Problem exporting SU -->autoCAD
General discussion related to SketchUp Pro and Make
Postby pace514 » Thu Jan 09, 2020 3:37 am
Hi all !!!
Trying to export in .DWG i have this error message. Then,using DWG true view, it takes forever to open and i can barely do whatever. I suppose i got much more polys than i should but why that same drawing is pretty responsive in SU ?
Should not is be as fast in cad viewer ?
https://www.dropbox.com/sh/wg5quydr1av5 ... kUVNa?dl=0
Thanks for your help !
Have a nice evening !
Pace from Montréal
pace514
Re: Problem exporting SU -->autoCAD
Postby Glenn at home » Thu Jan 09, 2020 5:50 pm
Ok, I gave it a shot and here is what I found out. Your original file with all of those scenes was not working well. I was able to import the dwg into AutoCAD 2020 but it was a hog and slow to use. I deleted all of the scenes and saved to a 2018 SU file and used AutoDesk's free SU import utility and it's smooth as silk now. The dwg files grows from a 45 mg skp to a 86.5 mb dwg. Not sure on what your end result is on this.
SketchUp Pro 2019/2020
Dell Precision 3630
Intel i7-8700
32 GB Ram
512 M.2 PCIe SSD
Nvidia RTX 2080
Glenn at home
Postby pace514 » Sun Jan 12, 2020 9:45 pm
So, from what i understand, i would have to have autoCAD in order to download that plugin. I only have
autodesk DWG TrueView wich is free. Is there an other way to do ? Or would you be kind enough to send me your result ?
Thanks for your time anyway Glen at Home !
Appreciate
Pace
pace514
Postby Glenn at home » Tue Jan 14, 2020 4:55 pm
Sorry for delay, I was out for a bit. Try this....
https://www.dropbox.com/s/xeih0jq22vdqd ... a.dwg?dl=0
Dell Precision 3630
Intel i7-8700
32 GB Ram
512 M.2 PCIe SSD
Nvidia RTX 2080
Glenn at home
Postby pace514 » Tue Jan 14, 2020 8:53 pm
Hummm... When i click on the link, my Dropbox opens and a little red window is telling me that the file does not exist ???
pace514
Postby Glenn at home » Tue Jan 14, 2020 9:06 pm
Sorry, I must have done something wrong on my end. Let me try again.
Edit: Try the above link again. Sorry
Dell Precision 3630
Intel i7-8700
32 GB Ram
512 M.2 PCIe SSD
Nvidia RTX 2080
Glenn at home
Postby pace514 » Tue Jan 14, 2020 10:26 pm
Awesome !!!
Work very well !
Thank you so much Glenn at home !
You made my day !
Cheers !
Pascal
pace514
Postby Glenn at home » Wed Jan 15, 2020 3:34 am
Thanks, glad to help :)
Dell Precision 3630
Intel i7-8700
32 GB Ram
512 M.2 PCIe SSD
Nvidia RTX 2080
Glenn at home
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Pro & Make Discussions
Who is online
Users browsing this forum: dial117, Frovation, jkbarberjr and 7 guests
Visit our sponsors:
