[Plugin] ClothWorks v1.7.9 - 18 Apr 2024
@efrey1991 said:
hola amigo de ante mano agradezco por tal herramienta que pues le da a nuestros proyectos un mejora extra un realismo impresionante.
tengo un pequeño inconveniente cuando APPLY EQULATERAL GRID. BUENO ESTO ME PIDE QUE por favor active su licencia de clothworks para desbloquear la rejilla adaptable, apreciaría este favorhola efrey,
si no escribes en inglés no te van a contestar. son pocos los que hablan castellano en este forum y es cierto que los que lo dirigen no lo hacen. creo que anton tampoco lo hablará.
saludos.
edson -
@edson said:
Thanks, Anton. All of it helps but I still wish it would move a little faster. Which is the property that controls it?
Best regards.
Edson
Edson, you may be experiencing a performance issue, which can't be fixed due to the limitation of the plugin itself. If you send me private message of your model, I will take a look and see if anything could be done to improve performance.
Thanks. I will do that shortly.
tengo un pequeño inconveniente cuando APPLY EQULATERAL GRID. BUENO ESTO ME PIDE QUE por favor active su licencia de clothworks para desbloquear la rejilla adaptable, apreciaría este favorEquilateral and quadrilateral grids work without licensing. The adjustable grid only works with licensing. If you desire to use equilateral grid, you do not need to license the plugin.
@anton_s said:
@jo-ke Did you use the extension manager to install ClothWorks? If not, install ClothWorks RBZ via the Extension Manager (and also SketchUcationTools if desired for licensing):
- Open SketchUp 2019
- Select (Menu) Window -> Extension Manager
- Click Install Extension button
- Select the downloaded RBZ file
- Restart SketchUp
Let me know if this works.
Still not able to reinstall.
Installing via Scetchucationtool I am getting the error: "UnZIP error: Could not unzip archive"
Strange...
Now I used a different library to save the extension.
I relicensed the product and it worked well.
After restarting SU everything disappered.
What did I wrong?
This sounds like a problem typical of incorrect installation of SketchUp. When you installed SketchUp 2018 (I assume that's the version you are using as indicated in your profile), did you right click on the downloaded installer file and select Run as administrator from the context menu?
Oh since a few months I am using SU2019.
I just started the exe file and installed SU and followed the instructions.
So does that mean that you did not install SketchUp 2019 by right clicking and selecting Run as administrator? If you didn't, close SketchUp and repair the installation. Find the downloaded installer file, right click on it. Choose Run as administrator and when presented with the options, select Repair.
OK Thank you. I will try it and report....
I hate it... Where can I find the current download of SU2019pro.
Can't find it at the homepage of SU.... -
Thank you juju. OK, found the installation file, downloaded it, ran as admin, repaired su and restarted my pc. Started su and: clothworks dissappeared again.
Does this occur to all your plugins or just ClothWorks?
It affects only clothworks
somebody any idea?
What exactly does "dissappeared" mean? Is it only that the toolbar doesn't show? Does it show in the Extensions menu? Does it show in Extension Manager? If it does, does it show as Enabled?
first session:
starting SU installing clothworks. everything OK.
clothing SUsecond session:
starting SU, clothworks dissappeared completely. -
@jo-ke In your second screenshot, you have ams_ClothWorks at line 2. I am totally not sure where that is coming from.
Paste the following into your file explorer address bar and send a screenshot of the plugins: %appdata%\sketchup\SketchUp 2019\SketchUp\Plugins
Then navigate into the ams_ClothWorks folder (if any) and send a screenshot.
Then, paste the following into your file explorer, and send a screenshot, if the Plugins folder exists:
C:\ProgramData\SketchUp\SketchUp 2019\SketchUp\Plugins -
OK, theses are the two screenshots:
