DO NOT UPGRADE TO CATALINA .... YET!!!!!
Postby Mike Lucey » Fri Sep 20, 2019 2:44 pm
Hi Mac SketchUp Users,
It looks like Mac OS Catalina Beta, at least, does not fully support SketchUp.
Mike
User avatar
Mike Lucey
Mayor
Re: DO NOT UPGRADE TO CATALINA .... YET!!!!!
Postby pbacot » Fri Sep 20, 2019 4:24 pm
Thanks Mike!
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
User avatar
Top SketchUcator
Postby sketch3d.de » Thu Sep 26, 2019 11:40 am
Mike Lucey wrote:It looks like Mac OS Catalina Beta, at least, does not fully support SketchUp.
what does this exactly mean, pls elaborate, thx.
User avatar
sketch3d.de
Postby laterstarter » Thu Oct 17, 2019 11:45 am
3dConnexion devices are not supported at all yet, though they inform a driver is being developed
Natively SKP 2019 seems to work under Catalina so long as one has not been spoilt by a 3DConnexion navigation device.
Kind Regards, Scott
laterstarter
Premium Member
Premium Member
Postby markchandler » Thu Oct 17, 2019 8:37 pm
If you're on macOS Catalina, you should be running SU2019.3
markchandler
Postby juju » Thu Oct 17, 2019 9:28 pm
markchandler wrote:If you're on macOS Catalina, you should be running SU2019.3
Wow, another maintenance release?! When did this drop? I totally missed that.
User avatar
juju
Premium Member
Premium Member
Postby sketch3d.de » Fri Oct 18, 2019 12:18 pm
User avatar
sketch3d.de
Postby TIG » Sat Oct 19, 2019 1:17 pm
Version 2019.3 is published.
https://www.sketchup.com/download/all
BUT it not been advertised, or notified in update checking !
Its main change is MAC's Catalina compatibility.
So if you must have Catalina get it.
BUT remember that Catalina is flaky with ALL earlier versions of SketchUp and they won't be getting updated.
So if you use v2017/2018 you can't step up to Catalina.
Catalina has also broken lots of other common applications, so you might want to check what they are, as fixing SketchUp might only be one step down along road !!
User avatar
Global Moderator
Postby juju » Sat Oct 19, 2019 6:25 pm
TIG wrote:Version 2019.3 is published.
stepping up to Catalina when you're on SU2019 / SU2019.1 / SU2019.2 is also a no-no.
User avatar
juju
Premium Member
Premium Member
Postby TIG » Sun Oct 20, 2019 4:15 pm
Unless you like to live dangerously :shock:
User avatar
Global Moderator
Postby Ecuadorian » Sun Oct 27, 2019 10:54 pm
I also lost Audacity after the upgrade :oops:
Ecuadorian
Postby TIG » Mon Oct 28, 2019 2:05 pm
Catalina has broken many apps !
The latest SketchUp v2019.3 [available but not widely advertised yet!] addresses most known issues, but I understand that it still suffers from an 'undo/redo' bug, and that needs fixing directly by Apple !
User avatar
Global Moderator
Postby slbaumgartner » Wed Oct 30, 2019 2:33 pm
@Euadorian what kind of problem with Audacity are you seeing? If it is being rejected as 32-bit, you need to update to the latest release (2.3.2) which is 64-bit. However, there is known issue with access to certain input devices such as the microphone. They are looking into it. See this link for a temporary workaround:
https://forum.audacityteam.org/viewtopi ... 2&p=378694
slbaumgartner
PluginStore Author
PluginStore Author
Postby Ecuadorian » Thu Oct 31, 2019 11:39 pm
@slbaumgartner Thank you! It just won't open. I was in a rush, so I just used MacOS's voice recorder and then edited it in my PC. I'll look into it. Thanks!
Ecuadorian
Postby ramyasri123 » Fri Feb 07, 2020 11:54 am
ramyasri123
Postby galactus » Tue Feb 11, 2020 12:06 pm
Plugins don't work with CATALINA 10.15.2 / SU 19.3
is there any news yet?
galactus
Postby galactus » Tue Feb 11, 2020 2:25 pm
UPDATE: I just updated to Catalina 10.15.3 and installed LibFredo6_v9.5g. FredoCorner and Curviloft are working again!!!
galactus
Postby Mike Lucey » Sun Mar 08, 2020 4:24 pm
Good to hear. It looks like the wrinkles have been ironed out :thumb:
User avatar
Mike Lucey
Mayor
Postby Leggy » Fri Apr 03, 2020 5:01 pm
So are we good to upgrade now?
Leggy
Postby Mike Lucey » Sat Apr 18, 2020 12:36 pm
Leggy wrote:So are we good to upgrade now?
Yes, all good now. I must 'unstick' this thread.
User avatar
Mike Lucey
Mayor
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Corner Bar
Who is online
Users browsing this forum: jsteacy and 0 guests
Visit our sponsors:
