iPin Pro - Ideal for one-man building surveys!
General discussion related to LayOut
Postby Mike Lucey » Wed May 16, 2018 9:26 pm
Hi Guys,
I think the iPin Pro will be attractive to anyone that completes building surveys. I don't complete as many as I used to which involved two persons a lot of the time. This device eliminates the need for a second person as the user simply takes photos and extrapolates the height, width and length dimensions back at base.
Click image to view animated gif.
The iPin Pro attaches to a smartphone magnetically and the better the smartphone's camera resolution the better the results. It can be used as a standalone device also.
The specs are quite impressive,
The iPin Pro is a current Kickstarter campaign and pitched at around €68. Anyone interested can check it out here.
Mike
User avatar
Mike Lucey
Mayor
Re: iPin Pro - Ideal for one-man building surveys!
Postby pbacot » Wed May 16, 2018 9:48 pm
might be good. I've tried a few iPAD apps that don't have an add-on and found them lacking. It's got to be dependable or it's a waste of time. One such app required zeroing in on all the corners of the room. First you had to find an empty room!
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
User avatar
Top SketchUcator
Postby Mike Lucey » Fri May 18, 2018 5:12 pm
pbacot wrote:might be good. I've tried a few iPAD apps that don't have an add-on and found them lacking. It's got to be dependable or it's a waste of time. One such app required zeroing in on all the corners of the room. First you had to find an empty room!
Hi pbacot,
I’ve also tried out a few iPad apps where one has to zero in on the corners. It was a bit clunky and the results were not that great.
I take you point about taking pics with furniture in place. I have asked the campaigner about this and will report back with anything I learn.
Mike
User avatar
Mike Lucey
Mayor
Postby jo-ke » Fri Aug 17, 2018 8:02 pm
looks interessting.
Does it also creat an SU file in output?
User avatar
jo-ke
Premium Member
Premium Member
Postby aadbuild » Fri Jul 26, 2019 7:45 am
I purchased a phone that used Project tango, it was cool, unfortunately, google ditched it like a hot potato.... There goes a $1000 dollars arghhh.
I would be interested in giving it a go.
Every building designed can be affordable & buildable, to help we built PlusSpec; VDC & BIM for Sketchup
https://www.plusspec.com
User avatar
aadbuild
Premium Member
Premium Member
Postby kaas » Fri Jul 26, 2019 9:18 am
I'm also looking for a more modern and easy way to do building surveys.
In my notes I find the IpinPro had some really bad reviews so it wasn't an option for me. I didn't even bother to write down which reviews so better look for yourself. Maybe they have fixed the software by now.
kaas
Postby billharis » Fri Aug 23, 2019 1:23 pm
Thanks.
Mike Lucey wrote:Hi Guys,
I think the iPin Pro will be attractive to anyone that completes building surveys. I don't complete as many as I used to which involvedtwo persons a lot of the time. This device eliminates the need for a second person as the user simply takes photos and extrapolates the height, width and length dimensions back at base.
Mike
billharis
Postby ramyasri123 » Mon Feb 10, 2020 11:36 am
ramyasri123
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to LayOut Discussions
Who is online
Users browsing this forum: No registered users and 4 guests
Visit our sponsors:
