't seem to take section cuts into account.
Could you try to render a model with an active section cut using Ambient Occlusion Ex and tell me if you see it.
fredo
User avatar
PluginStore Author
PluginStore Author
Postby piew » Tue Mar 10, 2020 11:02 am
I just did a section cut with scenes.
Ambient occlusion does not render section cut correction when export via animation mode.
Section cut does work in Ambient occlusion in a static view.
I guess that is the limitation of Ambient occlusion renderer.
Thanks for your awesome tools Fredo.
piew
Postby fredo6 » Tue Mar 10, 2020 6:28 pm
piew wrote:Ambient occlusion does not render section cut correction when export via animation mode.
Animator interacts with Ambient Occlusion Ex via an API. Maybe it caches the state of objects. Let me see if there is a way to force a refresh. I noticed the same behavior with Thea.
User avatar
PluginStore Author
PluginStore Author
Regarding explosion animation
Postby Saumil12345 » Sun May 10, 2020 6:30 pm
I have a question regarding explosion effect in animator, is there a way to control direction of elements that explodes, currently they are exploding in all the directions but i cannot control them as in which element should move in which direction.
This plug-in is super useful, thanks for making something that can convert your imaginations into something visual.
Regards,
Saumil
Saumil12345
Re: Regarding explosion animation
Postby fredo6 » Sun May 10, 2020 8:51 pm
Saumil12345 wrote:I have a question regarding explosion effect in animator, is there a way to control direction of elements that explodes, currently they are exploding in all the directions but i cannot control them as in which element should move in which direction.
Currently Animator explodes away from the center of gravity of the object. There is unfortunately no way to customize it at the moment.
User avatar
PluginStore Author
PluginStore Author
Postby Saumil12345 » Mon May 11, 2020 8:33 pm
Greetings,
Thank you for a quick reply.
Check out this turn table animation I created using animator , v-ray for rendering and some post production.
https://www.instagram.com/p/B_z7B7SgbWZ ... _copy_link
OR
https://drive.google.com/file/d/1-xU8aS ... sp=sharing
Saumil12345
Postby juju » Tue May 12, 2020 10:29 am
Saumil12345 wrote:Greetings,
OR
nice one, loved the finger snap with accompanying disintegration at the end
User avatar
juju
Premium Member
Premium Member
Regarding rendering Plugin
Postby Saumil12345 » Wed May 13, 2020 7:03 pm
Greetings,
Can anyone suggest quick rendering plugin(other than V-ray) for basic rendering of the animation. It has nearly 2000 frames.
Saumil12345
Postby ntxdave » Wed May 13, 2020 7:54 pm
Have you looked at Twilight Render? Animator also supports it.
User avatar
ntxdave
Postby Saumil12345 » Wed May 13, 2020 8:20 pm
Not yet, I'll go through it.
Thank you
Saumil12345
Animator & SketchFX
Postby Saumil12345 » Wed May 13, 2020 8:36 pm
Greetings,
I have been trying to render my animation using sketchFX. In the progress bar & even in the sketchup it shows that frames are being generated , but when it is done I don't get the full video or all the frames generated, I only get 2-3 frames out of 300 frames in my folder.
See attached images
Saumil12345
Safe Frame
Postby Saumil12345 » Thu May 14, 2020 8:49 pm
Can we add safe frame in animator?
Or is there any way I can get an idea of how much area will be covered if I export in 1:1 aspect ratio while setting up the camera.
Saumil12345
Postby aweardon » Fri May 15, 2020 12:26 am
How do I save the video I create?
aweardon
Animator - besoin d'aide
Postby smai31 » Tue May 26, 2020 2:50 pm
Bonjour Fredo,
J'adore ton plugin et je souhaiterai l'utiliser pour visualiser et rejouer la trajectoire de drones ou robots dans une pièce.
Je m'explique, les robots sont équipés de capteurs qui me communiquent toutes les secondes leur position X,Y,Z + ID. Pourrait-on imaginer lire ce fichier et écrire en automatique le script de toutes les séquences d'une seconde (ou X secondes) de chacune des translation des différents drones ?
En clair, peut-on créer un code pour générer un script en automatique et l'ajouter au modèle pour qu'il puisse être accessible à l'ouverture d'Animator, visualiser les mouvements et réaliser les films des séquences de ces mouvements ...
Merci d'avance de ton éclairage sur la faisabilité de cette idée
Bien à toi
Stéphane
smai31
Postby fredo6 » Wed May 27, 2020 4:15 pm
@smai31
J'ai prévu de faire des animations par script, mais ca prendra un peu de temps avant que je me remettes aux évolutions d'Animator
Pour l'instant, on peut faire l'inverse et visualiser les trajectoires sous forme de courbes de points choisis sur des objets animés.
User avatar
PluginStore Author
PluginStore Author
Postby Frankoi » Fri Jun 05, 2020 11:13 am
I have installed the fredolib and the animator plugin on my macbookpro, on SUPRO2017, i can see the animator tool bar wtih four buttons, but when I click on the first, nothing happens, I can't see the time line and all the other panels!.
Could someone help me?
Frankoi
Postby Frankoi » Fri Jun 05, 2020 11:16 am
Bonjour,
Je reposte le message en fançais si besoin, suite à l'installation de fredolib et de animator sur mon mac avec sketchuppro 2017, je ne vois que la toolbar avec 4 boutons, mais pas tout l'environnement de travail.
Quelqu'un peux-t-il me répondre sur ce sujets?
Merci bcp
Frankoi
Postby smai31 » Fri Jun 05, 2020 1:00 pm
Merci pour cet excellent conseil !
Bien à toi
Stéphane
smai31
Postby fredo6 » Fri Jun 05, 2020 6:19 pm
Frankoi wrote:I have installed the fredolib and the animator plugin on my macbookpro, on SUPRO2017, i can see the animator tool bar wtih four buttons, but when I click on the first, nothing happens, I can't see the time line and all the other panels!.
What happens if you click on the first button of the toolbar.
If nothing happens, the redo the same, but with the Ruby console opened, so that you can see if there are error messages.
User avatar
PluginStore Author
PluginStore Author
Postby sketchnut » Wed Nov 11, 2020 11:58 pm
Animator does not start when pressing the clip Icon.
Using skethup 2020.
sketchnut
Postby fredo6 » Thu Nov 12, 2020 7:48 am
sketchnut wrote:Animator does not start when pressing the clip Icon.
Using skethup 2020.
Can you open the Ruby console and check if there are error messages.
User avatar
PluginStore Author
PluginStore Author
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Previous
Return to Animator Beta
Who is online
Users browsing this forum: No registered users and 0 guests
Visit our sponsors:
