In that, I milled most everything but the ply-wood used, I guess this is "woodworking".
I modeled and built this from a concept sketch. I've revised the original model to reflect the "as-built" state.
The walls, ceiling, and floor were 1/4 inch steel welded in place, so every attachment point was drilled and tapped.
The two back panels on the right and left are mounted on cantilevered slides to access and hide my client's full-automatic guns.
Because the man had both double-barrel and single barrel rifles, I designed some upper receivers that are mounted using magnets, so the guns could be positioned as he wished.
More older stuff
• Page 1 of 1
Re: More older stuffReally nice, well concieved and executed design CJ and thanks for sharing been a bit quite in that area. I find the render a bit half baked and not at all covincing
Render? This is probably the actual appearance of the furniture. Robert
Re: More older stuffThis confused me.
![]() Robert Re: More older stuff
Hi Robert, sorry mate that was a (probably bad) joke. I was aware it was a Photo, indicated by the "wink" at the end ![]()
Re: More older stuffL i am, in that I know you, I found it funny.
For hahas, I found another "render" of the hidden panel.
Hi CJ, not sure Stinkie would appreciate you taking credit for his work ![]()
• Page 1 of 1
