Componentes dinsmicos para carpinteros
Postby Gianmartin » Wed Oct 16, 2019 5:34 pm
video_converter__1571243245372.avi
Hola a todos
No se si alguien pueda darme una idea de como hacer lo que esta en el video
mil gracias
Gianmartin
Re: Componentes dinsmicos para carpinteros
Postby pcmoor » Sat Oct 26, 2019 12:54 am
can not see anything on the video, can you upload link to you tube?
pcmoor
Postby Gianmartin » Sat Oct 26, 2019 2:07 am
Gianmartin
Postby pcmoor » Sat Oct 26, 2019 11:58 am
There are two ways to create this, one is to use parts and hide the common edges and faces, the other is to use cutting components
In this case its parts and hidden faces/edges as shown @ 2.04 on video
you can see the outline of the end face/component when the offset is matched to the thickness with a given back thickness,
When you create such. I recommend you use solids then can outer-shell the subs to create a whole (retaining the parent for data and ability to reinstate with swap with its definition)
cutting components work if the edges are hidden (outlines can be added as dynamic groups or components)
Either way, it involves making sub components or (I prefer) groups to suit your purpose
pcmoor
Postby Gianmartin » Sat Nov 02, 2019 1:40 pm
Ok, muchas gracias por la informacion, voy a intertar hacer lo que me dices y estare informando los resultados
Gianmartin
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Dynamic Components
Who is online
Users browsing this forum: No registered users and 0 guests
Visit our sponsors:
