Thread maker plug in
General discussion related to SketchUp Pro and Make
Postby Leggy » Thu Jun 13, 2019 4:56 pm
Hi Does anyone know of a plugin to make threads for OSMac?
The ones I found have come up with a pop up saying its not compatible with my system
Thanks Dean
Leggy
Re: Thread maker plug in
Postby gilles » Thu Jun 13, 2019 5:08 pm
User avatar
gilles
Top SketchUcator
Postby Dave R » Thu Jun 13, 2019 5:45 pm
What do you need from these threads? Do you just need to represent threads are are you planning to 3D print them? Or maybe something else?
If I need threads that match existing standards, I find it better to draw the correct profile and extrude it along a helical path. Here are some fairly recent examples.
User avatar
Global Moderator
Postby Leggy » Thu Jun 13, 2019 6:38 pm
hi Yeah I need it for 3d printing
Leggy
Postby Leggy » Thu Jun 13, 2019 6:39 pm
nice work by the way
Leggy
Postby Dave R » Thu Jun 13, 2019 7:05 pm
Thank you.
If you really must have an extension to make threads, you might look at Bolt Maker or Draw Whorl or EP Fasteners. I've used them all but as I said, I prefer to draw them differently.
User avatar
Global Moderator
Postby Leggy » Thu Jun 13, 2019 8:09 pm
Draw whorl , came with a pop up saying it was not compatible with my system, which I don't understand
Leggy
Postby Leggy » Thu Jun 13, 2019 8:19 pm
I downloaded Bolt maker and it said unsigned, what does that mean , and what do I have to too?
Leggy
Postby Dave R » Thu Jun 13, 2019 8:27 pm
What version of SketchUp? Your profile says you are using SU2016 Pro. It's marked as compatible with that.
The message will pop up with later versions but the extension does work in SU2019. It's not a real easy extension to use if you are trying to match standard machine threads but you can give it a go.
I downloaded Bolt maker and it said unsigned, what does that mean , and what do I have to [do]?
Nothing. Just don't set the extension loading permissions too strict.
User avatar
Global Moderator
Postby Leggy » Fri Jun 14, 2019 1:06 am
I just upgraded to pro 2019,$299, so i would have thought i would have been ok
Leggy
Postby Dave R » Fri Jun 14, 2019 2:12 am
You're OK by me.
User avatar
Global Moderator
Postby Leggy » Fri Jun 14, 2019 4:39 pm
What do you mean by that?
EP fasteners is windows only I'm on Mac
Leggy
Postby Dave R » Fri Jun 14, 2019 4:50 pm
Leggy wrote:Nothing. Just don't set the extension loading permissions too strict.
In the Extension Manager there's a gear icon for setting the loading policy. Leave it unrestricted and unsigned extensions will load just fine.
Leggy wrote:EP fasteners is windows only I'm on Mac
That's not what your profile says.
Maybe you should fix that.
User avatar
Global Moderator
Postby Leggy » Thu Jun 27, 2019 1:15 am
Thanks all changed
Do you have any tutorials to make your threads?
I mainly use metric
Thanks Dean
Leggy
Postby Dave R » Thu Jun 27, 2019 1:34 am
Are you asking me? I don't have a current tutorial but it's not especially difficult. Work with units set to Meters and enter millimeters as meters. So for a 6mm screw, draw it as 6 meters. I use Curve Maker's Helix tool to create a helical path for the threads. For that 6mm screw and working in meters, the radius will be 3 meters and the height per turn will be 1 meter.
Then I draw the profile based on dimensions available just about anywhere. If you are modeling external threads you'll wind up drawing a face with a V-shaped notch in it. Draw this is place at the bottom of the helix. Then explode the group containing the helix.
Use Eneroth Upright Extruder to extrude the face up the helix.
As far as terminating the threads, it depends on what you need. Generally you'd draw a shape that matches the end of the screw and intersect that with the threads. For the bottom end of the external threads on this machinists jack I drew a cone and intersected it with the threads to get the chamfer. I used a similar cone on the top of the jack base for the internal threads. At the top of the screw I used a shape like you'd get with a round-nosed tool if you were turning that section of it on the lathe.
If you are 3D printing the model, make sure you clean it up. ThomThom's Solid Inspector2, and CleanUp3 can help as can TIG's Solid Solver.
User avatar
Global Moderator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to SketchUp Pro & Make Discussions
Who is online
Users browsing this forum: nslynn and 5 guests
Visit our sponsors:
