[Plugin] Universal Importer - v1.1.5 - 29 Jan. 2020
Re: [Plugin] Universal Importer - v1.1.1 - 14 Jan. 2020
Postby ken » Wed Jan 15, 2020 2:52 pm
I still have the problem I have for some time.
User avatar
ken
Premium Member
Premium Member
Postby samuel_t » Wed Jan 15, 2020 5:07 pm
ken wrote:I still have the problem I have for some time.
Reinstall Microsoft Visual C++ library (it can fix your error) then let me know if problem persists.
User avatar
samuel_t
Re: [Plugin] Universal Importer - v1.1.2 - 15 Jan. 2020
Postby samuel_t » Wed Jan 15, 2020 6:25 pm
1.1.2 version fixes loading of some OBJ files.
Download latest Universal Importer plugin from SketchUcation PluginStore.
User avatar
samuel_t
Postby ken » Thu Jan 16, 2020 7:07 pm
Well re-installing Microsoft Visual C++ library with stl files. Thanks for the help.
User avatar
ken
Premium Member
Premium Member
Re: [Plugin] Universal Importer - v1.1.3 - 16 Jan. 2020
Postby samuel_t » Thu Jan 16, 2020 9:09 pm
1.1.3 version allows you, during import, to reassign textures which are not referenced nor embedded in model.
User avatar
samuel_t
Postby samuel_t » Thu Jan 16, 2020 9:31 pm
Einstein wrote:[...]
3. When I import a model with multiple textures, I can only select one texture file and that texture is applied.
Sometimes I can but another time I cannot have all textures included. Some models may be badly textured but I'm almost sure that I tried importing the same chair as TutorialsUp did with success, while I didn't get both textures (only one).
Einstein, your issue has been fixed with 1.1.3 version of plugin. ;)
User avatar
samuel_t
Postby sibawal » Fri Jan 17, 2020 12:48 am
hi samuel thanks a lot for this amazing plugin
but sadly it seems not workin with me for some reason
i try use the plugin for importing an .blend .obj and .dae but none of them work
and i got some error ( i attach the image error)
if u not busy please help me and once again thanks a lot
im using mac os high siera , sketchup 2019, and blender 2.81a
sibawal
Postby Oxer » Fri Jan 17, 2020 2:25 pm
The .blend files of 2.80 don't work dought to changes in the API, try with .blend files of Blender 2.79, for me these work fine.
User avatar
Oxer
Postby Oxer » Fri Jan 17, 2020 2:29 pm
Samuel , really the Model height (cm) option do something, I changed this parameter to different values but the imported model has the same dimensions always.
User avatar
Oxer
Postby samuel_t » Fri Jan 17, 2020 4:08 pm
sibawal wrote:[...]
This Blender is not supported. :? Export to .fbx or, as suggested by @Oxer, retry with Blender 2.79. ;)
User avatar
samuel_t
Postby samuel_t » Fri Jan 17, 2020 4:10 pm
Oxer wrote:Samuel , really the Model height (cm) option do something, I changed this parameter to different values but the imported model has the same dimensions always.
Hi Oxer! This feature works pretty well on Windows. I don't know why it doesn't work at all on macOS.
User avatar
samuel_t
Re: [Plugin] Universal Importer - v1.1.4 - 17 Jan. 2020
Postby samuel_t » Fri Jan 17, 2020 5:49 pm
1.1.4 version fixes rendering of some high-density models (typically trees).
User avatar
samuel_t
Postby Oxer » Fri Jan 17, 2020 8:16 pm
In the image the height issue on Mac.
User avatar
Oxer
Postby lewmosconi » Thu Jan 23, 2020 8:59 pm
Hello man, thanks in advance for the app.
But every time I try to import an FBX, messages like that appear.
Universal Importer Error: Command failed: "C:/Users/Leo/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/universaLimporter/Assimp/Win/assim p.exe- info 'C:WrogramData/Universal Importer/tmp/import.FEOC > "C:WrogramData/Universal Importer/tmp/assimp.nfo-
C:/Users/Leo/AppData/Roaming/SketchUp/SketchUp 2019/SketchUp/Plugins/universaLimporter/assimp.rb:166:in 'get_texture_refs'
Universal Importer Version: 1.1.4
lewmosconi
Postby Dave R » Thu Jan 23, 2020 9:46 pm
lewmosconi wrote:Hello man, thanks in advance for the app.
"WrogramData"?
Does it actually say "WrogramData" instead of "ProgramData"?
User avatar
Global Moderator
Postby samuel_t » Fri Jan 24, 2020 11:12 pm
Hello. Reinstall Microsoft Visual C++ library (it can fix your error) then let me know if problem persists.
User avatar
samuel_t
Postby kostiaarh » Mon Jan 27, 2020 11:17 pm
Hello. Importer Error. What does that mean
kostiaarh
Postby joshtays » Tue Jan 28, 2020 5:38 am
Maybe this has been asked, I tried to search it just in case, so apologies if it has been answered already... Is there any plan to support PDF in the future? Lack of PDF import to Windows Sketchup boggles my mind.
joshtays
Postby samuel_t » Tue Jan 28, 2020 7:53 am
Hello @kostiaarh. This sounds like a bug. Could you please upload your model to a file hoster? This way I could debug it.
User avatar
samuel_t
Postby kostiaarh » Tue Jan 28, 2020 8:10 am
samuel_t wrote:Hello @kostiaarh. This sounds like a bug. Could you please upload your model to a file hoster? This way I could debug it.
Yes. I uploaded the file. Thanks you.
https://mega.nz/#!WKZDkYSA!3HFXWqZTRpVG ... 4lG9apMFTA
kostiaarh
Postby Headmade » Tue Jan 28, 2020 10:21 am
Hi, iI installed the latest version of the plugin and it does not work on mac os ((
Headmade
Postby samuel_t » Tue Jan 28, 2020 3:33 pm
joshtays wrote:Maybe this has been asked, I tried to search it just in case, so apologies if it has been answered already... Is there any plan to support PDF in the future? Lack of PDF import to Windows Sketchup boggles my mind.
There's no plan to support PDF in future. :?
User avatar
samuel_t
Postby samuel_t » Tue Jan 28, 2020 3:44 pm
kostiaarh wrote:Hello. Importer Error. What does that mean
Problem comes from model encoding. I've manually fixed "222.obj" and "222.obj.mtl" with a text editor.
I've attached fixed model:
222-fixed-model.zip
User avatar
samuel_t
Postby samuel_t » Tue Jan 28, 2020 3:51 pm
Hi. What version of macOS are you running?
User avatar
samuel_t
Postby Einstein » Wed Jan 29, 2020 12:22 pm
Would it be possible to implement support for TGA format of textures? You can often download models textured with TGA files.
Einstein
Postby samuel_t » Wed Jan 29, 2020 2:49 pm
Einstein wrote:Would it be possible to implement support for TGA format of textures? You can often download models textured with TGA files.
Yes. It's possible. ;)
User avatar
samuel_t
Postby db11 » Wed Jan 29, 2020 5:30 pm
Thanks for the great work on this extension Samuel. It's so useful, and I appreciate the rapid iteration / evolution to address user feedback.
Fantastic job!
3
db11
Re: [Plugin] Universal Importer - v1.1.5 - 29 Jan. 2020
Postby samuel_t » Wed Jan 29, 2020 6:53 pm
1.1.5 version adds TGA and TIFF support for textures.
4
User avatar
samuel_t
Postby Pixero » Wed Jan 29, 2020 7:07 pm
Thanks you.
I agree with the previous poster that PDF import would be awesome.
User avatar
Pixero
Postby olaydigitaldesign » Thu Jan 30, 2020 3:06 am
This is a huge game changer for game developers like me. It is almost up to par with the Skimp plugin's importer which comes with a pretty heavy price tag. The reason why this plugin is so valuable is that I can import models into Sketchup while preserving the UV map, and then export them back into the game engine (Unity in my case).
The only thing it's missing is the ability to preserve the scale and position of imported models, which is the only thing Skimp has on you at this point.
Thanks a ton!
:thumb:
olaydigitaldesign
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to Plugins
Who is online
Users browsing this forum: CreaVivaCity, Pirassununga, ramiro_nicolas, stendhalian, TECHDAVE02 and 20 guests
Visit our sponsors:
