Hi, i am trying to render object moving animation with VRAY NEXT (Sketchup 2019)
My VRAY camera is set to VR-Spherical Camera.
My problem ist that the animator just skips the frame even if it is not done, when the elapsed time of that frame goes over 10:36.
How can i solve this problem?
Hooni
Animator Problem with Vray Next/Spherical Cam
• Page 1 of 1
Re: Animator Problem with Vray Next/Spherical CamThere is a time out in Animator for the duration of the generation of each frame. I could of course increase the timeout value, but 10 minutes is already a lot.
I would suggest that you tweak the VRAY parameters to get the generation of each frame to be much faster, even if you lose a little bit of quality. In an animation, this is usually acceptable.
Re: Animator Problem with Vray Next/Spherical Camhow can i increase the timeout value? im rendering with for my VR with Stereo-Option for Camera on. So i kinda need that quality.
it would be great actually if there is no timeout at all! thx for quick answer! Re: Animator Problem with Vray Next/Spherical Cam
I have increased the timer to 60 minutes instead of 10 minutes. I hope this will be enough. Please install LibFredo6 v9.1b. Fredo
Now i deleted the version i installed tried to install new one, but i cant get installed on the extension manager of skup somehow... Re: Animator Problem with Vray Next/Spherical Cam
can you make it 120min pls? it would be great! Re: Animator Problem with Vray Next/Spherical Cam
sorry i installed it! last question would be if its possible to have the timeout more than 60? i wann have really high resoultion with vray and for that i need actually half a day to render a frame and if you render over animator with vray, vray swarm doesnt work. is there any way to make vray swarm work with animator? Re: Animator Problem with Vray Next/Spherical CamOK. I'll make it configurable in the next release.
I hope this will work for you. Fredo
Are you seriously going to invest 75 days for say 1 min animation (15 FPS)? ![]() Re: Animator Problem with Vray Next/Spherical Cam
It takes not that long a little ![]() but result is impressive with vr ![]() Re: Animator Problem with Vray Next/Spherical CamI guess throwing the model to UE and even learning it from zero would take considerably less time
• Page 1 of 1
Who is online
Users browsing this forum: NERO7 and 0 guests
