V5 Beta MOI 3D on MAC / PC April 2022 !
By Zarkow
Modelisation Moi Render C4D / Octane
Tuto express
Render Free Simlab Composer
http://www.simlab-soft.com/3d-products/simlab-composer-lite.aspx
Max 1920 * 1080 Real Time (Generated Image Can Be Used Commercially!!! )
Realtime Progressive Rendering !
25 3D formats supported for import and can be mixed!
Free Library of Materials, lightning, HDR, 3D Models and Rendering Presets !
No activation Needed : Just install the program then select βlite editionβ at the first run
(this tutorial is not made with free SimLab even it has some basic modeling functions!
And you can save with free only in owner product format ! -
New Beta 4.0 26 Februar 2019
(for owners of the V 3)
List of news (principally debugging) -
New fonction: InsertCircle - Bones...
Repository of the 70 Native nodes of Elephant (created by Max Smirnov) English / French!
And you can use it with the free alternation version of Moi3D with out save!
As you can make animation with ELEPHANT, you can make screen shot of it!
Elephant the free Nodal system inside Moi3D
Funny inside the free TwinMotion
10 seconds of relaxation render the free real Time SimLab Composer (maxi 1920 * 1080)
Marvelous Insects!
With a free model by Digital Archive of Natural History (numerous available)
Inside Moi with 2 importation methods
Real Time Render with free SimLab Composer Lite
From model at https://www.mcmaster.com
Flow can make miracle before waiting a deformation cage!
Mini Tut
For make fillets over maximum
but can be make more easilly!
For the original script of following!
From a model by Danperk
for link operations seen above and permit research of forms!
https://vimeo.com/370146519 -
"You have to go back because there has been an improvement! Applying it twice allows you to reset the Auxiliary Plan to 0!
From where gain of keys of shortcuts"! -
Sorry I don't know why it's the French version?
I will change that in a minute! (Done)Yes you win a shortcut key because the Plugin makes like a Toogle function!
So the same shortcut enable the CPlane/Face and some many times after (or not) Reset it!
Very practical no need to make Menu View/ CPlane/ Reset CPlane!
Only one key used! For enable the function, for disable the function = Reset Cplane when you don't need it anymore! -
You return it retourner because there has been an improvement! Apply it twice to reset the Auxiliary Plan to 0!
That's why you win a shortcut keys! -
Beta V4 01 21 2020 released! (only for owners of the V 3)
With Elephant nodes cool VoronoΓ― can be made!
