procedural texture
General discussion on Thea Render for SketchUp
Moderator: Frederik
procedural texture
Postby fabrice » Wed Apr 24, 2019 3:45 pm
Hello,
Does anyone know how to get a procedural texture pretty much like this? :oops:
Thank you in advance and good day to all!
Fabrice
fabrice
Re: procedural texture
Postby majid » Sat May 04, 2019 7:59 am
Will give it a try
I guess it could be possible by:
1- Noise map, adjusted
2- Combination of Niose and ramp map.
My perspective shortcuts book: https://bit.ly/30Tdbce
User avatar
majid
Top SketchUcator
Postby majid » Sat May 04, 2019 3:37 pm
Here is my test, exactly not what you want but will give it another go
User avatar
majid
Top SketchUcator
Postby majid » Sat May 04, 2019 3:47 pm
This one is pretty much better i guess. Also May scale it to approach the desired map.
User avatar
majid
Top SketchUcator
Postby fabrice » Sun May 05, 2019 11:51 am
Thanks a lot Majid I will try this ! :)
Il will say you the result
fabrice
Postby majid » Sun May 05, 2019 9:21 pm
So seeing forward to see from you.
User avatar
majid
Top SketchUcator
Postby ntxdave » Mon May 06, 2019 4:10 am
I tried to find the TextureLab software but do not think I found the correct thing. Would you mind sharing some info or a link to it?
User avatar
ntxdave
Postby majid » Mon May 06, 2019 8:33 am
If you are using version 1.5 just double click the material to open up the Thea material lab.
V2.x includes all material lab features by default.
User avatar
majid
Top SketchUcator
Postby ntxdave » Mon May 06, 2019 3:11 pm
Is that V-Ray or some other rendering software? I do not have/use V-Ray.
User avatar
ntxdave
Postby majid » Mon May 06, 2019 8:13 pm
This is obviously Thea.
In Thea material lab you can recall texture lab from left side , the second from top icon as I highlighted in screen snapshot.
User avatar
majid
Top SketchUcator
Postby ntxdave » Mon May 06, 2019 10:30 pm
Thanks for the response. That explains why I could not find it I use Twilight Render. That sure looks like an interesting tool. :)
User avatar
ntxdave
Postby majid » Tue May 07, 2019 5:12 am
I am pretty sure that Twilight is capable of generating such textures as it has even stronger procedural texture library. let me give it a go this evening.
User avatar
majid
Top SketchUcator
by Ad Machine » 5 minutes ago
Ad Machine
Robot
Return to Thea
Who is online
Users browsing this forum: No registered users and 0 guests
Visit our sponsors:
