IFC Files to "clean" SKP Files
General discussion related to SketchUp Pro and Make
Postby HornOxx » Wed Sep 11, 2019 12:32 pm
Hi All
usually for me imported ifc files are extremely large and no longer usable so. I haven't done this often yet and I completely lack the experience ;)
Does anyone know a way how to separate and delete the ifc (Bim) data content from the pure model file?
never trust a skinny cook
User avatar
HornOxx
Re: IFC Files to "clean" SKP Files
Postby GD3Design » Thu Sep 12, 2019 11:27 am
Here is my workflow:
-turn off layers of roof, furniture, fixtures, etc
-select all walls, group them, enter group, explode all
-use Vray to select by material, and group parts of wall I want to keep (there is a plugin for this if you dont use Vray.)
-select all, then isolate faces (selection toys) and set all materials to default (sometimes I just delete all materials from the start (quick and easy using vray)
-run CleanUp3 to get rid of 'crap', switch to monochrome mode and run AutoReverseFaces
-put walls on new wall layer, then turn them off and move on to next part of model to 'de-BIM'
Of course, I play by ear on this depending on how much of the model I really need to use and how 'messed up' the model is when I get it. For smaller areas, I may just remodel the portion that i need - I find I have less crashes and things move faster that way.
User avatar
GD3Design
Postby HornOxx » Thu Sep 12, 2019 3:33 pm
GD3Design wrote:Here is my workflow:...
:thumb:
thank you very much for your answer :thumb: - first I have to understand step by step what you recommend and consider how and with which means I can implement your suggestions - so for example I still can't understand that Vray (which is not in our use) might be able to be helpful here...
Hopefully i was clear above - my question is how to extract pure model data from any IFC file.
In a current case I was able to import a 90 mb ifc file which grows in SkUp to 500 mb skp file which for me is no longer editable ;) unfortunately I often don't have any influence on files which will be made available...
Regards
User avatar
HornOxx
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Pro & Make Discussions
Who is online
Users browsing this forum: HornOxx and 6 guests
Visit our sponsors:
