FlexTools Updates
Discussions for FlexTools - Responsive Sketchup Modeling
Re: FlexTools Updates
Postby halroach » Thu Jan 24, 2019 6:08 am
Epix3d wrote:Thank you Juju,. I will try that next time.
I have suggestion.
I often use CleanUp3 plugin to clean my files for unecessary geometry.
The door arc in FleTools Doors should be locked to avoid disappearing when cleaning for stray lines.
[img]
[/img]
I don't quite remember why now, but something tells me not to lock components by default. Maybe it's the red color every time you select the component... :)
Other than locking, another thing you could try in order to avoid the lines getting erased is to open the arc component and draw the radius lines so a surface is generated. Then hide the lines and the surface.
See if that works.
After which ever change suits you, you can then save the component aside with ComponentFinder for future use.
User avatar
halroach
Postby Epix3D » Thu Jan 24, 2019 10:27 am
I cannot find any problem with locking the arc by default as it is locked steps inside the component.
i have made some door libraries previously working like this. If you want to delete the arcs(which should not be necessary as it is on own layer) you just unlock it.
I think default is best way to avoid customers deleting arcs by mistake.
User avatar
Epix3D
Premium Member
Premium Member
Postby pilou » Fri Jan 25, 2019 1:01 am
seems all works fine! ;)
Speedy Galerie
User avatar
Top SketchUcator
Postby halroach » Mon Feb 04, 2019 1:08 pm
You can now produce 45(+) different Dynamic Doors, thanks to Mr. pcmoor and his extremely useful Multi Dynamic Door Panel.
How? By combining it with FlexDoor :)
We've known about this multi door panel component for quite some time now, but it had a catch. The minute you made a copy of it, and altered one of the copies, both DCs would jumble up with sub-components flying all around your model. The only solution was to delve deep into each component and make all of it's sub-components unique - A very time intensive process. So... we decided to develop a tool just for this called 'Make Totally Unique'. After applying this tool to your new door variations, the door and all of it's sub-components will instantly become unique and they will all behave just right.
See more details in this FlexBlog post.
User avatar
halroach
Re: FlexTools problem
Postby porschegt2 » Mon Feb 04, 2019 7:05 pm
Hi all,
Iam using the flextools pro but i cant Access to parameters from Windows and doors… anyone can help me out solve this issue?
thanks a lot
carlos
porschegt2
Postby juju » Mon Feb 04, 2019 7:43 pm
click into them a level or so to access more DC options
User avatar
juju
Premium Member
Premium Member
Postby halroach » Tue Feb 05, 2019 5:41 am
porschegt2 wrote:Hi all,
thanks a lot
carlos
Hi Carlos,
I just replied to your email about this issue. If you still can't get to the parameters, please post a screenshot/video.
* Edit for reference:
The issue had to do with a crazy DC plugin bug - '/u' was appearing in the folder path where the SKP file was being saved to which would then cause the DC plugin to fail with errors.
More about this issue at: https://forums.sketchup.com/t/error-on- ... w/19991/21
User avatar
halroach
Postby Ivan K » Wed Feb 27, 2019 3:15 pm
Just came to say a very big thank you to you all for including the hidden door!
I was designing an interior renovation with "EZY Jamb" details and you showed up just in time!!!!
Thank you!
Ivan K
Postby juju » Thu Feb 28, 2019 8:10 pm
Yoni, can you look into incorporating the PCMoor DC door as well?
User avatar
juju
Premium Member
Premium Member
Postby halroach » Fri Mar 01, 2019 6:17 am
juju wrote:Yoni, can you look into incorporating the PCMoor DC door as well?
Hey Juju,
I'm unaware of this DC door. Can you send a link?
When you say to incorporate, do you mean to get it to work as a wall cutting component?
User avatar
halroach
Postby halroach » Fri Mar 01, 2019 7:06 am
We’ve had a chance to visit a manufacturer of beautiful high quality hidden doors called Minimal Doors.
Now we’re happy to share with you their elegant, hidden, very minimal (now flex) doors, and a new WallCutter feature ‘Hide Cut Edges’.
Learn more about how to hide frames in this FlexBlog post.
User avatar
halroach
Postby juju » Fri Mar 01, 2019 9:59 am
Hey Juju,
Man, you guys must be real busy... :thumb: ;)
See your BlogPost & mail comms of 01 February 2019.
User avatar
juju
Premium Member
Premium Member
Postby halroach » Fri Mar 01, 2019 10:24 am
juju wrote:Man, you guys must be real busy... :thumb: ;)
Hah :)
Well... we are crazy busy, that's true!
I thought you were referring to a different (complete) door component that I haven't seen in the 3D warehouse, and not to the dynamic panel.
The blog post/video basically show how to insert the door panel into FlexDoor, and you can always save it aside with Component Finder for later use.
We could theoretically incorporate it into one of our components by default... but should we?
It's a cool panel, though the workflow with it - the need to use the 'make totally unique' tool, isn't a straight forward process. I think it would confuse and frustrate sketchuppers who first install flextools. They would copy the door around and then find that things are acting really weird with components flying around, and they wouldn't know why. It's also a bit heavy/slow in larger models. I think it would be problematic.
User avatar
halroach
Postby halroach » Thu Mar 28, 2019 4:46 am
New Flex Casement Double Window with 20 window style presets is released! :bounce: :bounce: :bounce:
See more details in the FlexBlog:  https://flextools.cc/blog/flex-casement-double-window/
User avatar
halroach
Postby halroach » Fri Apr 05, 2019 7:53 am
A new video by Justin from The Sketchup Essentials shows how to build a house in no time using FlexTools and Tig Roof.
User avatar
halroach
Postby pbacot » Fri Apr 05, 2019 5:07 pm
Nice video. Congrats. Windows are almost always set according to the head height not the sill height.
MacOSX Mojave High Sierra SketchUp Pro v19 Twilight v2 Thea v2 PowerCADD
User avatar
Top SketchUcator
Postby halroach » Mon Apr 22, 2019 7:08 am
3 New Flex Windows released!
Dynamic Hopper-Awning, Casement Single and a Fixed Window are now available.
They can also be combined into new types of windows!
Learn more in the FlexBlog.
User avatar
halroach
Postby halroach » Tue Apr 23, 2019 11:32 am
With this new Flex Window, you can create a simple Hopper.
Change one setting and it's an Awning!
Change another setting and it's flipped inside out!
Double Click into it and you have the same  20 presets and full customization  like with the previously released Casement-Double.
User avatar
halroach
Postby halroach » Wed Apr 24, 2019 3:37 pm
Casement-Single Flex Window
It’s just like the recently released Casement-Double, but single! :)
User avatar
halroach
Postby pbacot » Wed Apr 24, 2019 3:46 pm
Looks great. Are you sure about the handle placement for hoppers and awnings? Can the handle be omitted?
User avatar
Top SketchUcator
Postby halroach » Thu Apr 25, 2019 7:25 am
pbacot wrote:Looks great. Are you sure about the handle placement for hoppers and awnings? Can the handle be omitted?
Hi pbacot,
The handle in the hoppers and awnings (and in the casements too) are placed by default like in a tilt and turn window, but they aren't tilt AND turns, rather just tilt, OR Turn... So you have a good point! :)
I'll add an option to center the handle on the lower rail for it to suit tilt OR turn windows!
The handle's placement, visibility and rotation can be easily changed. Double click into the component and select it:
You can choose to hide it completely.
You can have it visible on one side of the window or the other.
(It may sound weird to have the handle on the outside, but it makes sense when you start flipping the window in and out and if you happen to like placing windows from the interior rather than from the exterior, or if you'd like to use the casement windows as doors...)
You can also delete the handle all together if it bothers you - no harm will be done, everything else will continue working.
