[Plugin] Universal Importer - v1.1.9 - 17 Aug. 2022
Will the smallest I can get the file is 5442 KB.
Attached is an image of the file another converter. This is a downed oil platform in the Gulf of Mexico.
If you can send me an email address, I can use google mail to send the file.
OK. I've sent you my email address in private message.
1.0.5 version:
- Enhances bug reports.
- Fixes "big copy" issue.
Download latest Universal Importer plugin from SketchUcation PluginStore.
1.0.6 version:
- Fixes polygon reduction on models without textures.
- Reduces plugin package size. (From 49MB to 41MB.)
Hi!
I downloaded the latest update but I'm still getting the same bug with every file format. I cannot import any file to SketchUp
By the way, I think it would be cool to also have polygon reduction as standalone tool for meshes that already exist in SketchUp. Because we haven't had a decent free polyreducer in SketchUp so far. It's just a suggestion.
Regards,
MichaΕ
i import this model with v1.0.1 without any problem but v1.0.6 give me this error why?
please help.
please help.On macOS 10.13.6 & SU2017 the v1.0.6 works fine with your model.
It's a good idea
please help.In recent versions of plugin there's a mechanism that prevents copy of a too big folder. To fix this issue: Create a sub folder in your Documents then place model and textures inside that sub folder. Re-import.
@einstein said:
Hi!
Hi!
Could you please upload your model (textures included) to a file hoster or here? So I could debug it.
Still Same error ?
@ahmed0007 said:
Still Same error ?
What's size of model in MB?
@samuel_t said:
@ahmed0007 said:
Still Same error ?
8 mb
@ahmed0007 said:
@samuel_t said:
@ahmed0007 said:
Still Same error ?
8 mb
OK. Could you please post a screen capture of folder containing model (aka a Windows Explorer view)?
Now i'm also unable to import this model again
Youtube Videofile type .obj
size 110 mb
located in Documents folder \Documents\obj 2 -
@samuel_t said:
@ahmed0007 said:
@samuel_t said:
@ahmed0007 said:
Still Same error ?
8 mb
C:\Users\Ahmed\Documents\New folder (2)
@ahmed0007 said:
@samuel_t said:
@ahmed0007 said:
@samuel_t said:
@ahmed0007 said:
Still Same error ?
8 mb
Everything seems OK. I don't understand why you can't import... There are no hidden files, isn't?
Everything seems OK. I don't understand why you can't import... There are no hidden files, isn't?[/quote]
did you try this on your own pc
No! There are no hidden files
i think i should stick with older version. -
i think i should stick with older version.Yes. I tried to import a model with this path: "C:\Users\Samuel\Documents\New folder (2)" and it's OK.
Could you please upload your model to a file hoster? This way I can verify if the model is the problem.
