[Plugin] LSS Matrix
Yes but so there is no limit !
Why not 10 or 100 inbetweeners modules !:) -
Hi everyone,
I just download LSS Matrix. Im using a Sketchup 2017 and it just does not work. It doesnt let me set up any copy or original...
Any help??
This plugin was dead.
@niko_monkey said:
Hi everyone,
Any help??
If you consider the last active post, before the quoted above, is from 2013 and take a look on Extension Warehouse the last release of LSS Matrix was 20 May 2013 and only listed as compatible with SU version 2013 last.
My guess is if you're using anything newer than SU2013 you shouldn't expect this to work at this time.
Why, this plugin was really great, and your work there helped many people...
hey whats up am new here and my lss matrix isnt working properly after i group the first model and copied it when i try to select after i click the initial pick button it wont select it whats the problem plz help me thank you
daer all
any idea why I can't pick the the initial instance , and when the matrix Dialogue the green tick never exit
[img]file:///C:/Users/jade/Desktop/Capture.JPG[/img] -
@jade272 said:
any idea why I can't pick the the initial instance...
Your profile says you are using SketchUp 2017. Read the first paragraph of the original post.
@kirill2008 said:
Small Announcement (29-Jan-2017)
Note that currently there are no plans to continue development of LSS Matrix extension so it is highly recommended look for some other alternatives, which have a similar functionality and compatible with recent versions of SketchUp.This extension hasn't been updated since 2013 so it shouldn't be surprising that it doesn't work in SU2017.
By the way, in order for your image to show you need to upload it. It doesn't work to link to a file on your computer.
ANYONE CAN HELP, THIS PUGIN SOUND GREAT BUT CAN'T PICK THE INITIAL INSTANCE, THERE ARE NO GREEN BOXES OR GREEN TICK AS THE DEMO SHOW? CAN PICK THE I ANY OBJECT.
As the author wrote in his first post, and I repeated in my previous reply to you, this extension is not updated to work in later versions of SketchUp. As the author said, you should find another extension.
is there any up-to-date plugin that has similar functionality to this one?