You can also swap the handle with others or customize the handle manually to any handle you choose following the instructions here: https://flextools.cc/learn/flexdoor/hardware/
It may look daunting, but once you get the hang of it, making your own dynamic handle is a matter of minutes.
I hope that all makes sense.
User avatar
halroach
Postby halroach » Sat Apr 27, 2019 1:33 pm
A Fixed Flex Window
It's similar to the original FlexWindow, but it is a lot simpler.
Read more details in the FlexBlog: https://flextools.cc/blog/3-new-flex-windows/
User avatar
halroach
Postby halroach » Tue Apr 30, 2019 11:09 am
We started working on FlexStairs!
Here is a work-in-progress video:
  • The stairs are recalculated while scaling according to the restrictions you enter (based on Blondel's Rule).
  • The top step can be hidden.
  • You can set a minimum riser height.
  • You can also set a fixed tread length.
To be continued... :)
User avatar
halroach
Postby juju » Fri May 03, 2019 5:41 pm
Personally I’d say that if the tool does the various possibilities structurally it should be fine as longs as components are used. The range of possibilities for balustrades and handrails together with inlays, finishes, nosings, etc. is so wide that I’d rather take the time to customize the components particular to the application than try to fiddle with numerous settings to see what it comes out like only to end up doing a partial custom job anyway. Remember to work in landings and being able to set governing parameters for that.
User avatar
juju
Premium Member
Premium Member
Postby Epix3D » Wed Jun 05, 2019 3:29 pm
Where can I find wooden double doors like in gif?
Also in my(Activated)ComponentFinder text is red when searching and doesn´t work.?
User avatar
Epix3D
Premium Member
Premium Member
Postby halroach » Wed Jun 05, 2019 5:36 pm
Epix3D wrote:Where can I find wooden double doors like in gif?
Hi Epix,
The components in that animation were all components I created with the Flex components as a base.
1. Pull in a FlexDoor component.
2. Change the door to a double door in the component options window - double click into the component and then select it to reach the correct options window and change number of doors to 2.
2. Change the handles with handles from the 3DWarehouse and then recalibrate their location with the interact tool.
3. Add which ever wood material to the sub-components you want.
4. You can then save the component with component finder for later use:
Epix3D wrote:Also in my(Activated)ComponentFinder text is red when searching and doesn´t work.?
The red text appears if nothing comes up when searching. Since it appears you have no folders open it won't find anything for sure. Add a few folders and then search through them and it should work as expected.
Please let me know how it works out.
User avatar
halroach
Postby halroach » Tue Jun 11, 2019 3:23 pm
FlexSlope
New FlexSlope Component easily calculates ramps, car parks, roofs etc.
The original, simpler beta version is available for free download at the FlexLabs.
See more details at the FlexBlog.
User avatar
halroach
Postby halroach » Mon Jun 17, 2019 12:35 pm
You can now also specify the number of divisions in Colonial Style Distributions.
More updates in our Blog: https://flextools.cc/blog
User avatar
halroach
Postby juju » Thu Jun 20, 2019 3:36 pm
I tried once last night and twice today, this update is not installing via the FlexTools Manager. It keeps on showing the update is available, even after restarting SU and after restarting the machine.
User avatar
juju
Premium Member
Premium Member
Postby halroach » Thu Jun 20, 2019 3:44 pm
juju wrote:I tried once last night and twice today, this update is not installing via the FlexTools Manager. It keeps on showing the update is available, even after restarting SU and after restarting the machine.
Hi Juju,
1. Hmmm, what happens when you update? Does it show it downloading and installing or nothing happens?
2. Are you getting any error messages?
3. Anything in the console? Window > Ruby Console
4. Please send any log files you find to yoni@flextools.cc:
C:\ProgramData\F3d_FlexTools\logs
I'm available on the flextools.cc chat now if you have the time and we'll figure out what's going on.
User avatar
halroach
by Ad Machine » 5 minutes ago
Ad Machine
Robot
PreviousNext
Return to FlexTools
cron
Who is online
Users browsing this forum: No registered users and 0 guests
Visit our sponsors:
